Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How 2 unlock c 0500
How 2 unlock konica c 350 c 0500 service code
  • Konica Minolta Expert
  • 158 Answers
On a c350:
1.leave the machine on and open the front door
2. locate a small rectangular hole inside the front dooron the bottom right side corner
3. insert a small object such as a small ball point pen to actuate a switch that resets the error code the screen will indicate door open when the error is reset.this is a fuser error code so if the error keeps coming back the fuser will have to be replaced
Posted on Nov 16, 2009
    New Friend:
Como hago para cambiar el fusor de la impresora KONICA MINOLTA magicolor 1690MF
Posted on Apr 02, 2016
Why am i still getting error code 0500 i bought a new fuser unit.
You need to reset the machine, the new fuser does not reset the machine.
May 03, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Konika minolta 1690mf displaying CAUTION machine trouble service call(0500)
hold down the stop button and power on, if the code come back get a new fuser unit
Apr 23, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Trouble shoot konica minolta error code 0500
need to know model number
most konica minolta 0500 codes is fuser related and a tech has to reset it
Aug 22, 2013 | Konica Minolta bizhub Office Equipment &...
(C-0500) error code konica di 470
There is a trouble rest button inside the front door above the fuser unit. There is a small panel with one screw in it, remove the cover and you will see a PCB with two black switch's on it. One is the trouble rest button, have the copier ON and press the trouble rest button and close the door and you are done... If it will not rest, check what you did and make sure it is put back correctly.
May 06, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Printer (bizhub 350) keeps saying malfunction detected. shows code c-0500. what can i do?
The C0500 code means that the fusing unit is not heating up properly. The fusing unit is the part that gets hot and "fuses" the toner onto the paper. You are going to need to have a technician come out and diagnose the problem for you. Most common failure in the fusing unit is a blown thermal fuse. Next most common is a bad thermister, which is the part in the fuser that monitors or "reads" the fuser tempurature. Although rare you could also have a bad heater lamp. Removing the fusing unit and diagnosing which part is bad is not something I would recommend for anyone other than a trained service technician. At least you know what the cause is so you do not have to worry about getting mis-information from the service person. Such as if they say you need a new fusing unit. You just need the defective part replaced, NOT the whole unit.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
On the display is message: mashine truoble service call 0500
Turn ON the Power Switch with the Stop key held down. it resets the error error its self means :
Warm-up failure
Oct 10, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error code C-0500
On the control panel, Check the right side of the panel if there a hole, and press it w/ a paper clip, it will reset the code, if not. It need a new fuser unit
Apr 28, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Need to reset admin code for konica minolta c-350
Hello
press utility/counter - then under the counter "details" - stop 0 0 stop 01 - now you are in service mode, - stop 0 C, and there shold be admin pwd
Oct 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica C350
should mean that fuser temp too low or high, try reboot. If just reboot wount help, hold down utility or stop key, then you should be abel to do trouble reset.
Nov 15, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
560 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
