Question about Dell 1320c Laser Printer
Our 1320c prints 3 copies only,Any thoughts why?
Our 1320c prints 3 copies only,any ideas why?
Check the paper format of the program and the paper format of the printer.
If there is a mismatch only 3 pages come out.
Solution: the paper size should be matched other wise the printer gets confused.
Best regards,
Walter Spierings
Posted on Nov 15, 2009
    Master:
  • Dell Master
  • 956 Answers
When you click to print, menu drop down, click print you then should get the prefences and panels to alter copies number of etc? Alter to the number you require.
If this fails to alter the number printed, you need to reload printer setup disc/ it may give you thechoice to repair. up to you, usually quicker to uninstall with dvd/restart/then reload.
Posted on Nov 14, 2009
Cannot print to Dell 1320c printer
check printers on computer select your printer as default
May 02, 2016 | Dell 1320c Laser Printer
Dell 1320c printer is squeaking when printing
Hi, my Dell 1320C has started making a squeeking noise when it prints. It's like some rolling parts need oiling. Any suggestions?
Feb 28, 2012 | Dell 1320c Laser Printer
My printer prints multiple pages even though number of copies in setting shows 1
Try looking here: open your printers fax folder. Your printer should be listed here, right click on it and select properties. Now click on the advance tab. There should be a printer defaults button, click on it. Make sure your copies number is set to 1. Then click ok on each window and close.
Hope this helps
Feb 13, 2012 | Dell 1320c Laser Printer
Dell 1320c is giving faded printing in both color and black. I've replaced two toner cartridges, tried to 'bleed' the cartirdge by printing 20 copies, toner save is turned off and there is no...
After you click print, and just before you print, go to your 'printing preferences' or 'print settings' in the popup window. From there, cycle through the tabs, and ensure that 'print quality' is NOT at draft and IS on normal or high quality. Alternatively, you change the 'print resolution' in this window, if the option is available. Resolution is usually given in 'dpi' so choose the highest 'dpi' value. This should hopefully give you darker prints
Aug 26, 2011 | Dell 1320c Laser Printer
Dell 1320c print spool issues
Today I installed my new printer Dell Color Laser Printer 1320c. I cannot print as documents sent to spooler. I tried reinstalling. o good. I disabled spooler...no good. I'm a technophobic with little spare time, running own business and cannot print the documentation I need. Any help out there?
Jul 02, 2011 | Dell 1320c Laser Printer
My Dell 1320c Colour Laser Printer prints black as grey. How can I get it to print black?
If you have an extra black toner cartridge, try installing that and see if it fixes the problem. If it doesn't make sure Toner Save Mode is off (in the print driver, under Preferences). If your copies still come out gray instead of black, you may need to replace the Print Head Unit (PHD).
Feb 21, 2011 | Dell 1320c Laser Printer
The black prints light grey. It has new toner
Printing - Light - After - replacing - toner
Bleed the cartridge- yes bleed it, if the black is grey, print lots of BLACK, in 'greyscale' like pages of it, probably 20, I had a customer with the same problem, I am and experienced tech and I own a shop, Dell couldnt help, Dell didnt know, I figured it out by looking at the way the printer works. Enough said.
* I am a HP person* ( as far printing goes )
Personaly HP is the best, anybody, and I mean ANYBODY who builds a printer that is NETWORK capable, Puts network interface in it that is a 'dummy' interface that you can actually plug a network cable into and it lights up.... then you figure out the interface you are trying to use is dead!!, How bout a laser printer that doesnt support PCL.... they say it does..... it may 'emulate' PCL.... probably does.... but the drivers will not print DOS apps correctly.... DOS may be dead,,, but there are SOME companys still using DOS based programs..... Dataflex is one..... I am not trying to write a review, my opinion, Dell 1320c is junk.... junk..... it is the cheapest of cheapest, in design, print quality, anything..... I have 4 Dell 1320c's that i am dealing with at the moment, at 3 different companies .... I am pulling out my hair with failed print jobs, (usb) of course, are they worth buying the network interface to make them network printers???? (get away from usb connectivity issues)--- no they are not, my accounts with HP's.... no problems!!! ---- none --- actually so good, we 're-geared' a HP, total cost---- more than it was new,, more than the Dell 1320c...... BUT KEEPING THE HP is what I and the customer knew to do.... when you wear the gears out in a printer and the only thing you put into it was toner's and two drums... during it lifespan... You bet your britches thats the printer to keep.... ('twas hp4100 n)..... HP 3600n is my choice for a Dell 1320c replacement,, Ummm yea... the 3600n uses toner cartridges that are NOT remote tanks..... they are integral.
Dan Antos
www.djantoscomputershop.com
Apr 30, 2009 | Dell 1320c Laser Printer
Dell 1320C
On page 30 of the 1320c manual it says this signifies the coming end of the PHD (print head device). I cannot find a part number or reference to the PHD on the Dell web site pages connected with this printer
Jan 30, 2009 | Dell 1320c Laser Printer
Dell 1320c Laser Printer Logo
239 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
