Like to know the diameter of bolts (4) used to mount my 42 in.lcd
  • 11,361 Answers
Most of them use Metric M5, but some will use M6.
Posted on Nov 15, 2009
Bolt size for starter 92 tracker
mount starter mount
lost both?
they are both the same diameter.
the length is super easy, measure it.
the leaves, diameter, metric, 8 or 10mm and pitch
so using a box of random bolts with starter off
find one that fits, m8 or m10, or m12.
now you know the sizes, and with starter off the holes are right there. in front of you to test.
to get length, use drinking straw, and your thumb, nail
to find lenght fitted up by and then move straw to ruler, metric
ahhhhhh there is the lenght in 5min work.
if no bolts in the scrap box, at all, metric, buy some.
Oct 30, 2016 | 1992 Geo Tracker
NEED BOLT SIZE TO MOUNT 42 JVC LCD 120HZ PLEASE
Best way is to Call JVC customer service with the model number--need number of bolts,thread type and you are going to find in almost all cases they are standard ones---Home Depot will have them.
Apr 26, 2012 | JVC 42 in. LCD TV
Want to mount tv lg 42lg50 42 in. on wall...which screws you use for drywall
You don't use screws for drywall to hang a TV, EVER.  That's a 50 pound TV.  You should only use the heavy stud bolts that came with mounting bracket and bolt them directly into the studs.  If by some chance the mounting didn't come with them, go to Home Depot or Lowes with the mounting tell them what you're doing and they'll get you what you need.  You are using a mounting bracket, aren't you? If by some chance you're trying to do this without a mounting bracket, STOP what you're doing and get a mounting bracket appropriate for your size television.  Go to Monoprice, they're the cheapest and their quality is excellent.  Meritline is good as well, they just take a little longer to get.  See the video below.
utube.png You-Tube video "lCNyc-KgCDY" placeholder [unremark-end]-->(do not delete) utube.png
http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10828
http://www.meritline.com/tv-wall-mount---c-13552.aspx
Apr 22, 2011 | LG 42LG50 42 in. LCD HDTV
What size bolts do i use to mount it
It is very likely that the correct mounting bolts to attach a wall mount to your TV are type M8 bolts 20 MM long. It is a rather standard size and you should be able to find them locally without a problem. This is the most probable size although you may find that it requires a different size. It should be either a M5 or M4 bolt of similar length. Give it a try, I think you will find it works perfectly!
Mar 07, 2011 | Toshiba 42HL67 42 in. LCD Television
Mounting bolts
Most TV uses Metric M5 or M6. You should be able to get them locally for about 25 cents each so you you try them out.
http://s807.photobucket.com/home/budm/allalbums
Jun 23, 2010 | Proscan 42LA45H 42 in. LCD TV
What specification of bolt is needed to mount the LG 42LB1DR using a VESA wall mount? Thank you.
It can be METRIC M5 or M6, when you buy wall mount brackrt, the kit will come with mounting screws to attach the TV to the brackets.
Dec 10, 2009 | LG 42LB1DRA 42 in. LCD Television
HP speaker
The screws are little fatties,
they measure 3/inch in height and 1/4 inch in diameter...
just measured them for you!!!
hope this helps!!
Nov 17, 2008 | HP PL4260N 42 in. Plasma HDTV
Remove Swivel Base on 42LB1DRA
If you look at the back of your TV, locate four big screw/bolts. Its the biggest screws/bolts you'll ever find at the back. 2 each side that holds the unit to its swivel base. roughly 12" from the left edge and 12" also from the right edge. remove all this four (4) screws/bolts then ask someone to help you lift from the base.
Good Luck.
Dec 30, 2007 | LG 42LC2D 42 in. LCD HDTV
Wall mount hardware
The bolt size you need is: M8-1.25 X 20.  20 is the length that I used and it works well.  You could also use 25 (which is a little longer) if you would like.
It took about 5 trips to Home Depot and Lowe's and a few hours searching the web before we got it right.
Sep 06, 2007 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
