Question about DXG Technology DXG-565V Flash Media Camcorder
Unable to view moves from the camera on my TV set.
When I plug in the TV OUT cable into the camera, the LCD screen on the camera goes blank.
  • 561 Answers
This could be correct as the signal for the Camera LCD screen is now being sent to what ever device is connected on the TV out cable.
ensure your connection is
Camera - TV out
TV - Video in.
ensure that your TV is set to the correct channel or input setting to view the signal from the camera.
Posted on Nov 14, 2009
Screen goes blank on Samsung LCD TV. Comes back on if tilt or move screen.
I'm gonna go out on a limb and say you may have a LCD tab(s) that are failing.
Jan 26, 2013 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I have an LCD Sony Bravia KLV-46V400A, and a Dell Laptop both TV and PC have HMDI connection, i pluged them both using HDMI cable, however i am unable to view anything on my TV screen and nothing on my pc.
make sure that your pc is shutdown(off) when you plug the hdmi cable in your tv. First, plug hdmi cable into tv and turn on tv. Next, power up pc and it should see your tv. There should be an option on the pc to set the output a projector.
Mar 26, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
We cannot view camera images on TV from G2. We could in the past. Image in camera viewer goes blank when plugging tv cable into camera. Tried new cable. Still the same. Has something failed in camera?
Hello. I'm not sure if the camera has failed but try this sequence.Plug camera into tv then turn on camera then push review button. This is the only way 2 of my cameras will work for tv viewing.
Builderdale
Feb 26, 2010 | Canon PowerShot G2 Digital Camera
LCD Scree went blank/black
No problem. Discovered that fix by accident when my camera did the same thing. Since the screen was blank, tried arranging camera setting using the camera's AV cable with the TV, and discovered that fixed it. Apparently corrosion builds up on the AV cable plug switch (which also turns the screen off when inserted), and inserting/removing the plug several times can fix it.
Jul 10, 2009 | Canon PowerShot SD10 / IXUS I Digital...
Sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
May 19, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Canon EOS XTi video output not working
Check that you have the right video cable first. It should have a plug with three contacts at the camera end and 1x black and 1x yellow plug at the other. Check that your camera is set to the correct video output for your region.(NTSC/PAL setting is found in the menu) To check the camera is working correctly, press the playback button to display an image on the lcd and then plug the cable in. If the screen does not blank the camera has not detected the cable being plugged in. A service centre would need to repair the connector or board if that is the case.
Mar 29, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Blank Screen using HDMI-DVI cable for PS3
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Black LCD screen/ not 'seeing' picture. Canon EOS 400D camera
Hi
The Digital Rebel XTi doesn't have 'live view' mode, you can't see what you're taking a picture of before you take the picture.
Thomas
Darntoothysam com - Digital camera parts and repair.
Nov 11, 2008 | Canon Rebel XTi / EOS 400D (body only)...
Coolpix nikon digital camera
This sounds like a broken or cracked LCD screen. The backlite is working, thus you will get the white screen. The LCD could also be disconnected internally, or has other problems. But this is a direct problem with the LCD.
A camera like this can usually take pictures, and you may be able to use it to set the menus by using the video cable to the TV or computer screen (some flat screens have video inputs).
Dec 04, 2007 | Nikon COOLPIX L3 Digital Camera
My LCD screen shows a colorful vertical line & then the screen goes white
Hello, The problem is in bad contacts on flat cable from the LCD. Cleaning the cable and the connector can solve the problem. If you need more info please advice. ps: this should be the long term solution.
Apr 21, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
DXG Technology DXG-565V Flash Media Camcorder Logo
93 people viewed this question
Top DXG Technology Video Cameras Experts
SHARCNET-USA
SHARCNET-USA
Tony Parsons
Tony Parsons
Are you a DXG Technology Video Camera Expert? Answer questions, earn points and help others
