Question about Mitsubishi VS-6041 60" Rear Projection Television
VS6014 Have had this set since brand new - picture is getting fussy (not Crisp)
VS6014 Have had this set since brand new it has been turned on 24 Hours a day since new about 11 years only time it was off was during the hurricanes - picture is getting fussy (not Crisp) still has picture and sound just letters on edges are starting to look blured
I tried the self test (push input and menu buttons at the same time) and that does not work on this on.
Any suggestions?
  • Anonymous Apr 20, 2008
    I have the same issues, did anyone get this figured out?
    President:
  • 4,402 Answers
Sounds like the tubes might be shot, would try doing a focus and convergence before calling it the tubes.
Posted on Jan 14, 2008
Sanyo 24 in flat screen model DS24425 Screen slowly goes fussy and slowly goes black , a slight tap on the rear left side brings the picture back to good screen,for a few minutes or a couple of hours no...
Hello
Your flat panel TVs picture tube base board has soldering loose contact with it. Just unplug your TV from AC mains socket, and open it. Pull out the picture tube base card from the picture tube neck. Pull it out straight, no shake must be there, as it will damage its connecting pins.
Normally, loose sodering are very difficult to loacate, as they will be quite micrscopic in size. Just resolder all the suspected loose sodering point on that board, by applying a little more solder. This will solve your TVs problem. OK.
May 26, 2011 | Toshiba 55ZV650U 55 in. LCD HDTV
It maybe a filter problem go through the steps you took when installing the new bulb and check all then test.
Thanks J
Feb 03, 2008 | Toshiba TLP S30 Multimedia Projector
I have a brand new samsung 46' lcd tv and the picture is not crisp it is very fuzzy?? What do I do?
More than likely your set is fine and you need to provide it with a HD signal. Contact your cable or satellite provider for an upgrade
Jun 02, 2010 | Samsung LN32A550 32 in. LCD TV
Sony KDS 50a2020. Tv Seems to Dull. not a setting.
Two possibilities:
1. The lamp. When did you last replace it? They will dim over time and lose focus, clarity, brightness and sharpness. If it has been 18-24 months, and this is your main tv, consider replacing it.
It's a F-9308-860-0. They go for about $175.00.
2. Let's say you follow my advice, put in a new lamp and the picture is still dim, dark, dingy and fuzzy? Then you, my friend, need a new Optic Assembly. The thing your lamp shines into and the thing that gives you a picture to look at. They can fail or wear out for all sorts of reasons--too many for me to type out now. But, suffice to say, if you have recently replaced the lamp (less than 6 months) and are experiencing a drop in brightness, consider getting on the phone with Sony. Even if you are out of warranty, your set is covered against Optic failure until June 30, 2010.
Hope this helps.
Jan 21, 2010 | Sony KDS-50A2020 Television
Best settings
Vivid will make the picture look its brightest, press either Status, info or recall on the remote to see what Resolution you are receiving. If 1080i or higher,(720p is higher than 1080i) you should have a very clear and crisp picture.
Aug 09, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Looks blurry, wanting a clear & crisp picture.
In the picture settings, you can choose between hdtv and standard t.v.. That should work for you because not all channels broadcast in the hdtv signal.
Jul 16, 2017 | Televison & Video
Sharpness of the image
Putting sharpness up to high will cause the opposite effect. To get the correct level of detail you are looking for you need to adjust all your settings, especially your contrast and brightness levels. A good guide would be cnet.com. They have several posts for TV settings for HDTV. Goof luck. Please post back to let me know how things go.
Nov 14, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Red and green colors not coming through in picture
Bad crt
Sony Picture tube recall
http://esupport.sony.com/perl/news-item.pl?news_id=24
Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700
Feb 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Picture quality
The output from your sat reciver is not HD unless it says right on it that it is . The signal your getting now is a digital signal from the dish to the reciver, but from the reciver to the TV set, it is analog. To answer short and sweet, Yes, you will need an HD reciver for the satallite to get the most out of your HD TV set. Good Luck Ps and please dont forget to rate this.
Oct 16, 2006 | Hitachi 57S715 57" Rear Projection HDTV
Televison & Video Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
