Question about Apple (R) 17 LCD Studio Display
Loss of usb jack in monitor - Apple (R) 17 LCD Studio Display
  • Apple Master
  • 739 Answers
Just check that the connector hasn't come out of the back of the Mac. It's not likely but you never know.
Posted on Nov 14, 2009
HOW DO I GET SOUND ???
Your HP Pavilion F1903 monitor does not have built-in speakers. Your desktop computer probably did not come with speakers. You will have to plug computer speakers into the audio-out jack (green) on the back of your computer to play through external speakers.
There are also a number of USB speaker systems available that use USB both for power and for the audio signal.
Alternatively, there is probably an earphone jack on the front panel of your computer. If you plug headphones into that you should be able to listen on your headphones.
Amazon com AmazonBasics USB Powered Computer Speakers A100 Computers... Amazon com Joylive White 3 5mm In Ear Earpiece Earbud Headphone Earphone...
Jun 27, 2016 | HP Pavilion F1903 19" LCD Monitor
What is the use of rear usb ports
The USB ports on the monitor will work only if you connect the monitor via a USB cable to your PC/Laptop's USB port. Sounds awkward. Doesn't it? There must be a USB cable with flat socket on one end and trapezium shape jack on one end. It should be in the box which the monitor came in. The USB ports in the monitor are just another extended USB ports for your PC/Laptop. If you can't find the cable mentioned above, it is the same cable you connect to a printer, scanner,........ In some cases you might need to install a driver which should also come along with monitor. Mostly you don't need to install.
Good luck.
Sep 13, 2013 | Dell UltraSharp 1905FP LCD Monitor
My usb port on monitor isn't working. how can i fix this?
Good luck.
Apr 13, 2012 | NEC MultiSync 1770NX 17" LCD Monitor
How do i connect compaq presario x1000 to external monitor
Hi Judy,
The Compaq Presario x1000 notebook offers connections for external displays at the rear below the screen hinge as show in the picture below:
Identifying the back from left to right: Ventilation slots, External VGA Port, S-Video Port, USB Port, USB Port, RJ-45 Network Jack, RJ-11 Telephone Jack, Parallel Printer Port, USB Port and 1394 (a.k.a. "Firewire") Port.
You can connect a VGA monitor to the VGA port (blue colored jack) very easily. Any analog VGA monitor should readily connect to it. Additionally, the x1000 can output its display to TV or other monitor that accepts "S-Video" signals. An "S-Video" cable will be needed to connect between the "S-Video" jacks on the notebook (next to the VGA Port) and one on the TV. It is important to note that not all TVs support both or either "S-Video" or VGA inputs. When ever the there is a choice of using S-Video or VGA on a TV or monitor, the VGA will provide the best looking picture, and should be used.
I hope this helps and good luck! Please rate my reply - thanks.
Oct 03, 2011 | Compaq Presario X1000 Notebook
The touchscreen is not working, it's seems that the USB port is loose. Where can I find a replacement part or can it be repaired?
The USB port is soldered to the driver board in the monitor. If it is loose then either the jack is broken and will need to be replaced or the jack is pulled from the solder on the board and will need to be resoldered. Hopefully the board was not damaged. The ELO monitors are a pain to open the case on and you will need to know how to solder to replace the jack. If you don't normally do electronics repair then in this case it would be best to find a repair technician than can do the work for you. As long as the board itself is not damaged then this type repair should not run over about $50 (parts and labor) plus shipping. Here is a link to a service site that can do the work for you.
http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
BuddyMc
Aug 16, 2011 | Elo 1515L (Grey) (Dark Gray) 15" LCD...
None of my USB ports on my p2210 monitor are working How do I fix. Thanks
be sure that you connect usb cable between pc usb port and monitor usb port and try its usb
good luck sir
Apr 01, 2011 | Dell P2210 Monitor
On imedia should i connect the usb to speakers and green jack or only the usb?
Please do a monitor self test
connect a monitor without a cpu
or rather just connect a power cable to a monitor
if u get check video cable or something lyk tht its wrkng
if nt thn u l need 2 change the monitor
Mar 26, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
Where do I connect the speakers to the monitor. I have a Flatron L1922P monitor. I ordered 2.0 USB Multimedia speakers that come with a 3.5mm stereo plug and USB plug. I must not being doing something...
Your speakers do not plug into your monitor. Your speakers should be connected to a USB slot on your PC tower and the 3.5mm stereo plug should be put into the green stereo jack on your PC tower. If your audio jacks on your PC are not colour coded, then you should look for the jack which has a picture of a set of earphones over them.
Depending on your speakers, you may or may not be required to keep the stereo plug connected in order to get sound. Some models transmit model over the USB connection and others just use the USB connection as a way to supply power to the speakers and need the stereo plug to be connected in order to have sound. I suggest trying both.
Mar 25, 2011 | LG L1922P 19" LCD Monitor
HOW DO I HOOK UP TO GET SOUND
well there should be either a usb cable or an mini stereo audio jack, most likely green tip, and you plug either the usb cable up to the computer or the audio plug in the headphone jack in the back of your computer usually has a green ring around it.
Jul 11, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
HELP
Do you mean you can get it to turn on?
Apr 23, 2008 | Compaq Presario FX700 17" CRT Monitor
Computers & Internet Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
