Winsource Tech Solutions TS-4500 Cross-Cut Shredder. Price Shown Reflects Instant Savings.
Problem for Winsource Tech Solutions TS-4500 Cross-Cut Shredder. Price...
Fellowes paper shredder
By junv on Jan 08, 2008
shredder run only on reverse mode, i replaced the sensor still not working
Clarification Request
Posted by fellowesrep on Mar 02, 2008
you have listed as Tech solutions Shredder and as Fellowes paper shredder please give manufacturer and model info before I can comment for sure
Best Solution
posted on Mar 02, 2008
Very Helpful)
fellowesrep
Rank: Guru
Rating: 87%, 144 votes
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol.
If neither of these help your paper feed sensor or your pc board has gone bad and you will have to contact your manufacturer for further parts availability.
Was this helpful?
Yes
No
Popular Solutions for Winsource Tech Solutions
Questions and Unsolved Problems for Winsource Tech Solutions
Do you recommend Winsource Tech Solutions TS-4500 Cross-Cut Shredder. Price Shown Reflects Instant Savings.?
Answer
Answer
On our AMS-500, the Comber spacers are worn out. Should I replace these alone or should replace... (More)
Answer
Machine will not run without this part. Plastic tab on end broke off. Want to replace it.
Answer
Have "Techsolutions TS4500 Paper Shredder" Power on, Green light On. safety switch... (More)
Answer
I am getting trouble with deep freeze software which restores system whenever i switch off how to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Shredders Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
