Question about Olevia LT37HVS 37 in. LCD HDTV
WHAT DO I HAVE TO DO WHEN JUST USING CABLE INPUT, WHAT IS THE SOURCE
  • 52 Answers
The source is TV.
Posted on Nov 14, 2009
Can not get a signal to my rca tv model led 32c45rqd
hmmm seems like the signal board is having issues or the cable your using is not good try having the cables or any type of cable replaced if HDMI or another source make sure the right input source is selected by changing the tv's input source (EG press the input button on the remote or "source" button)
Feb 22, 2017 | RCA Televison & Video
Tv will not speak to my computer..am using a vga cable, but the tv will not get past, setting up channel commands. I am not using the internet with this computer
If you have connected a VGA cable then you need to set the source to PC-VGA input not the Television channels.Button will be labelled either source or input.
Jan 26, 2015 | Insignia Televison & Video
What channel does my flatscreen need to be on for my roku player
it would be depending on the cable that you used to connect the roku to tv. if you're using hdmi cable, make sure to set the input source of the tv to hdmi. if you're using a/v cable, set the input source of the tv to video.
Dec 14, 2013 | Roku HD Player (N1100)
I unplugged my television, and plugged it back in, but the TV will not turn on now.
What probably happened is the Input mode was reset. Using the TV remote (not the cable or dish remote) look for a Input button or Source button. With the TV on (the screen may be black but you should see a small power light) use the Input or Source button on the remote to select the TV's source (ie cable, component, HDMI etc).
Jan 05, 2012 | Toshiba 57H83 TV
I have the word LINE in the right hand corner of my TV. I have connected it to cable and a cable box and nothing works. The TV still doesn't operate correctly and I can't even change the channel...
The word LINE is letting you know that the LINE Input is the source that you have selected on your remote. You should be able to change that using your remote. There should be a button labelled INPUT or SOURCE or something similar. If you want to watch the cable box press your INPUT or SOURCE button until you can see the feed from the cable box.
Jun 29, 2011 | Daewoo Televison & Video
2004 jvc 56in projection tv, has sound but no picture
Hello
Change the channel to ensure the problem isn't with the current station broadcast. Check the channel at a later time to see if the broadcast problem is resolved.
The type of programming you are trying to watch determines the proper input source. Press the "Input" button on the remote control to change to the proper input source. For example, if the source is a cable or satellite service, press the "Input" button until "TV" mode is selected. A component device, such as a DVD player, will operate on a different input source, such as "Video-1."
Check the coaxial cable, which connects your television broadcast service provider to your television. You need to securely connect the coaxial cable to the "ATSC/Digital Cable In" jack on the back of the television, and the other end to the wall jack. If the cable appears damaged, replace it with a new cable.
If you are using a component device as the source of your programming, ensure the component cables are plugged into the "Video Input" and "Audio Input" jacks on the back of the television or that the S-Video cable is plugged into the "S-Video Input" jack on the back of the television. Connect the other end of the cables to the "Video Output" and "Audio Output" jacks or "S-Video Output" jack on the component device.
Oct 02, 2010 | JVC AV-56WP84 56" Rear Projection...
I have a 19" phillips lcd tv and when i turn the tv on the phillips screen comes up but when it is going the show the channel it shut off by itself how can i fix this problem?
Hello. I may be able to assist you. If you are using a direct cable connection from the wall outlet;
  • Check the incoming cable or antenna signal connection to ensure that it is properly secured to the TV's antenna input.
  • If the connection is good, perform the automatic installation again to search for all available channels.
If you are using a coaxial connection from the Cable or Satellite box to the TV;
  • Set the TV to the channel specified by the service provider.
  • Change the channels at the Cable or Satellite box to view the program.
If you are using a video connection (CVBS, S-Video, YPbPr, HDMI) from the source (DVD, Cable or Satellite box) to the TV;
  • You do not need to perform automatic installation to search for the channels.
  • Press the 'SOURCE' 071218044349_22024.gif button on the remote control repeatedly to select the correct input source.
If you are using an HDMI connection from the source (DVD, Cable or Satellite box) to the TV;
  1. Reset the TV and source by unplugging it from the power outlet for 30 seconds.
  2. Turn on the TV and press the play button on your source device. If the source is HDMI CEC compliant, the TV will automatically switch to the HDMI input.
  3. If your source is not HDMI CEC compliant, turn on the TV and switch to the HDMI input.
  4. Turn on your source.
If you are sure you have selected the correct input or channel but still have no picture or sound;
  • Try resetting the TV by unplugging it from the power outlet for 30 seconds.
  • Press the 'SOURCE' 071218044349_22024.gif button to select the correct input source.
  • Check the connection cables.
  • Try the connected source with another TV.
  • Connect a different source on the same connection of your TV.
Dec 14, 2009 | Televison & Video
Change input source for philips magnavox
use the up/down channel until you get to the input you have connected. You did not say you had a remote so i am using the standard fix for this.
Thanks
Apr 28, 2009 | Philips 19PR19 19" TV
Sony Trinirton TV and DAV-HDX 275 System
Here are a couple of the most common reasons for your problem:
Make sure you have selected the right input source on the DAV-HDX275 that your TV station source (cable, satellite, direct TV or whatever you get TV stations from) is connected to on the DAV-HDX275.
Also make sure that if you are using a digital input (HDMI, optical, or coaxial) from the TV station source, that the DAV-HDX275 in set for a digital input and on the right source.
If you are using an analog source (red and white RCA jacks) for the TV stations , make sure you do not have the digital input activated for that source on the DAV-HD275. You need to select the analog option.
You must also be sure that you have a cable, whether it is analog or digital, connected from the cable box to the DAV-HD275.
I hope this was helpful to you, it is always very important to double check all the connections and make sure the stereo is set to the right type of input (digital or analog).
If you have found this to be helpful, a good rating is always appreciated. Thanks and let me know if you need any more help.
Jun 22, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Pt-47wxc43g tv
No ,
Fisrt I need more info, what source of input or you using, video 1, 2 etc... or is it your calbe connection input.
If you or using av cable's, witch I would, connected to source input 1 with video in and two audio in and go to the ptv menue and put in on source input 1.
This should work if it doesn't then you may have cabling problem, ptv problem or cable box problem.
First start by suspecting cable problem, swap the cable to see if you get picture, if not try a differenct source of input a dvd, it should solve your problem
Regards
What About Bob
Timmins, Ontario
Home of Shania Twain.
Mar 08, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Olevia LT37HVS 37 in. LCD HDTV Logo
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
