Question about Siemens Gigaset S440 Cordless Phone
Phone will not register with base
I cant get the handset to register with base auto register or manual will not suceed
  • 577 Answers
Would you try this procedure:-
First on the base station..press and hold paging/register key for 3 seconds
Than on the hand unit select function key and open "MENU"
select "SETTING" from menu and confirm (Ok)
Selecect "HANDSET" and confirm
Than select" REGISTER" and confirm
than enter "0000" as pin and confirm..
it will flash and it detects the base.
Take care..
Posted on Jul 09, 2010
How to register 2 Bell Cordless handsets on 2 bases?
Multiple handsets registered to one base works well.
The extra base can be used as a remote charging
dock without registering a handset.
Trying to register a handset to two bases is neither
possible nor useful.
OTOH, the specific model number was
not given. While I have never heard of
registering a handset to more than one base,
nor made it happen by accident, maybe we
all do "...learn something new everyday...".
What is the specific model number, and the
date of manufacture ? Thanks! a r t
May 17, 2016 | Bell Lands Phones
How do I register new handset for AT&T cordless phone el51359
1. To de-register the orphaned handsets from their old base:
When the orphaned handset says "Connecting..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Dec 30, 2015 | AT&T Lands Phones
I cant dial out it says register HS i am not familiar with the procedure.
When you reset a handset (or if you buy a new one1, that handset displays a Handset Not Registered message. If you see this message on a handset, you need to register it to a base before you can use it.
Registering a handset
Does the handset fit in the base cradle?
Yes
No
Place the handset in the base.
The display should say Handset Registering.
1. On the base, open the menu and select Register Handset. The display should say Handset Registering.
2. On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
In about 30 seconds, the handset display should say Registration Complete. Press TALK ( )/FLASh and make sure you get a dial tone. page29image32024
27
If...
Try...
- you don't hear a dial tone- the display says Registration Failed
Making sure the handset is fully charged, then start over at step 1.
To register a handset to a different base, see the section "Expanding Your phone" in the user's guide for the other base.
Mar 18, 2014 | Uniden DECT 6.0 Cordless Phone ID
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
Jul 26, 2011 | Uniden D16602 Twin Cordless Phone
I am trying to replace a handeset on my E5640 answering system. I have followed the procedures to deregister the existing handsets but it will not accept the base code for the last one. The handset I am...
  • Your telephone can accommodate up to four cordless handsets. You can add new handsets (Model E560-2, sold separately) at any time, but each must be registered with the base before use.
  • The handset provided with your telephone is automatically registered as Handset 1.
  • Additional handsets will be assigned numbers in the order they are registered (2, 3 or 4). You can register a maximum of four handsets.
To de-register all handsets
• Unplug the power supply from the base unit.
• Remove all handsets from the charge cradles and base.
• Plug in the power supply while pressing and holding the HANDSET LOCATOR button.
• Continue pressing HANDSET LOCATOR until the IN USE and CHARGING indicators are lit (this could take up to 10 seconds).
• Release the HANDSET LOCATOR button.
• All handsets will display: ENTER BASE ID: XXXXXXXXXX
Once the base indicators turn off (up to 30 seconds), the handsets have been de-registered from the base, and can now be re-registered.
To re-register a handset:
• Make sure your handset batteries are properly installed and charged.
• Your handset will display "ENTER BASE ID".
• Enter the 15-digit Base ID number from the bottom of the base unit.
• Press SELECT to accept the new code and complete re-registration.
To re-register a handset to a new base unit:
• Unplug the old base unit. Your handset will display "SEARCHING...".
• Install the new base unit by plugging it into an electrical outlet and phone jack.
• Press and hold the SELECT key until the handset displays "ENTER BASE ID".
• Enter the new 15-digit Base ID number from the bottom of the new base unit.
• Press SELECT to accept the new code and complete re-registration. The handset is now registered to the new base.
