Question about Panasonic Televison & Video
I have a panasonic dmr-es10 after I record a dvd it wont play back on other dvd players. It doesent matter if I use a dvd-r or dvd+r. Playback is fine on the recorder itself.
  • pamscott2 Nov 14, 2009
    ok do i finalize before i stop recording?
  • pamscott2 Nov 15, 2009
    So I dont hit stop on recording? I hit the finalize button while it is still in record mode?
  • 10,594 Answers
Recorded DVD disc has to be "Finalized" in DVD Recorder at end of recording then it can be playback in other dvd players. Without Finalization, only the actual dvd recorder can playback its own burned dvd disc.
Finalize option is available in DVD recorder Menu.
Hope this info will help you.
Thanks.
Posted on Nov 14, 2009
  • Shahid Electronics
    Shahid Electronics Nov 14, 2009
    NO, when you decide to end the recording on one dvd disc, means no more recording is needed on that dvd disc then finalize it.
    Finalization will close further recording option on that particular disc.
    Now this burned dvd disc is ready to playback on any other dvd player including its won dvd recorder.
    Thanks.
    Shahid Electronics Nov 15, 2009
    Let me explain it.
    DVD recorder is recording on disc, TV program that is being recorded reaches on its end, press Stop button, there is not further program that needs to be recorded and need to take out recorded disc, now Finalize the recorded disc. This will let say lock the dvd disc for further recording and now it can be playback on other dvd players too.
    Hope this info will help you. Do you have user manual copy of DMR-ES10 ? It has all info about finalization of dvd disc.
    If need copy, click Panasonic Support to download free copy of user manual.
    Thanks.
Transfer from Widescreen camcorder through S video results in Full Screen instead of Widescreen
have you set the dvd to widescreen? i know some change automatically when there is widescreen input but some need to be changed manually. This should be in system settings. hope this helps
May 19, 2009 | Panasonic DMR-ES10 DVD Recorder
Can't record DVD+RW and DVD+ Disks...PLUS
Firstly, you need to finalize the -R disk recorded by and in your unit before it will play back anywhere else.
Secondly, the DMR-ES10 does not support +RW, only -RW.
Finally, I have never heard of a +D. Do you mean +R? It is likely that you have a corrupt disk; change it.
Mar 11, 2009 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
Mar 08, 2009 | Panasonic DMR-ES10 DVD Recorder
X HOLD on player screen if button press. Panasonic DMR-ES10
My Panasonic is doing the same (displaying HOLD). Did you find out what the problem was?
Jan 20, 2009 | Panasonic DMR-ES10 DVD Recorder
No Sound when recording with DMR E100H Panasonic
You should check that the connections and audio settings of your unit are as you require for playback.
Nov 01, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr es10
What SCART connections do you have on each of the three units (TV, Virgin+ and DMR-ES10)?
Oct 26, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Aug 30, 2008 | Panasonic DMR-ES10 DVD Recorder
Playback of discs
Have you tried setting the players video output to your TV type?
R1 discs are NTSC(30 fps), while R2 are PAL(25 fps). Look for video output or TV type in the player's menu. Most player's default to "any", passing whatever signal is on the disc to the TV.
Dec 19, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
