High blue the blue does not line up with the other colors its higher then the rest
  • 8,617 Answers
Convergence ICs are bad.Thats why you cant converge the blue back inline with red and green.
Posted on Jan 13, 2008
What color should the ping pong table be?
Thetable should be in dark color (ie. Blue, green) and have white lines on thesides and top and bottom.
Aug 05, 2012 | Sport & Outdoor - Others
Tv turns off and on by itself. when turned off, it shows bands/lines of color. what could be the problem?
high voltage regulation problem. when high voltage gets too high protection circit kicks in and shuts off tv. since high voltage is too high, you will see a glow with horizontal retrace lines. if you see red, green, and blue lines your convergence ic's are overheating. suggest local service center
Nov 10, 2009 | Televison & Video
Samsung Model HLR4667WAX/XAA is making a buzzing sound
This TV is horrible. I have the same one and not even a year replaced the light bulb twice. Very disappointing for a Samsung.
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
The colors of my oki c5150 do not line up, they all print but the blue will start higher then the others making it look like a 3d picture without the glasses. It is not a set amount higher, even on the...
Sir,
This is the problem with toner cartridge. This may be clogged. Remove the toner cartridge, through cleaning and insert it. It may be solved.
Thanks Good Luck
Aug 24, 2009 | OKI C3200n Led Printer
Screen fades to blue.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
Apr 02, 2009 | Sony KP-57WS500 57" Rear Projection...
Colors off. blue and yellow not lined up
try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Sep 30, 2008 | Televison & Video
Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
Nov 28, 2007 | Philips 20 in. TV/VCR/DVD Combo Flat...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