Jun 25, 2011 | AT&T E5640 Phone
I had to purchase a new AT&T cordless phone system since my last set was destroyed by lightening. My old system was CL82409 and my new system is CL82209. I have 3 expandable handsets from the old...
According to the manual starting on page 52, you need to de-register all handsets then re-register the handsets one at a time. The manual covers both cordless model numbers so the handsets should be interchangeable. I have included a link where you can download the manual if you need it.
http://att.vtp-media.com/ecp/documents/product_Product/127/UserManual/1082/cl82209_manual_i3.pdf
Mar 27, 2011 | AT&T Lands Phones
The phone says no phone line, and i dont have a dial tone. cant call out and cant get calls coming in
Model LS6305: How to register a handset:
  1. Place the non-registered handset in the telephone base or charger. If 1.Press FIND HS on base 4sec and 2.Then press # on handset do not appear alternately on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds until the red IN USE light on the telephone base turns on.
  3. Remove the handset from the telephone base or charger and then press # (pound key). It displays Registering...Please wait. It takes about 60 seconds to complete the registration. The handset displays Handset X Registered and you hear a beep when the registration process completes.
  • If the registration fails, the handset displays Registration failed for a few seconds, then 1.Press FIND HS on base 4sec and 2.Then press # on handset alternately. To reset the handset, remove it from the telephone base or charger and place it back in. Try the registration process again.
Model ip8300: How to register a handset:
  1. Press and hold FIND HANDSET for at least 10 seconds on the telephone base. The VMWI and LINE IN USE lights will blink alternately indicating that the telephone base is in registration mode.
  2. To display the telephone feature menu, press the Menu softkey from the main idle screen.
  3. Press the up, down, left and/or right NavKeys to choose Registration Settings then press the Select softkey or center NavKey/SEL.
  4. Press the up or down NavKey to choose Handset Settings then press the Select softkey or center NavKey/SEL.
  5. Press the up or down NavKey to choose Register to Base then press the Select softkey or center NavKey/SEL. A list of locations for assigning telephone bases will be displayed.
  6. Press the up or down NavKey to choose an empty location and press the Register softkey or center NavKey/SEL.
  7. The handset will display Searching while it searches for the telephone base. If the search is successful, a code from the telephone base will be displayed. To register the handset to the telephone base, press the Register softkey.
  8. In the Enter PIN box, enter the system PIN. The default PIN is 0000. Press the Apply softkey.
  9. Handset registered will be displayed when the registration process is complete. The screen will return to the registration settings menu. Press OFF to return to the idle screen.
Model ip8301: How to register a handset:
  • Before registering the handset with the base station, press the FIND HANDSET button in the base till the VMWI and LINE IN USE lights blink alternatively. When the lights start blinking, register the handset. The default PIN for registering the handset with the base station is 0000.
  1. Press Softkey Menu from Home screen
  2. Choose the Settings icon from Menu screen and press center Navigation key/SEL to display the settings menu options.
  3. Press the up or down Navigation Key to choose the Registration Settings menu option and press the center Navigation key/SEL to select.
  4. Press the up or down Navigation Key to choose the Handset Settings and press the softkey Select to select.
  5. Press the up or down Navigation Key to choose the Register to Base and press the softkey Select to display a list of available base stations. Choose a base station from the list and press the softkey Select to select.
  6. The handset will search for the Base within its range. During this time, the searching screen will be displayed.
  7. If the search is successful, the Base station number of the base will be displayed.
  8. Press softkey Register. Enter the PIN and press softkey Apply to save and subscribe to the base station.
  9. To cancel the entire operation, press OFF key anytime.
Mar 07, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Bought a spare 3111 handset and cant connect it to my base. it looks as if it was connected to another base at one time. screen just says "connecting..." and there is nothing I can do to clear...
The handset must be registered to the base unit if the system has multiple handset ability, the manual will tell how to register the handset. If the system is a two handset system then only two handsets can be registered.
Dec 08, 2010 | Vtech Cordless 6041 Phone
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
Siemens Gigaset S440 Cordless Phone Logo
574 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
