Question about Hitachi 61SDX01B 61" Rear Projection Television
Hitachi 61SDX01B Hello, I will try to explain my situation as best of my abilities. I have a Hitachi 61SDX01B that was working great until about 3 months ago. Picture started to get darker and darker after a week or so it got completely dark and could not see anything (no picture and good sound). I called a place after a few days they came over to check it out after a few minutes they decided to take all the electronics from the TV. They disconnected everything and removed couple of screws and all the electronics from the bottom portion of the TV came on loose. After about a week or so they brought it back connected everything, they turned it on and still nothing. The tech guy had a plan ?B? just incase it did not work; he also mentioned that they replaced some capacitors and that is hard to trouble shoot the TV without having the entire TV with them. At this time he started to check some voltages. After a few minutes he tells me that the power supply is not supplying the correct voltage (12V, I think) to one of the picture tubes. So he pulls a piece of copper wire out of his suitcase and tells me that he is going to coil the wire to the power supply (or something around there), measure the voltage of the wire after each turn until he gets the desire voltage and solder the wire to the picture tube that is not getting the correct voltage. The area were he need it to solder the wire was at the end (tip) of the picture tube and since it had a small metal cover he was having problems removing it. At this time he tells me that he will have to come back on other day. At this time I got upset and told him that I didn?t want to fix the TV the way he was trying to do it. He got upset also, but I told him that I still wanted it fixed and that I just wanted to replace the entire component that was causing the problem. Not just a patch up work. I told him to find the price of the power supply (he referred to the part as the power supply) and to give me a call. Well, he never did call me and the TV is just sitting on my leaving room. My question to you is: Assuming that the problem is the power supply or something around the power supply (whatever injects voltage to the picture tubes), do you think is worth fixing the TV? Maybe with my story you can get an idea what the problem is. I do understand that you can?t tell me for sure what the problem is without inspecting the TV yourself but with your knowledge maybe you can tell me what the part number is called (whatever gives voltage to the picture tubes), part name. I know is a long shoot, I know is a risk that I?m taking trying to replace (maybe) this part without knowing exactly the name, part # or knowing if is this is actually the problem. so do you think is worth fixing it? how much do you think i can sell it as is? Thanks,
    Problem Solver:
  • 5 Answers
R43 resister drives the lamps 2.5 ohm 2 watt $.70 cent
located in the center of the center board . same tv i have did same thing
Posted on Jan 19, 2009
Chele5796969, email me at rizofam3@sbcglobal.net
Posted on Feb 14, 2008
Chele5796969, email me at rizofam3@sbcgolobal.net
I need a replacement screen for that same tv. Would you be willing to sell and ship it to me? I live in KS
Posted on Feb 13, 2008
How old is the set? if its more than 4 or 5 yrs old buy a new one and did u contact hitachi? if not try them depending on how old it is maybe they fix it if not the should atleast tell u the correct problem
Posted on Jan 09, 2008
Tv got dark and darker and now no picture what can be wrong? bulb bad?
If the model number indicated here is correct that set uses 3 picture tubes.
No bulb used on that model.
If model number is correct let me know and I have a few suggestions.
May 03, 2012 | Hitachi 61SDX01B 61" Rear Projection...
I have a hitachi 61sdx01b projection tv that just started showing the red and green color out of line ?
timjuvera,
Your unit has a failed convergence system. I have a tip at
http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics
which will explain and identify the problem, instruct you in the repair procedure and tell you where to get the parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 06, 2011 | Hitachi Televison & Video
Hi my hitachi 61sdx01b red power light is working but i have no picture or sound?
CK fuse F903 if it blows it again then replace STRM6511 CK all of the pico fuses 5and 6 amps they look like resistors they willbe green or yellow they are fuses.
Dec 21, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B Dark Picture and bad color
There isn't anything you can do yourself for this problem, but it should be worth having a qualified technician look at it.
Sep 09, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Screen broke on my Hitachi 61SDX01B, need replacement
Here's a link to order the original Hitachi screen assembly for this model (61SDX01B) from a major parts distributor:
Hitachi 61SDX01B Replacement Part Screen Assembly
Mar 19, 2009 | Hitachi 61SDX01B 61" Rear Projection...
DARK PICTURE
skimo, service manual part number is "SM-PA0131" I doubt you can order the whole module anymore set is 2000 yr model, why do you want to order the whole module any way? Big bucks if it is available, BMW Rider
Dec 14, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX picture got dim shows Code 3
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 17, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B picture...
Sounds like the blue convergence circuit still not working.
Assuming both IC's are good, look for open soldered-in pico fuse.
Once bowing problem is solved,then convergence should adjust ok.
Jul 27, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
125 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
