Question about Cosmi Print Perfect Platinum
Error reading event file - Cosmi Print Perfect Platinum
  • 34 Answers
The EVT files include the event log messages as they are stored by the system. Each message is composed of an ID (that is, the message itself) and a number of insertion strings. The IDs are translated into strings through the use of messages DLLs.
All the application event logs messages DLLs are defined under the following registry keys:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ Application
All the system event logs messages DLLs are defined under the following registry keys:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ System
For example, the TCP/IP service's message DLL is defined under the following registry entry:
Key = HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ System\TcpIp Value = EventMessageFile REG_EXPAND_SZ %SystemRoot%\System32\ netevent.d
Therefore, all the TCP/IP event log messages are defined in the DLL netevent.dll.
When the user double-clicks an event for which the message DLL is not defined in the registry, the message string cannot be displayed and the following message is displayed: The description for Event ID (51) in Source (aservice) could not be found. It contains the following insertion string(s): ... Below is a description of a way to read the system event logs of a computer with WINS on a computer without WINS. This sample can be adapted for any application or system component.
WARNING: Using Registry Editor incorrectly can cause serious, system-wide problems that may require you to reinstall Windows NT to correct them. Microsoft cannot guarantee that any problems resulting from the use of Registry Editor can be solved. Use this tool at your own risk.
The following operations are required:
  1. On the computer with WINS, run REGEDIT and select the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ System\Wi
  2. On the Registry menu, click Export Registry File and select a file name (for example, Winsreg.reg).
  3. On the computer without WINS (for example, the one used to read the system event logs of the computer with WINS), run REGEDIT. On the Registry menu, click Import Registry File and select the file Winsreg.reg previously saved on the other computer.
  4. You should now have the following registry entry on the target computer (that is, the one without WINS):
    Key = HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ EventLog\System\Wins Value = EventMessageFile REG_EXPAND_SZ %SystemRoot%\System32\ winsevnt.d
    You now need to copy the file defined in the EventMessageFile registry value in your System32 directory. If X: is mapped to \\wins_server\admins$, you can run the following command: copy x:\System32\winsevnt.dll %SystemRoot%\System32\winsevnt.dll
    Of course, the file may be copied somewhere else, but in this case you need to edit the EventMessageFile registry value manually so that it points to the directory with the DLL.
  5. Close all the instances of the Event Viewer and rerun the Event Viewer. You should now be able to dump all the WINS events.
Posted on Nov 15, 2009
Error code 1309
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
In a perfect world, a computer would run smoothly without any glitch or error.
Of course it isn't a perfect world, though, and PCs do come under the occasional error.
One of those, Error 1309, occurs when you install either Microsoft Office 2003 or Microsoft Office Project 2003.
It is due to an ordering issue in the program's installation.
There is no perfect order because many computers handle the software differently, but there is a fix for the error if it should ever come up.
Open "Notepad."
Click "Format." Make sure "Word Wrap" is not selected or enabled.
Click "Open" and then navigate to the folder "C:\ProgramFiles\MicrosoftOffice2003\Files\Setup." Scroll through the list of files and select "PROJPRO.XML."
Search the file for the section "OCLNCORE.OPC_1033."
Once found, there will be a "CATCHLEVEL=1" written next to it.
Change the 1 to 3 so it reads "CATCHLEVEL=3
Save the file. Make sure it is saved over the original file.
This will override the error message 1309 and keep it from appearing.
