Question about Pantech U4000 GSM UNLOCKED 1.3MP CAMERA SLIDER PHONE Cell Phones
Certain buttons work?
Why does only certain buttons on my pantexh matrix work and how do i fix it?
How to find the determinant by Sharp ELW516 Scientific Calculator
Press the MODE key. and press 4 for MATRIX.
To enter a matrix press the MATH button and choose 2 for EDIT. Determine the size of your matrix by typing in the row x column value (maximum 4). Then press =. Type in the values in your matrix. After each value press = to move to the next part of the table. Once your matrix is complete press ON and then the MATH button. This time choose 4 for STORE. Select the matrix name you would like to store your matrix in - for example choose 0 for matA. Now press MATH and press the down arrow key once. Select 6 for CALC and choose 0 for det (determinant). Then input the matrix you want the determinant of by pressing MATH and 1 for MATRIX. Select the matrix you would like to work with eg, matA and press then press =.
Aug 22, 2012 | Sharp ELW516 Scientific Calculator
How to do matrix multiplication in scientifically calculator
Here is an account of what you can do with matrices on this scientific calculator. Certain precautions must be taken as concerns the dimensions of the matrices. Refer to your text book on matrix algebra.
On this calculator the largest matrices you can define have dimensions 3X3.
  1. First you must set Matrix calculation: Press [MODE][6:Matrix].
  2. Then by entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix (mxn].
  3. Once finished entering the matrix you clear the screen.
  4. The operations on A SINGLE matrix are available by pressing [Shift][Matrix].
  5. The choices are
  • [1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
  • [2:Data] enter values in a matrix
  • [3:MatA] access Matrix A
  • [4:MatB] access Matrix B
  • [5:MatC] access matrix C
  • [6:MatAns] access the Answer Matrix (the last matrix calculated)
  • [7:det] Calculate the determinant of a matrix already defined
  • [8:Trn] The transpose of a matrix already defined
Once you have created a square matrix, for example matA.
You press
[Shift][Matrix] [7:det] [SHIFT][MATRIX][3:MatA], close the parenthesis and press [ENTER].
If you have defined two similar matrices (same number of row and same number of columns) you can ADD them or subtract them. The operation keys are Plus and Minus as for any number.
To multiply you use the multiplication sign. The matrices must be compatible (mxn) multiplied by (nxk).
Aug 10, 2011 | Casio FX-115ES Scientific Calculator
Pantech cell phones can be use in the philippines? it needs to openline? but no available software for pantexh cell phones in the philippines how can i open line the phone? tnx
a friend sent me a pantech phone AT&T where you able to find a solution? I found some info from Sulit.com for phones being used to open At&t so far I have not heard from the person. thanks aribx@hotmail.com
Jan 25, 2011 | Kitchen Ranges
Hi - I have a whirlpool gold series electric double oven. The error message is E1 F2. Anyone know how to fix this?
it could be the following
Taking a Quick Look
The E1 F2 error message indicates the control board thinks the touch panel has been unplugged from the board or it cannot read the switches.
How it Works
The panels on these ovens utilizes a switching matrix to constantly monitor all the buttons for a key press. By using a matrix for switch input, many buttons can be read by the processor using very few wires. The unfortunate side of a switch matrix is if any one wire becomes damaged, an entire row of switches on the matrix will no longer be usable since they cannot be seen by the control board.
advise
getting a qualified engineer to check this touch panel and suspect touch panel maybe defective and need replacing.
I hope this was helpful
Jan 05, 2011 | Whirlpool RBD305PD Electric Double Oven
To find the determinant value in a fx991MS calculator
Use the matrix mode in the calculator.
In that mode you will be asked what the order of the matrix. Select the matrix of the desired order. After that you will be asked to enter the elements of the matrix.
Then you will be redirected to your normal screen. Select the shift button and press the button with matrix written on the top of the button. Push that and you will find an option to find the determinant of the given matrix.
Good Luck
Dec 17, 2010 | Computers & Internet
Pantech matrix turns off when I push the period or backspace button when texting. I have reset phone by removing battery and sim card-did not fix. It is an intermittent problem
Try your reset button. It is around or under the battery. It is usually a small hole. You might need to use the end of a paper clip. If this fails, see your provider.
Dec 05, 2010 | Pantech Matrix Cell Phone
My pantech matrix cell phone buttons arent working
You can finda different way to end call/ If you got to like call settings, it asks how you want to hang up. I only have to sldie my phone closed. can't help with teh resyt.
Jun 07, 2010 | Pantech Matrix Cell Phone
Touch screen not working but the other buttons work
This could be an connection problem of your matrix screen. When you open the phone you will see a flatcable with a litte flat cable connected on that cable it could be that the little one isn't fitted well the flat cable is from your LCD screen and the Little flat cable that is fitted on that Flat cable is from the matrix screen (Touch screen).
Jun 03, 2009 | LG KU990 Viewty
Hi, i have a mitsubishi fto gr, the car starts and runs fine, but i have no hot air coming from the vents although the car gets warm, its not the heater matrix or coolant level, any ideas? thanks Andy I...
If your car has climate control, remove the glovebox, and change the heater temp from the lowest to the highest setting. you should hear the electric motors pulling cables in the dash. it's probably a faulty control unit in the dash, you're certain there's hot water going through the matrix?
Dec 20, 2008 | 2002 Mitsubishi Montero
Pantech U4000 GSM UNLOCKED 1.3MP CAMERA SLIDER PHONE Cell Phones Logo
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
