Hi, my desktop likes to shutdown randomly and I
Hi, my computer likes to shutdown randomly and I don't know why. I never had this problem 2 years using it. Please help find a solution? Thank you!
  • 3,153 Answers
I have fixed quite a few computers that have this type of issue with the followin procedure.
Generally I "always" re-seat the fan but if you are not comforatble doing it your local repair shop can do it quite cheaply
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
Posted on Nov 14, 2009
    Master:
  • 956 Answers
Check out your power settings in control panel
If it is then alter to Never or 30 mins, change to suit your needs>
Come back if correct?
1990 dakota engine shutting down randomly
I had a 1988 dodge Dakota ,and it did the same thing. I fould that the o2 sensor was bad. I am a self employed mechanic
Oct 28, 2012 | Dodge Dakota Cars & Trucks
My Acer X1700 desktop randomly gives Blue screen and locks or sometimes reboots. The error shown on blue screen dump says some like "a prblem has been detected and windows has been shutdown to prevent...
Your hard drive is corrupted - virus, bad driver file, etc... You may need to reformat and re-install Windows or operating system. Before you do that, remove the harddrive and "slave" it on another computer to backup you data. The other computer should be able to discover the corrupted harddrive allowing you to do the backup. Then you can proceed with the repair or reformat.
Oct 24, 2010 | Acer Computers & Internet
I always get this message on my computer desk top and dont know what it means..(The system process c.\windows\system services .exe terminated unexpextedly with status code -1073741819.T HE SYSTEM WILL NOW...
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Oct 06, 2010 | Microsoft Windows XP Home Edition
My computer is shutting down on its own. Is this
May 15, 2010 | Dell Dimension 3000 PC Desktop
My computer keeps shutting down randomly. Also when i try to use F10 it will not respond if i try and run error checking the system will crash/shut down or give me a black screen. Basicly it randomly...
Possibilities:
1. overheating, and automatic shutdown.
Check that the fans are working.
2. bad RAM, causing "random" crashing.
On a "good" computer, download the free 'MEMTEST86+' software, and run it, to test your RAM.
3. Leaking capacitors on motherboard, causing "voltage-spikes", leading to "random" errors.
4. Bad disk-drive. Remove the disk-drive.
Connect it as a "slave" drive in another computer,
and run 'CHKDSK' ("Check Disk") to look for problems.
Apr 16, 2010 | HP Pavilion a450n PC Desktop
My desktop would just turn off randomly i would be using the internet n without warning would just turn off.
This is common with older laptops and is usually from overheating. Dust is the most common cause. Depending what machine you have, unplug it and disconect all cables and hold the power button in for 10 seconds, remove the side panel or the cover. This may require removing some screws. If you find it's dusty remove it by blowing with a can of compressed air or other air source at low pressure. Be carefull not to bump or otherwise damage anything inside. Also as an afterthought check to see if a cooling fan is present and working.
builderdale
Jan 12, 2010 | Office Equipment & Supplies
Fan won't cool enough, causes random shutdown
it could also be your power supply or the presence of viruses/malware
Mar 20, 2009 | Gateway 3250S PC Desktop
Shut Down Problem & Have to Reset Computer Battery
Hi, I had the same problem, for a workaround this is what I did. I made a new shutdown shortcut. Now when I click on it the pc shutsdown fine. I actually put mine on the taskbar. Here's how I did it...
XP Users:
1. Right click the Desktop and select New /Shortcut.
2. A screen will appear asking you for a Command Line. Here's what you put in that box:
For Shutdown:
Shutdown -s -t 0
For Restart:
Shutdown -r -t 0
For Log Off:
Shutdown -l -t 0
After you've decided which of the above options to use, click the Next button and give the shortcut an appropriate name.
Final Notes:
1. Now that you have the nifty little shutdown shortcut on your desktop, you may want to drag it to your taskbar for easier access (and less chance of accidental clickage).
2. I didn't like the nasty looking icon that XP gave my shortcut (it was too Win3.1 for my taste), so I changed it.
If this helps you plz rate this 'fixya'. If not leave a comment & I'll be happy to try to help you further. Thank you kindly.
Feb 12, 2009 | Dell Dimension™ B110 PC Desktop
No video on boot up!!
have you tried to uninstall the vedio driver and reinstall it then let me know.go to my computer icon right click it > go to properties >hardware tab > device manager and check if there is any yellow mark showing.kindly do this in starting your computer in safe mode.
Oct 09, 2007 | Gateway 500XL PC Desktop
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