http://support.microsoft.com/kb/830422
More information on error 1309
Aug 27, 2013 | Lenovo Computers & Internet
Tip
How to display Errors found and Repairs made by CHKDSK
<b> <p>How to display Errors found and Repairs made by the CHKDSK Command<br /></b> The Chkdsk command is used to verify the integrity of a file system and is capable of correcting discrepancies in system data files. This command has been with us since DOS days and has been modified by Microsoft as required to meet the requirements of new operating and file systems as they evolved. <br /> If you execute the Chkdsk command from a command prompt without using the F (fix) switch, Chkdsk runs in the read-only mode. As Chkdsk runs its tests on the drive, it displays the results of these tests on the monitor screen and the test results remain there for you to read until you close the CMD box.<br /> However there are several drawbacks to running Chkdsk in the read-only mode, especially on an active NTFS volume (usually C:) <br /> 1. Chkdsk cannot make any corrections to the drive while in the read-only mode.<br /> 2. If Chkdsk encounters more than minor errors, it will not complete all of its tests.<br /> 3. If you are running Chkdsk in the read-only mode on the active partition, Chkdsk frequently reports disk corruption and other file system errors which do not exist. This happens when the system modifies the disk during the Chkdsk testing sequence.<br /> Considering the above, there is little to be gained by running Chkdsk in the read-only mode.<br /> You need to run Chkdsk/F at the command prompt to test the drive and to correct any errors found.. As soon as you make this entry the system responds with:<br /> "The type of file system is NTFS. Cannot lock current drive."<br /> "Chkdsk cannot run because the volume is in use by another process. Would you like this volume to be checked the next time the system restarts? (Y/N)."<br /> After you key in "Y" (followed by enter) and re-boot, the operating system starts to load and you are advised that a disk check has been scheduled and unless you cancel it, Chkdsk/F will start to run in a few seconds. (Actually the file being executed at this time is Autochk.exe). Chkdsk will run through its phases but it only displays the test results on the monitor screen for about 2 seconds before the screen clears and the operating system continues to load!<br /> If problems were found wiith the file system, you will not have time to read any messages regarding what they were or what actions were taken. If corrupted files and/or orphaned files/directories were detected you would most probably like to know about it and other problems found by Chkdsk. So how do you display the errors found and actions taken?<br /> The answer is that since running Chkdsk/F is a system event, the information is recorded in the System Event Log under application events. To read the log, Click on Start, Control Panel, Administrative Tools, Event Viewer and Application. Look for "Winlogon" in the Source column and double click on it. An Event Properties dialog box will open and display the log for you to read..<br /> Yavacotech.<br />
on Dec 09, 2010 | Computers & Internet
Tip
How to display Errors found and Repairs made CHKDSK
Yavacotech.
I cannot drop files from my laptop to my lacie n2870. What is the problem?
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Jan 13, 2013 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
The Machine Reboots after displaying Blue Screen With Error Message
Windows is entirely in control of any blue screens; so the hardware spec is not relevant yet.
can you try reading your windows event log immediately after a crash? :::Start>all programs>administrative tools>event viewer
you are looking for an error mentioning a filename... C:\windows\~somepath~\Minidump.dmp
If you get yourself a copy of WinDB (here: http://msdn.microsoft.com/en-us/windows/hardware/gg463009)
You can then open WinDB and open/read that crash dump file (file open crash dump), and it will provide you with a filename of the driver that caused a problem (possibly even tell you what it was doing when it was called).. chances are it's one of the following causing the problem: Graphics Card drivers Storage controller drivers Motherboard drivers (Power Management related issue usually)
If you have the latest driver; then get the hardware checked out...
May 17, 2011 | Intel D865GBF Intel 865G Socket 478 ATX...
I get error rtl100.bpl what must i do
hi
i am techbuddies from fixya group i would like to try and solve your issue .
please try to follow these steps
You probably read web pages written in a language that displays Right To Left
(hence rtl100) There are several reasons why that file might corrupt, an
add-on of some kind being the main suspect. Go to start/run, and type:
iexplore -extoff
to see it that stops the error.
If not, try refreshing all system files with :
sfc /scannow
if is doesnot work then try this
Are any devices malfunctioning? Select Start, All Programs, Accessories,
System Tools, System Information. Open Components under System Summary
and click on Problem Devices. Is anything listed there?
Are there any yellow question marks in Device Manager? Right click on
the My Computer icon on your Desktop and select Properties,
Hardware,Device Manager. If yes what is the Device Error code?
Does anything turn up in the Event Viewer Logs?
You can access Event Viewer by selecting Start, Control Panel,
Administrative Tools, and Event Viewer. When researching the meaning
of the error, information regarding Event ID, Source and Description
are important.
A tip for posting copies of Error Reports! Run Event Viewer and double
click on the error you want to copy. In the window, which appears is a
button resembling two pages. Click the button and close Event
Viewer.Now start your message (email) and do a paste into the body of
the message. Make sure this is the first paste after exiting from
Event Viewer.
if the same problem comes up please try to get in touch with me on my email or on fixya
thanks
techbuddies
Dec 30, 2009 | Dell Microsoft Windows XP Home Edition
Windows event log service wont start, error code 5
Your right its not a virus, and its not because your running one of the top anti- virus software,the problem is else where.
Have you checked the log files to see if you have permission?????
Have you checked event viewer to see if you have permission????
I need to know or the fix I have for you will not work.
Mar 13, 2009 | Dell Inspiron 530 Desktop Computer
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Problem Event Name: APPCRASH
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Sep 18, 2008 | Computers & Internet
Cosmi Print Perfect Platinum Logo
147 people viewed this question
Top Cosmi Computers & Internet Experts
Alun Cox
raysaw
Are you a Cosmi Computer and Internet Expert? Answer questions, earn points and help others
