Question about Hotpoint HSS25GFP Side by Side Refrigerator
We cleaned out fridge inside and out put in baking soda and coffee turned it off let it sit and we still have a smell in it whats the problem
    President:
  • 2,702 Answers
Its that darn coffee you put ith the baking soda causing the smell,wash it out again only this time only use the baking soda by itself,,, NO COFFEE!
and leave the door open for it to dry out, that should sort out the smell,,,,why did you use coffee with baking soda???? it causes it to smell bad?
Posted on Nov 14, 2009
A smell in my refrigerator
Behind the plastic inner panels of the refrigerator are sheets of insulation.
Some are fibreglas blankets, some are styrofoam sheets.
In any regards, these insulators have absorbed that smell, and here are a few ways you might be able to get the smell out.
1) Take the refrigerator outside and sit it in the sun for several weeks, NO rain, just sunshine.
2) Buy half a dozen boxes of Baking soda, and sprinkle that liberally inside and leave it sit for a week, then replace the baking soda, and do it again. Like 5 times, a week at a time.
3) There are air freshener machines, like Eco-Quest, that can be put inside the refrigerator and run in there ( with the door open).
We have used these in closed spaces and they work. (Inside a car or truck, in a closet, etc)
God bless your efforts.
Dec 15, 2015 | Samsung RB195ACPN
Refrigerator smells like fish
Put a couple of boxes of baking soda in the fridge to absorb the smell.
Apr 18, 2017 | Thermador Refrigerators
My fridge smells fishy. It is perfectly clean and i have not had fish in there.
Bacteria will cause the smell. Make sure it is cold and put a box of baking soda open inside the fridge. It will absorb the odors. They sell baking soda with a mesh side specifically for your fridge.
Jun 06, 2011 | Samsung RS2530BSH (25 cu ft) Side by Side...
Problem is rotten smell inside GE profile fridge. I've checked for rotten food-none; taken everything out and cleaned inside plus all shelves with added bleach in water. Smell is still there. I...
Hi, pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. You can also mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section. Too much bleach and the smell of bleach would be circulated by the fan to the room, so be sure to add water. Finally, another popular methods of removing fridge odor include washing the entire fridge out with a vinegar and water solution, placing fresh coffee grinds or boxes of baking soda on each shelf and even using trays of cat litter.
May 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Fishy smell in camper fridge
They freon used is mainly amonia,best thing to use is bleach put in spray bottle mix 70 percent water and 30 percent bleach squirt entire fridge let soak then wipe clean let air out as much as possible!!!! :)
Jul 19, 2009 | Zanussi ZEBF277W Bottom Freezer...
Terrible odor! Washed inside & still stinks! NOW what?
try coffee grounds in it. take and put it inside and leave it in for a while. also have you cleaned out the drain pan yet?
Mar 26, 2009 | Sub-Zero 632 / S
Odor in GE side by side Fridge
Sounds like mold.  I'd try Lysol or one of the other products that claims to treat the odor cause in the air.  Spray a quantity into the empty fridge and freezer and turn it on.  Let the fans spread the stuff around. Try to find the internal vents which seem to pull air into the coils to spray into.
Nov 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Bad Smell in Fridge
To remove odors:
1. Remove all items from refrigerator or freezer. Throw
out any spoiled foods. Take out removable parts and wash
them and door gasket with mild detergent in warm water.
Rinse well and wipe dry.
2. Wash interior walls and door liner with solution of 1-2
tablespoonsful of baking soda to 1 quart warm water, and
wipe dry. Leave door open and let it air out well, with a
fan directed toward inside, and opened windows if climate
permits.
3. If odor still remains, try one or all of the following
means of odor removal.
a. Spread baking soda out on shallow pans (like shallow
glass casseroles, pie plates, or jelly roll pans lined
with foil) and put pans on shelves to absorb odors, or on
the bottom and in baskets of chest freezer. Leave open
and unplugged.
b. Buy activated charcoal (which is specially treated to
remove odor molecules from air) at some department store
housewares sections, appliance store, or pet shop. Spread
out on shallow pans and put on shelves of refrigerator.
Turn refrigerator on low setting and run empty a few days
so odors will be absorbed.
c. Spread cat litter in shallow pan in cabinet, turn on
and run empty a few days. If odor is disappearing but is
not all gone, replace old litter with fresh litter.
d. Pour several ounces imitation vanilla (not pure
extract) in a shallow saucer, put on shelf and let run
empty a few days.
e. Put fresh ground coffee in cereal bowls inside the
refrigerator and let run empty several days. A slight
coffee odor may remain, but will disappear after washing
again with baking soda solution.
f. Pack each refrigerator shelf with crumpled newspaper.
Set a cup of water on the top shelf or sprinkle the
newspaper lightly with water. Allow refrigerator to run
for approximately 5-6 days. This method takes a bit longer
but has been effective in removal of strong odors.
g. Buy a commercial odor remover, and follow instructions
exactly. Several companies manufacture a liquid
concentrate which sells for about $3.00 for 1/4 to 1/2
ounce. A couple drops are put on a piece of cotton and
placed in the area to absorb odors, in the cabinet or
in a room.
Three of many brand names are: "Odor-Away" by Wrap-on
Co., available at hardware and hospital supply stores,
"SuperCD" IBL Household Products by Crackerbarrel Sales,
Avenal, New Jersey, available in pet supply department
or special products in grocery, or "Clean-Air" at some
appliance repair shops.
Hospital supply stores carry Dow Chemical Hospital
Disinfectant and Deodorant Spray. Spray into cabinet and
quickly shut the door. Repeat.
4. If none of these methods removes all the odor, then it
has probably penetrated into insulation. Contact an
appliance service company for an estimate on cost of
removing the liner and replacing the insulation. If cost
is too high you may prefer to get a new appliance. It
could be used for occasional cooling of soda pop where
the odor will not get into the beverage.
Smelly Fridge
Try putting an open can or two of coffee inside. My mother's freezer had gotten unpluged and it was full of fish. She put cans of coffee inside and shut the door a couple of days later she took them out and the freezer did not stink anymore. Hope it works for you.
May 05, 2007 | GE GSS25JEMWW Side by Side
Hotpoint HSS25GFP Side by Side Refrigerator Logo
412 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
