Question about Hobart Welding Tools
The unit powers up but when you pull the triger it just clicks and pulls the power down.
    Problem Solver:
  • 6 Answers
There is the possibility that that the tensioner for the wire rollers is too tight. If this is the case here is a good rule of thumb for any make wire welder. Run the wire out of the tip about an inch or so, grab the wire with your fingers, now pull the trigger. If the wire is pushing your fingers back with a good amount of force loosen the tensioner, and repeat this procedure until the wire just starts to push and then the wire starts to slip in the rollers of the wire feed. Your tensioner will be set just right. Another possibility is that the tip and nozzel are dirty causing it to ground when you pull the trigger and the wire touches your work. If this is the case clean both tip and nozzle. A good tip is to us a an anti spatter product. Just rememer to dip the nozzle in it every once in a while, while the nozzle is hot. A third possibility is that the liner in your lead is dirty or the wrong diameter wire for the lead, tip or the rollers is being used. Check to make sure that these items match the diameter wire you are using.
I know the response is a little long, but I hope it helps.
Posted on Nov 15, 2009
Hi I have a 2002 goldwing GL1800 I put a headset in my helmet and everything works but the cb when I pull the triger to talk the music cuts out and I cant here my mate and he cant here me
check the switch that is operated when you pull the trigger for the cb
it may be possible that the switch is cutting of the radio but not connecting to the cb power wire
just a thought
Dec 19, 2016 | Motorcycles
Pressure will not kick in consistantly
The circled part is the one that usually will stick.
Jan 14, 2010 | Karcher K2.26 Electric Power Washer
How do i remove the bolt from the mossburg 308 win. and is there a product you offer to modify the triger
if i were you i would leave the bolt alown,,its a hell of a job getting them back in,,,as for the triger i know there a bit on the heavy side to pull at nearly 4 lbs but its a safe pull,you could drop the gun into a gum smith and get him to snip off a coil off the triger pull spring,,and stone the sear,, but be warned it will make the triger twitchy,,you realy dont wont to light a triger on a hunting rifle 4 - 6 lbs is normal
Nov 18, 2009 | Optics
MY HONDA POWER WASHER
Nozzle is dirty. Use small diameter wire to clean out nozzle.
Sep 09, 2009 | Honda Pressure Washer PSI 3000
The tool attachment won't spray water-
you almost have to open up the unit and follow the hoses from the handle into the base.fill it with solution and turn on pull triger.hold the triger in and turn off the unit keeping the triger pulled.turn off and start it up and try again.if it don't spray you might have a bad pump.open up the unit and see if all the hoses are hooke up.there should be a plug on the handle .is it plugged in.please leave feedback.i hope i was some help to you...pet
Apr 26, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Apr 25, 2009 | Karcher Garden
Welder feeding or arking
Release the wire feed rollers,turn the wire feed dial up to maximum ensure you are well away from the earth clamp, pull the triger, you should hear the relay click in, if it dosn't check the 5 mil anti serge fuse positioned on either the front of the set or on the control panel near the wire feed rollers inside the cabinet. usualy covered by a plastic screwed knob, make sure the unit is unpluged before any testing.
Jan 18, 2009 | Welding Tools
Welding Tools Logo
91 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
