Lights and fan comes on but screen does not then the Laptop seems to reboot and it does the same thing, until i manuallt shut it down.
  • Richard  Scott
    Richard Scott May 11, 2010
    can you get into safe mode have you added a external monitor to see if it works there
    Champion:
  • 206 Answers
Try removing the battery for an hour or two, and then try to turn it on again
Posted on Nov 15, 2009
  • 73 Answers
Hi this might be due to a lot of reasons. Check your ram slot. if possible remove and install ur ram again. also if ure initial set up screen comes then try to reinstall os. if nothing comes on screen it might as well be a monitor problem. check ur display in that case.
Posted on Dec 08, 2009
Why is my Lenovo G585 shutting down while I'm using it?
This could be a lot of things. The most common is heat. When the unit get too hot, it shuts down. The other thing that can cause this is the hard drive starting to go bad,
Nov 12, 2014 | Lenovo G585 15.6-Inch Laptop Glossy Brown...
My laptop has a black screen and i cannot give it any command and have to force shut it down
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 07, 2013 | HP Pavilion DV6500Z Notebook
Screen shows " shutting down " seems stuck in this mode
press and hold the power button until it shuts then reboot,common issue in vista if thats what you have.
Mar 01, 2013 | Lenovo G780 2182 laptop
Samsung laptop purple light
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 18, 2012 | Samsung R540 Laptop
Vaio computer problem
You could have a faulty fan and/or dust clogging the fan and heat-sink assemble. This is the most likely cause of the laptop shutting down. When the CPU overheats it goes into thermal shutdown and if this problem is not fixed, eventually the CPU will fail.
Check the fan to see it it spins freely and check if the fan works when the laptop is powered up.
If the fan and heat-sink is ok, then to give the laptop addition cooling then purchase a laptop cooling pad and place the laptop in this pad (These pads have cooling fans and helps cool the laptop).
Jan 29, 2010 | Sony VAIO VGN-CS110E/W NoteBook
Acer 3100 laptop lights on fan on slow but no screen
Remove the battery and disconnect the Ac adapter from the laptop. Press the power button and hold it for 10 seconds.Reconnect only the Ac adapter and power on the laptop.
Post back if the above solution doesnot work , it could be bad video card driver.
Thanks for using fixya
proton
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
Black screen will not boot at all
boot it, as it starts, keep tapping the F8 key,
should take you to, system startup utility,
take the top option
" last known good"
let it do it's thing
Reboot.
hope this helps
Regards
Richard.
Apr 20, 2009 | Gateway MT3422 RTL Notebook
Toshiba Laptop keeps freezing and shutting down
its the problem of your RAM not the hard disc. the blue screen error come because of less memory available for proccessing. so please once remove the RAM and again insert it and reboot your laptop......
Feb 24, 2009 | HP Pavilion dv6000z Notebook
Laptop Reboot on Startup
Do you want to sell it for parts
Oct 21, 2008 | Gateway MX6453 Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
