Question about Yamaha HTR-5730 Receiver
Ultra viewsat didital satellite receiever vs2000
I was updating it then it froze. i turned it off and turned back on from the back. when it turns on it usually shows the word on then 0000. it did that for a bit. i searched for satellite signal and it showed none to all the satellite and it froze. i turned it off and turned it back on from the back then it turned on showed the numbers for a sec the it got stuck on the word on. it wont turn off or on with the remote unless i turn it back off from the back. i turned back on and did the same thing over again it got stuck on the word on and there is no pic
  • 214 Answers
Re: Ultra viewsat didital satellite receiever vs2000
You need to install a factory bin then new bin that should get you up and running hope i gave you a fixyaa thanks :)
Posted on May 13, 2009
0 characters
3 Points
My viewsat ultra 2000 receiver does not respond
You can give it a hard boot by switching the switch off for 3 sec then turn on.If that will not work installa factory bin and updated fix hope i fixya :)
Jan 09, 2009 | Yamaha HTR-5730 Receiver
I have a viewsat ultra. It will turn on.. but if I have the cable from sat in the back of the receiver,.. where it should be in sat in.. it wont turn on... but without my cable from the dish itself it will...
If you are using a switch between the viewsat and the LNB, remove it and connect the receiver again.
If that did not work, remove the cable from the LNB and power up again; if the receiver still unable to power up then you might have a short circuit in the cable itself or water might be entrapped inside the connectors on the LNB/switch connections.
Let me know if you need further assistance.
Jan 08, 2009 | Yamaha HTR-5730 Receiver
Viewsat receiver help
did yopu hook the wires up on the back right?Remove the wires and try turnning it on with no sat or wires hooked up if stilldoes that you will need a bringdead viewsat back to live file and try that way.hope i help :)
Oct 11, 2008 | Yamaha HTR-5730 Receiver
Viewsat ultra update doesn't help
You need to reaim your dish to echo 110 .You have it on bell and bell is down.Try reaim then factory set then rescan and make sure you have the right tp and freq settings freq is 12250 and tp is 12258 then autoscan exit when done and let it sit for 15 min on channel 500 cnn and it should work hope i gave you a fixya thanks :)
Oct 04, 2008 | Yamaha HTR-5730 Receiver
Viesat 2000 ultra
we have a viewsat ultra 2000 on feb 29 08 we turned the tv off and left the unit on when we turned the tv back on everything froze and the unit does not respond we tried the switch on the back it works for a moment then completly freezes any help is appreciated this machine is approx 4 mths old - from
Feb 28, 2008 | Yamaha HTR-5730 Receiver
4 lines on receiver of my viewsat ultra need help to fix it
my viewsat ultra display showing on & off dosen't stop
Feb 22, 2008 | Yamaha HTR-5730 Receiver
Viewsat ultra
Go HERE to get all the info you need.
Feb 20, 2008 | Yamaha HTR-5730 Receiver
Need step by step guidance to fix my viewsat ultra 2000
user guides fta files bin files and factory files are all free to download never pay for a fix! go to and join for free all the help u need is there ! if this helps please vote for me
Feb 08, 2008 | Yamaha HTR-5730 Receiver
Ultra viewsat didital satellite receiever vs2000 box
I Had a similar problem with an older Bell Expressview receiver(Canada). Tech support told me I had an old Smartcard which wouldn't allow it to synh with satelite. Instead of replacing the Smartcard, they exchanged the receiver.
Jan 09, 2008 | Yamaha HTR-5730 Receiver
Yamaha HTR-5730 Receiver Logo
Top Yamaha Audio & Video Receivers Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Are you a Yamaha Audio and Video Receiver Expert? Answer questions, earn points and help others
