Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 original partitions have been wiped .. Now need to reinstall xp . I can not. Selected boot device not available. can not do ctrl-f11 anymore of course btw just in case you were thinking about that. Wanted to dual boot with linux. Now stuck. Thanks for your help. javascript:;
  • 3 more comments
  • tech_gal822 Nov 14, 2009
    Hello, thanks for your response. I tried that before I posted unfortunately.
    "Insert the Windows XP Operating system Disk.
    Restart the computer and start Tapping the F12 key, It will give you the boot options.
    Select to boot from CD/DVD-Rom
    When prompted press any key to boot from CD-Rom
    Once the computer is booted from CD, follow the instructions to install the Operating system.
    Note: You can also go to BIOS (by pressing F2 or Delete) and change the boot device to CD-ROM"
    The CD is set as boot device
    error now reads with reinstallation Cd from dell in cdrom
    "Selected boot device not available
    Strike f1 to retry boot f2 for setup utility"
  • tech_gal822 Nov 15, 2009
    I am using two cd drives.
    -have you checked the OS disk on both the drives. Please confirm
    by os disk do you mean whether both are set to masters by jumper You want me to check manufacturers settings for both drives for jumpers to make sure?
    Oh yeah using one sata drive formatted ntfs
    OK checked and top cd was set at cable select - changed to master.
    removed other cd for now
    same error as before
    "Selected boot device not available Strike f1 to retry boot f2 for setup utility"
    Arrgh thanks for the help. I swopped out the drives again this time making the other drive the master and now it works!!
    The cd burner is now the master and the dvd drive is the slave... missed that.
    Thanks for walking me through!
  • 662 Answers
If you are getting message the message "selected boot device not available" that is because you have do not have a bootable HDD (Hard Disk). Please do the following:
Once you finish installing the Windows Operating system. You can go ahead with installation of your Linux Operating system. After you finish Installing Linux you will get the option in GRUB to select the Operating systems.
If you have already installed Linux and want to install the Windows, Follow the same procedure but it will directly boot Windows after you finish Installing Windows. You will have to write the GRUB again for your Linux system.
Please get back for any further assistance.
If you find this solution helpful, Please do not forget to rate it.
Thank you for choosing Fixya.
Posted on Nov 14, 2009
Testimonial: "Mahhek was right on the money. I knew i was missing a step and he confirmed. I may have forgotten to check something. Thanks man! "
  • Laxman Bisht
    Laxman Bisht Nov 14, 2009
    Thank you for your comments. In that case could you please confirm if you are using multiple drives. If you are using 2 CD/DVD drives, have you checked the OS disk on both the drives. Please confirm.
  • Laxman Bisht
    Laxman Bisht Nov 15, 2009
    Thank you for your comments and I am happy to hear that your issue is resolved. I appreciate your efforts.
How do I delete everything that is on my dell dimension 3000 and reinstall the original software that came with the computer?
First, you need to find the original installation disks that came with your computer. There's a Dell System Recovery disk that will wipe your computer and reinstall everything as if it had just come from the factory. Insert the Recovery CD, restart your computer, and press F11 or F12 to access the boot menu. When you get the boot menu, select the CD/DVD ROM drive as your boot device. This will lead you through the re-install process.
Mar 04, 2010 | Dell Dimension 3000 PC Desktop
My Dell dimension 5100 on switch will blink yellow but will not boot up (on). When it did work, the switch would change to green.
boot files are corrupt or missing....
only repair of OS will rectify...
else
u need to reinstall OS...if
u have more then one logical partitions i.e. C:, D:, D: drive etc in ur HD then u can install one more copy of OS in either D: or E: and then when computer starts/boots u can chose from the multiple OS windows install to boot from.
Jan 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 computer with error
There are two ways,
1, If you still can access Windows, try to disable any backup programs, virus scanning programs or disk defragment tools. Try also to run a hardware diagnostics tool to detect any errors your hard drive might have. And run chkdsk /r to detect and repair any file system structural damage.
2, If you are unable to load Windows. Then you should try to access your ntfs partitions by making a ntfs boot disk with NTFS4DOS (freeware). You can download it from http://www.geekswhoknow.com/files/ntfsinst.exe You will need a floppy disk.
After you load the bootable floppy disk onto your damaged system, select either option one (1) or option three (3). If you selected option one (1), type chkdsk /r at the command prompt, and your problem should go away after the disk has been repaired.
Note! Unfortunately there is a chance that your partition is corrupt beyond repair and all of your data is lost. In that case, you need to reformat the partition to be able to use it again.
Additional information can be found at http://support.microsoft.com/default.aspx?scid=kb;en-us;Q228888
Nov 08, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Having Trouble Reinstalling XP on my Dell Dimension 3000
Here's what I would do. Download and burn any Linux disk. Install Linux and delete all partitions while doing so. After that, initiate the Windows XP installation and see if that works.
This will take care of two things:
If you can install Linux, then the hard drive is good and the partition that was previously on there will be deleted (I suspect the partition is locked which can be caused by a virus or the software used to scrub hard drive).
Check your CDs for Windows (for scratches) or it could be your actual CD drive is out (laser) which would make the installation fail. If the CDrom cannot read the disk, it locks up like that during installation...even if it read before.
Sep 22, 2009 | Dell Dimension 3000 PC Desktop
Windows XP freezes up when trying to reinstall on my Dell
You need to copy the restore partitions to a cd for back up.the wipe the drive using drivescrubber.also have a start up disc for back up.wiping the drive from back to front should keep the basic files for dos.its easy and there is a free version.
Sep 20, 2009 | Dell Dimension 3000® Pentium® 4...
Selected boot device is not available
I had the same issue with my dell dimension 2400. The issue I was having resulted in the connection to the drive was loose. Try taking off the side of the case, find the drives in question and reseating the plugins. My pc was quite a bit older though and i don't know if this will be your solution, but its worth a shot. You can even try installing a different cable and swapping to another power supply plug.
Aug 10, 2009 | Dell Dimension 8400 PC Desktop
How do I return our Dimension 5100 Dell Desktop back to it's original state? Lost the recovery CD.
Have you tried restoring your operating system to a previous restore point?
To do this click on start- all programs - accessories - system tools - system restore. Then choose a date from the calendar which corresponds to a time before you began to experience problems on your PC. Follow the on-screen instructions to restore your PC to its original state.
Note that a system restore will remove any programs which were installed AFTER the selected restore point date.
Hope this helps.
Regards,
Graemevm
Apr 19, 2009 | Dell Dimension 3100 PC Desktop
I need to reinstall window xp pro on my dell dimension 2400-
If you don't need any files currently on the computer, boot from your Windows XP disc, have it delete the current partition and then format the new partition, and install windows XP.
Note: this will delete anything you currently have on the computer at this time!
Mar 22, 2009 | Dell Dimension 2400 PC Desktop
Wiped HD
If the CNTL+F11 keystroke is not available at boot (Blue bar at top of screen immediately after Dell Splash Screen) then you cannot run PC Restore on that system and will need to reinstall Windows Manually.by booting to the WIndows XP CD
Jan 26, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
377 people viewed this question
Alun Cox
