Question about Dewalt & 2HP Hand Carry Heavy Duty Electric Air Compressor
My dewalt D55152 compressor is leaking air. It will build air and shut off. I thought it was leaking from the regulator, but I replaced that, still doing the same thing. The valve that come out the the bottom tank that the supply house hooks to that runs to the regulator my be the problem can some one advise? Thanks, Jimmy
    Sergeant:
  • 399 Answers
Check with atlas copco in hemel hempstead hertfordshire england they service and repair all dewalt and have an help desk
Posted on Nov 15, 2009
Dewalt Emglo 55168 motor starts to slow down as pressure builds to about 30 PSI. It really starts to labor. Any thoughts as to what could be causing the motor to strain and slow?
Most likely in tank check valve is leaking or belt is slipping. Belt tension easy to check, should not deflect with thumb pressure. Check valve should not let air escape out of tank. Easy to check. Run compressor till pressure builds to around 50 psi. Then unplug machine from power outlet. Listen for air leaking out of tank. In bad cases, air will actually leak out of intake filter. Replace check valve as needed. Good luck
Oct 26, 2016 | Dewalt Air Tools & Compressors
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Will not allow me to regulate air. compressor kicks on and builds to max pressure.
All air compressors build pressure in the tank(s) to their maximum allowed by the pressure switch. The regulator only controls the pressure of the air available at the outlet. That's why they have two pressure guages, one for tank pressure and one for outlet pressure. If you cannot control the air pressure at the outlet then you have a defective/broken regulator. Dewalt does not make the regulator as a seperate part for their air compressors, you have to buy the entire manifold which includes a regulator to fix this problem.
Jan 31, 2011 | Dewalt 2 Hp 4 GAL Air Compressor
D55152, left gage shows 40psi, right gage 100. Whats going on. how can i buy a manual? thanks
The right guage is the actual tank pressure. The left guage is the pressure for the air hose. If you turn the adjustment dial the air pressure guage on the left will go up or down. You should be able to go to the dewalt website and find an owners manual for this compressor. I personally own this compressor and it is a good one.
Nov 14, 2010 | Dewalt D55141 Heavy Duty 2 Gal, 150 Psi...
I have had this problem intermittently - often it occurs if I left the compressor pressurized overnight (i.e. forgot to drain it.) In the morning the pressure has gone down - I can turn it back on and...
There is only one relief valve and it is on the outside. The valve is set to open if pressure builds past 160psi. You may be having trouble with the pressure regulator (large knob with high/low arrow). This regulator will leak at times. You can determing if it is leaking by unplugging /shutting off the compressor when you hear the leak. If the leak stops as you shut it off then most likely due to discharge tube seal at the head of the pump. If you continue to hear leak after shut off turn pressure knob counter clockwise all the way out. If you hear a change in the amount of leak or stops then pressure valve is problem. Parts are available at dewalt service center or at www.toolpartsdirect.com
Oct 03, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Dewalt compressor d55152 just hums, has been used twice in 2006 and am finally getting around to fixing it. Any info on possible problems would be extremely helpful
Check your start and run capacitors ... you could just replace them or take the device to a motor repair place and have them check the caps.
Checking the caps is sortof a specialty. Most backyard mechanics do not have the ability to check accurately.
Dec 24, 2009 | Dewalt & 2HP Hand Carry Heavy Duty...
I have a dewalt D55155 compressor that has not been used in three years. It starts and builds pressure, but does not charge the air hose. Ant thoughts?
have you turned up the regulator, the big black know by the output fitting
You may have to open andclose it a few times cuz it may have trash or be stuck
Nov 04, 2009 | Black & Decker Dewalt #D55155 2HP 4GAL...
How much power (kw/hr) does a D55152 use at full capacity?
Below you will find the power requirements for your compressor. I would recommend not to use an extension cord due to possible damage to capacitor. My dewalt a/c, with same motor, is actually using 17.5 amps right before shut off. Good Luck!
  • Drive: Direct
  • Horsepower: 2.7 MAX HP
  • Tank Size: 4 gal
  • Power Supply: 120V AC, 15 amps,
    >60 Hz, 2 pol induction motor
  • CFM @100 PSI: 3.8 CFM
  • Pump Speed: 3400 rpm
  • Tool Length: 18"
  • Tool Width: 18"
  • Tool Height: 16"
  • Tool Weight: 65 lbs
  • Oct 15, 2009 | Dewalt Heavy - Duty 1.1 Hp Continuous 4...
    Manual for Emglo Air Mate Compressor
    Manual for the similar dewalt model is at www.dewalt.com, click on parts & service icon, then enter D55151. Or try clicking here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/5135175-01,D55152,Elec.pdf This Dewalt compressor is one of many versions of the Old Emglo AM78 compressor. There are several other brands built with the exact same design such as the Senco line. For parts list of actual Am78hc4v go to mastertoolrepair.com. If you have questions or problems with this compressor please email, Good luck
    Jan 28, 2009 | Dewalt d55151 factory reconditioned emglo...
    Dewalt & 2HP Hand Carry Heavy Duty Electric Air Compressor  Logo
    346 people viewed this question
    Top Dewalt Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Dewalt Plumbing Expert? Answer questions, earn points and help others
