Question about Apple iPod touch
What do i do when i open an application and it closes immediately?
  • 749 Answers
Hi this will most likely be a compatibility issue, simple uninstall it and reinstall it, there could be a possible malfunction, if its a preinstalled application then try to preform a hard reset.
Hope this helps
Muzzi_123
Posted on Nov 14, 2009
This message displays any time i try to access the camera. "could not start the camera. close other applications and try opening the camera again". please help.
This is what you should do, press and hold the menu key.. you'll get a display in a rectangular form with all programs that are currently running on your blackberry.
You can scroll through the open applications and for you to close all running applications, you'll have to click on your trick ball to get you to that open application and then you close it.
Go over the process of holding the menu key for about 10 seconds again until the rectangular window opens with applications that are currently open.
Click on another program and close it.... do this for all the applications until your have about 4 applications running. Once it's reduced to this you would be able run your camera.
Regards
Apr 08, 2010 | RIM BlackBerry Bold 9000 Smartphone
Tip
How to find out what process a program uses
1) So the fist thing you do is open the program that you want to find out about. As an examlpe I will open Microsoft's calculator from Start Menu -> Accessories as shown in the image below.
2) Next you will need to open the Task Manager by pressing Ctrl + Alt + Del. NB: You must have all three keys pressed down at once starting with Ctrl then Alt and lastly the Delete key.
3) Now the Task manager should appear. As you can see there are many tabs here such as Applications (which displays the applications running), Processors (which displays the processors the running applications are currently using), Performance (which displays what percentage of your processor is in use as well as how much RAM is still available), Networking (which displays the load on the Local Area Network; and Users (which displays how many and which user accounts are active at the present time).
4) Now on the Task Manager under the Applications tab right click on the program and click Go To Process at the bottom of the pop up menu.
5)This will then take you to the process that the program uses. In this case with Microsoft's calculator we see it takes us to a process called calc.exe, this is the calculators executable file (the file that makes it start up and run). Ending this process will immediately close the calculator application.
EXTRA: This tip is useful when your system crashes or freezes after you end a task with the Task Manager. Simply find the process of the application that is not responding under processes and right click it then choose end process. This will immediately bring your pc back from the frozen state.
on Jan 22, 2011 | Computers & Internet
Tip
Close Application at Once
When you're done working on your computer for the day, you probably close each open application one-by-one. If so, chances are that you've wished that you could close all you open applications at the same time
To do so, hold down the [Ctrl] key and click on each application button on your taskbar. When you do, you'll notice that each button remains selected. Once you've selected all the application buttons on the taskbar, right-click on any one of them and select the Close Group command from the shortcut menu. When you do, all your applications will close. If you have any application in which an open file hasn't yet been saved, that application will prompt you to save the file.
on Apr 25, 2010 | Microsoft Windows Server 2003 Enterprise...
Applications that i added open then close immediately. I downloaded applications both from the computer and from the itouch itself, restarting, and resetting. Very Frustrating!
When an app closes immediately this is known as the app "crashing." The first thing you should do is make sure that your itouch has the latest software update available. This can be done by hooking the unit up to itunes, and clicking the update button. Also try restoring the unit with itunes. You will lose all of the data on the itouch, so make sure you have all your data backed up with itunes. If you have any further questions feel free to contact www.wiredextreme.com.
Nov 18, 2009 | Apple iPod touch
My applications on my ipod touch won't open. How do I fix it?
my ipod touch is disabled,wrong passcode,help me to enable it
Jul 28, 2009 | Apple iPod touch
Text will not send
Sorry about the prompt on your phone, please follow the the simple steps I'll outline to close the open applications on your phone.
Step 1. Press and hold the "Home Key", you would have the open applications show up on the left corner of your screen. Scroll to 1st application you wish to close, and then ok it. Once you do this you would be in that application that is open.
Step 2. when trying to close the application that you are in right now, select on the options on the bottom left of your screen and ok exit. Once you do this that application is closed.
Step 3. repeat the process on Step 1 & Step 2 until you have just one application running on your e71, which is the "home screen".
Hope this helped, please specify if it did.
kind Regards
Jul 25, 2009 | Nokia E71 Smartphone
App close immediately after i open them
I know It Seems Stupid...You simply got 2 download an other application and all of them will work. I sware =)♥ Good Luck ans Have A Good Day .
Jul 05, 2009 | Apple iPod touch
What's wrong with my ez connect?
If you mean the connection manager application that came with the ezconnect adapter opens and then shuts down immediately, that's usually what happens when it doesn't see the adapter. Application says "no adapter present" and closes. You say you're trying to use the ezconnect software with a linksys card, so that's probably the cause. Try downloading the linksys driver software from their site
Dec 04, 2008 | SMC EZ Connect SMC2635W 802.11b Wireless...
Apple iPod touch Logo
52 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
