Question about Kenmore Washing Machines
Washing machine will agitate but not spin.
I have a Kenmore 90 series washing machine and recently I have noticed that the cloths come out soaking wet. I checked during the cycle to see what was happening by holding down the lid switch with a screw driver, and it would rinse the cloths and when it was supposed to spin it would just continue to agitate until the end of the cycle. It also has a slight, not strong at all, burnt smell inside of it, kinda like the smell of a fried circuit board. Any ideas? Thank
BTW
Model # 110.23932201 (it was manufactured by whirlpool for Kenmore I believe.)
  • 221 Answers
SOURCE: 10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Jan 08, 2009
  • 1122 Answers
SOURCE: Agitator doesn't turn during wash / rinse cycle
top the top off the agitator,remove cap inside,you have 4 plastic dog ears you need to replace,your local appliance store has them for $2,let me know how you do-mike
Posted on Mar 24, 2009
cj2176
  • 520 Answers
SOURCE: Washing Machine Will Not Spin. I'm left with
Possible bad clutch.
Posted on Jun 18, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Posted on Aug 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 90 tub spins excessively clockwise during wash cycle.
Improperly installed thrust bearing kit. Too many washers cause the basket to spin during agitation.
Posted on Jan 04, 2010
Testimonial: "Where is the "thrust bearing kit" and how can it be installed properly?"
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Why did my washing machine stop spinning?
Not knowing the age or model of your washer it's hard to say but if it is the older direct drive then it's a bad lid switch!
Dec 08, 2015 | Kenmore Washing Machines
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
Tub not working in spin cycle
Replace the brake/clutch on the transmission.
You can DIY.
May 25, 2009 | Kenmore 24922 Top Load Washer
Kenmore series 90 washer spins but the clothes are still very wet
you probably need a new clutch (Whirlpool Washer Clutch Kit 285785 fits kenmore too) , or your gear case is shot.
Feb 13, 2009 | Kenmore 24032\24036 Top Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Problems with Spin Cycle
Sounds like the "out of balance" mech has been destroyed. Check for that first
Jul 23, 2007 | Kenmore 27032
Washing Machines Logo
163 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
