Question about Maytag Atlantis MDE7400AY Electric Dryer
Squeaks all the time while running - Maytag Atlantis MDE7400AY Electric Dryer
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots and wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Nov 15, 2009
DO SHOCKS WEAR OUT AND START TO AND SQUEAK WITH AGE
the squeaks will be dry rubber bushings. Use some wd-40 and squirt one bush at a time to find the squeak and replace that one or re-tension the nuts or bolts. could be the sway bar bushes.
Jul 21, 2014 | 2004 Toyota Solara
I have a squeak that will not stop now, it started out in the morning time when it wad damp it would make a screech squeak noise, then stop as I started to drive it, I have just recently replaced the...
Alternator belt is loose or there is oil on the pulleys or belt making it slip instead of charge the battery. Check belt tension on your belts
Sep 29, 2013 | 2000 Mitsubishi Galant
Dryer drum has an intermittent squeak when running
there is a belt tension'er it might need to be replacing or temp fix greasing or drum bearing replacing or temp fix greasing to do this you will have to remove the drum
May 28, 2012 | Frigidaire GLEQ2152ES Electric Dryer
I have a gas dryer Maytag Dependable Care Model 6 cycle about 11 yrs old...Has a steady squeak as it runs , seems to be getting louder . Everything on the dryer seems to work fine other than this...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 14, 2011 | Dryers
First it started squeaking when it was running. Now it squeaks and doesnt heat while running Model #GLER331AS1
heatman101
Jun 13, 2011 | Frigidaire GLER341A Electric Dryer
Dryer sqeaks while it's running
This could be the result of a loose/worn belt, or worn drum roller bearings. Is it a constant squeal or a squeak......squeak.........squeak, basically in time with the RPM of the drum? If that is the case, get new drum bearings. If the former is the case, get a new belt.
May 24, 2011 | Maytag Neptune MDE5500AY Electric Dryer
With every step I get squeak / chirp while running on treadmill.
Check the knob used to hold it up in the folded position. While running, have someone pull it to the out position. That was the problem on mine. If it is, a little grease on the end of the rod should do it.
Jul 23, 2009 | Exercise & Fitness
HOW DO YOU GET THE SQUEAKING NOISE TO STOP
You must indicate where the squeaking is coming from. If its only squeaking, move on. There's other people here with down time problems. It'll stop squeaking or stop running eventually. If it stops working, then write in!
Mar 05, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
384 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
