Question about Frigidaire GLEQ2152ES Electric Dryer
THE DRYER TUB LEANS FORWARD. MAKES GRINDING NOISE.
For some time the tub has leaned forward leaving a gap @ the bottom of the tub. in is just large enough to catch a zipper or button. now when running it makes a grinding noise. the clothes are even hotter than usual. it almost hurts to hold them.
As I have never worked on a front loader and I dont possess a manual, I am not sure what is suposed to hold the tub truly horizontal. is it a bearing system? if so does the tub have to come out the front to repair it?
  • Frigidaire Master
  • 7,482 Answers
Most of my repairs have been to top load machines, so my help would not be of assistance to you.
If you plan to work on the dryer yourself, I would highly recommend that you purchase a manual for it.
The following website may be able to help you.
http://www.applianceaid.com/
Look under "Repair Manuals"
Good Luck,
I hope this helps
Posted on Nov 15, 2009
96 Honda Civic making a popping noise when I release the clutch and third gear
Reasons for popping noise:
Popping noise could occur due to the malfunction in the ignition system, leaky valves, weak cylinder compression, carbon accumulation in the combustion chamber or lean fuel.
1. Ignition system malfunction (Misfire).
Check:
- The ignition timing.
- Spark plug gaps.
- Use colder type spark plugs.
- Ignition module and ignition coil.
- Distributor cap and rotor.
- Spark plug high tension cords.
2. Cylinder compression:
- Check valves clearance.
- Perform cylinder compression test.
3. Fuel system (For lean state).
- Check fuel filter for clogged.
- Check fuel injectors.
- Check fuel pump pressure.
- Check fuel regulator.
May 04, 2015 | 1996 Honda Civic
Dryer makes loud noise is a ge has thin belt on it. belt is ok seems like the tub doesent turn as fast as it did.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
whn
Mar 09, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Load seems unbalanced during spin cycle making an incredible amount of noise.
it could be a susp rod is broken when you look into you tub b4 you add cloths does it lean to on of the 4 coners if so the susp rod must be replace or if ok then put into spin with out cloths is it ok then if only happen on large loads then the bottom of the tub assy is hitting the bottom panel of the washer
Sep 08, 2009 | GE Washing Machines
LG wm -1832c front loader making noise
when you take the panels off you will see that the barrel is suspended by springs on top and fake struts on the bottom. be careful when removing the panels. if the barrel is leaning forward it's the front struts, if it's tilting upward it's the rear. and be careful how much you load in a front loader
Feb 17, 2009 | LG WM-1832C Front Load Washer
Tub leans to the right when washing the clothes
I washed pillows in my washer and now the tub leans to the right front. And my dryer needs to have the lint cleaned out of it. How do I do this. They are Kenmore 80 series washer and dryer
Nov 23, 2008 | Maytag HAV3460AWW Top Load Washer
Dryer drum catching clothes in gap
most driers are now smaller in overall size and have ratings as to their capacity
many are more energy efficient , drying quicker than the older models
check the spares availability at an authorized repair agent spares for a new drum as fixing it would be the last option
Jul 30, 2017 | Dryers
Stuck clothes
There are durm glides that support the front part # 5303937139
you can look up and order at www.apdepot.com
Hope this helps
Jul 18, 2008 | Kenmore 62722 Electric Dryer
Noisy Dryer Drum - Squealing/Grinding type Noise.
okay this is a stack unit, what you have is a rear bearing problem, This will also cause your tub to lean. it is located in the back, to make your unit right go ahead and buy the rear bearing, it will come with a white coupler, bearing and you will need to lubricate it....
also for a couple of more dollars order you the front seal, this is the white felt that surrounds the door...
1. top felt
2. bottom felt.
thanks
Apr 02, 2008 | Dryers
Terrible scraping noise from drum,what is it?
more likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
Jun 01, 2007 | Creda W100FW Front Load Washer
Frigidaire GLEQ2152ES Electric Dryer Logo
123 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
