Question about JVC Cybercam GR-DVL520 Mini DV Digital Camcorder
I have a JVC GR-DVL 520 that has not been used for some time. I purchased a new battery and charger, charged the battery fully, inserted a tape. When I tried to record, I got the E03 message - "unit in safeguard mode" eject and reinsert tape. I have tried removing and reinserting the tape numerous times, as well as changing the battery and still get the same message. I saw one response on this site that mentioned a reset button in the battery compartment which I cannot find. Please help as I have an event I would love to be able to film Thank you
  • jaughtman Nov 14, 2009
    thank you. I imagine that is the problem - the tape that is in the camera has been in there probably a year or so - I had misplaced the camera and just found it. Will purchase new tapes and keep my fingers crossed :-)
  • jaughtman Nov 17, 2009
    I tried new out of the package tape - newly purchased and continue to get the same message. I have used compressed air to blow out the tape compartment and still no change. The camera probably was never used more than 5 hours when it was new and has been in a closed camera case in storage in our house.
    If there is not a "fix" available, is replacing the tape mechanism very expensive?
  • 10,594 Answers
E03 error code means problem with Take-up Reel table that is not spinning properly and system control chip missing Take-up reel FG pulse/ signal.
reason can be either bad / stiff tape or defective mechanism of camcorder.
Try few other tapes in camcorder and if problem still exist, replace tape mechanism by qualified camera tech.
Thanks.
Posted on Nov 14, 2009
  • 4,472 Answers
You may have a mechanism/tape basket problem or drum head/motor problem. If you want to have it repaired you can contact JVC at (800) 252-5722 for repair and warranty coverage info. I would recommend having the camera replaced because of how fast the technology moves and the price for repair compared to the price of a new one with all new parts and new warranty. You can always sell the parts on ebay or craigslist to recoup some of the cost of a new one. If you need any further assistance please let me know.
Thank you,
lee
Posted on Nov 17, 2009
I need a replcement batterie where can i GET THEM
Battery World has pretty much all types of batteries or would order them in for you
Aug 19, 2010 | JVC GR-D53 Mini DV Digital Camcorder
Where can I get mains charger for JVC GR DVL 9000
http://www.camera-battery.com.au/s/battery-charger/jvc/gr-dvl9000/?gclid=CP2C9Kb_naMCFQMjbgodoCJeng
click on this link camera-battery.com have the home and car charger kits for $29.95
good luck
Aug 03, 2010 | Cameras
Keep getting 0E4 CODE ????? ON JVC MINI DV
In the case there is no DRUM FG input in the
drum rotation mode for 4 seconds or more. This
error is defined as [E04], and the mechanism
mode is shifted to STOP with the pinch roller
set off.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA.
Sep 08, 2009 | JVC GR-DVL520 Mini DV Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
Shows fault E04 remove & reattach battery
Hi, Regarding the above fault with my JVC camcorder, I have solved the problem by removing the tape and replacing with a new one. Thanks anyway.
Regards,
**** Coupe
Mar 30, 2009 | JVC Video Cameras
JVC GR DVL 9000 digital video camera EO3 problem?
In the case no REEL FG is produced for 4 seconds
or more in the capstan rotation mode after
loading was complete, the mechanism mode
is shifted to STOP with the pinch roller set off.
This error is defined as [E03].
However, no REEL EMG is detected in the
SLOW/STILL mode.
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
status.
Sep 16, 2007 | JVC GR-DVL9000 DV Digital Camcorder
Eo4 error code
HI SIR the fault is caused either by the take up or supply reel in the camera they are not rotating when the tape is inserted.maybe A defective tape or hung reel brake can cause this issue.or maybe a bad loosen guide of the tape path is lame , Try replacing the tape, if this does not resolve the problem you may need to seek professional service to have the reels checked. thanx and plz try to rate and remember i am here just to help u thx
May 08, 2007 | JVC GR-SXM920 Camcorder
Cannot switch on
check whether the switches are jamed or not? did u try with the charger alone? there is no way u can get tape with out powering it up.
ny way u hav i-link cable of that one?|
Nov 28, 2006 | JVC Cybercam GR-D70 Mini DV Digital...
Open Questions:
JVC Cybercam GR-DVL520 Mini DV Digital Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
