Question about Maytag Neptune MAH5500B Front Load Washer
NeptuneMAH5500B error codeFL, door won't lock, help!
    Scholar:
  • 124 Answers
Oven door won't lock, self clean won't start
this is a door lock error , you will need to replace
Feb 20, 2013 | Kitchen Ranges
Washer error code dlf
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Dec 01, 2011 | Kenmore Elite 45986 Front Load Washer
F9 error
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 30, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
I have a Maytag range that is displaying F9. The oven door is locked as well as the cook top that allows finding the model number. Please help if you can. I appreciate it so much.
Hi
Daniel
Aug 07, 2011 | Maytag Ovens
Door locked, won't turn on. won't reset by pressing pause/start/power or unplugging washer.
Remove the bottom panel which would give you access to the pump area if you look up along the side that the door lock is on you will see a cord with a loop on it pull this cord and the door would open. The panel must be removed in order to locate this pull cord. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
p.s if after you open the door and you were to leave the unit unplugged for 7 minutes if the error did not go away or if the door once again locked up you would have no choice but to replace the door lock assembly on the unit Thanks again Rick
Jul 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi! My LG washing machine is showing a "de" error code. It won't allow water into the drum. Please help
Hi, the error code "dE" signifies a door open error. This may simply be because the door is not all the way closed. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it, though it could also represent a number of other problems. There may be a faulty door switch, a malfunctioning electrical connection or a damaged gasket.
Jun 24, 2011 | Kitchen Ranges
Kenmore smartwash error code dl and f? Won't start.
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the problem is solved. Please get back to me if you have any other questions.
Kevin
May 26, 2011 | Washing Machines
Door lock
dl meand door lock. A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error. Potential Causes ? Door Lock Mechanism broken or removed from the Door ? Check Door Lock/Switch Assembly ? Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) ? Door Lock/Switch Assembly Failure Replace failed component.
Sep 22, 2007 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
182 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
