Question about Sony Xplod (P589) Car Subwoofer
45w54 xplod. which wires do i use for the sub?
    Problem Solver:
  • 6 Answers
You want to get a wire that is capable of handling the output from your amplifier. Go down and see your local car audio dealer and he/she will advise you on the best gauged wire to install.
Trent
Posted on Nov 16, 2009
Are sony xplod 1100 watt 10'' subs 2 ohm stable
No keep on trying end blow everry thing up, Buy some real subs.
Nov 29, 2012 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
May 11, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
I would like know whether a sony xplod subwoofer can be connected to my alpine car audio system! xplod sub woofer is 1100 watts.
Deffinitely but wired directly would be pointless, the Alpine's internal amp is way to weak to get the best out of the sub. You need an amp, minimum 300w and bridge the outputs to give all the power to sub preferably switched to low-pass (most amps will have a high / low pass switch)
Dec 07, 2009 | Alpine CDA-7892 CD Player
Sony Xplod Amplifier Problem
First make sure you are using at least a 12 guage speaker wire for sub connections. Second make sure you have plenty of breathing room in your mounting position, these things need air badly. Third of all, Xplods are not very friendly if they are cranked all the way up on your dB boost knob. Only crank it about 3/4 of the way up, then use your equalizer settings to tweak the thump.
Oct 20, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
I have 2 1100watt sony xplods will they run off a 1000 watt amp
yes it will work, but it will only put out the power to the sub that the amp allows, ie : 100 watt amp puts out 100 wats.
you can also try reconfigering your wire to your subs, if your amp is 1ohm stable and your subs you can come off the amp with a bridge and run subs in series or parralell, this will dramaticly improve the bass
Apr 14, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Can I run 8 speakers and 1 sub through 1 1200watt 2:1 Sony Xplod?
asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
series; posative of one speaker to negative of other speaker and that doubles your ohms
parallel; posative to posative negative to negative and that cuts the ohms in half
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Dec 19, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod (P589) Car Subwoofer Logo
85 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
