Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher paykel drawer dishwasher is stuck open and will not close
Hey I dont know if you have this problem, but with mine the gasket seemed to be blocking the opening, so you could close it, but you had to shove a lot. The FP help line said to just unplug and replug in the unit. I did it and lo and behold it worked fine again. It did seem to leak a little bit the first time I reran it, but that seems to have gone away. Hope this helps
Posted on Dec 31, 2009
  • Kym068mac Mar 29, 2011
    Thanks for taking the time to post this, turning it off and on worked for me too. I thought I was up for a new dishwasher.
  • sydharpUK May 20, 2011
    Brilliant. Worked like a charm!
  • Fisher and P... Master
  • 3,247 Answers
If the key/ lock symbol is showing in the display, then it is possible you have the child lock on. Disable it by pressing the key/ lock button on the panel. Check your owners manual for the correct procedure for your model.
If this is not the case, then it is likely the drawer has come off the rails and is not able to slide right back. You will need to open the drawer and slides and refit. Unless you are technically savy you will have to contact a technician.
Posted on Dec 13, 2009
Lid(s) out of sequence
remove power.
do not force drawer ( or lip seal damage will occur)
remove drawer.
check/ensure lid(s) is against left and right, fwd and aft up stops.
if not, unclip rotary actuator at nylon frame pivot (left and right)
extend each actuators by backdriving ram (ccw) by hand (twist) so that frame will hit stop tabs.
reclip actuators to nylon frames.
drawer should glide in/out smoothly with little effort
repower unit with drawers closed
select a wash cycle and pause cycle before opening drawer (shud reset sequencing)
Posted on Jan 03, 2010
Opened the drawer while it was running now the drawer will not close
Turn off the mains power and back on and see if there is any change.
The drawer lid is stuck in close position when you opened the drawer. Try to select another program on the panel and see if it clears the stuck lid.
Jan 18, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel drawer stuck closed how to fix.
Turn the mains power off and force pull the drawer slowly.. No jerky movements. The lid seal is stuck. Once open, check for any damage to lid seal by running fingers on the underside of the top of cabinet where the drawer slides in. Turn mains power back on. If the drawer does not slide back in then it is likely the lid seal actuator motor is stuck or power to motor has failed. Will need technician involvement to fix. If lid seal looks torn then it will need to be replace. Can cause leaks and further faults otherwise.
Apr 09, 2013 | Fisher and Paykel 24 in. DS603H I Built-In...
Dishwasher lid stuck
the lids on dishdrawers are pulled down and sealed by lid activaters. there r two types, the screw type and the magnetic solonoid type. the reason your draw gets stuck is your lid activator is not releasing. there are 2 reasons for this 1st- 1 or both activators are faulty. 2nd the lid activator control board is faulty, which is located under the bottom drawer.pull the draw out and see if u can see if the lid is down on 1 side or both sides.please reply 4 more help.
May 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
Nov 25, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
The top drawer of my Fisher Paykel two drawer dishwasher will not close all the way. Something appears to be stopping it. How do I fix it?
To find out what might be blocking it, you can remove the drawer. There are two tabs one on each side of the drawer near the bottom front. Push those in and pull the drawer out. You can lift the drawer up and push the slides in to get them out of the way. Then you should be able to see into the cabinet and what if anything is stuck behind the drawer
Apr 22, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Nov 24, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher-paykel dd203 started filling with water with drawer open
what you can do is take a baster and empty out the water; then check and see if anything is at the bottom of the machine inside meaning under the thing that twirles and anything that is long put on top rack.Because you can something that is stuck or gunk that is blocking the way
Oct 23, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & paykel top drawer stuck again
Sounds like the lid is not opening all the way. Rubber may be coming off lid seal during opening and closing. Check you lid actuators replace both right and left if needed.
May 15, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher Paykel Dishwasher Door Open error code
If it is a dish drawer type there is a clip at the rear of the drawer that holds the drawer closed. you will need to withdraw the drawer partially to look in. with the drawer open the fingers should be facing towards you. If not you will need to reach in and pull the top of the fingers towards the front. there is a replacement arm that holds the pipes and cables away from this part.
Nov 18, 2007 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
859 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
