Question about Sony STR-DE595 Receiver
How do I hook-up a graphic EQ to this unit? I only have a basic CD player running through it-
  • 458 Answers
NOT NEED OUT SIDE EQ FOR THIS MODEL...
Posted on Nov 16, 2009
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
May 09, 2016 | Pioneer Audio Players & Recorders
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
How to hook up my Yamaha EQ-70 Equalizer
This is official image from Yamaha. If need to know more, go to the below address -
http://www2.yamaha.co.jp/manual/pdf/av/english/am/AV-90PY.pdf
download the amp's manual & you will find on page no. 7
Jul 05, 2009 | Yamaha EQ-70 Home Equalizer
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
No clue how to connect my equalizer
FOR EXAMPLE IF YOU WER HOOKING IT TO A CD PLAYER,, YOU WOULD PLUG RCA JACKS IN THE LINE OUT ON THE CD PLAYER,, THEN PLUG THEM IN THE EQ WERE IT SAYS LINE IN OR AUDIO IN,,THEN TAKE SOME RCA JACKS PLUG IN THE EQ TO AUDIO OUT, THEN TO YOUR RECIEVER,, IN CD ,,AND VISE VERSA ,,WETHER ITS A TV OR PHONO,, ANYTHING,,
Sep 25, 2008 | AudioSource EQ-100 Home Equalizer
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
Hi. i want to add a graphic eq to my pioneer receiver (home audio).
if the Eq has enough jacks to run every thing, that would go In to Eq an out to receiver, you were told correctly, for example cdplayer out - to Eq In - Eq- out to Receiver in
Nov 29, 2007 | Spectrum Technical Hifi EQ-B5100...
Sony STR-DE595 Receiver Logo
120 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
