Turn on notebook (A200 2 years old). Runs fine for about 10 minutes then screen goes blank. if you plug in an external monitor both screens work. This is not an intermittent problem.
    Master:
  • 956 Answers
Have you check screen power down could be it is setup to shut down as you say after 10 mins. Access power through control panel, change settings ie to 30 mins
Fingers Crossed>?
Posted on Nov 14, 2009
I am trying to diagnose a problem with my son's laptop screen going blank. I shall try to describe the symptoms. 1. When plugged into an external monitor, everything works fine. 2.The laptop screen...
Have you check the cable that goes from the screen at the motherboard? Usually this cable is not visible; it is hidden it one of the joints between screen and main body of the notebook.This cable is the most common problem in the cases that the notebook keeps on working although the screen is black. You can check it by opening slowly - slowly the screen all the way up and closing again slowly. If there is a cut at the cable your screen will get black at a specific slope.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 31, 2010 | Dell Inspiron 6400 Notebook
I have an old HP Pavilion a1140n, it was working fine until one day the monitor went blank. The monitor is still good because I connected it to my lap top and it works fine. The problem seems to be with...
obsolete PC, HP has zero support on it
no OS, stated, XP? what XP - service pack 3?
no service tag presented.
sounds like mobo is e-machine, onboard video chip bad,.
yes, most mobo support an old VGA card not sold now.
only used, and must match your machines express card,
voltages, etc. called express level #
the must go to bios and change from internal video to external.
that part is tricky on dead screen. no?
find that card (old) and working used, is problematic, could take weeks to find one... why?
and old old Pentium 4 wow.
why no scrap the best and upgrade to a newer system.
one with SUPPORT?
10 years or newer,
can be had used for like $50 (the brick, no screen)
why mess with OLD IRON like this... time to move on.
no?
why spend a fortune on a PC worth $5 on the street
why?
ever go to GOODWILL>? see vast machines far newer, for NOTHING?
or here, amazing no?
and this, even new boxes are cheap.
H3LL less than one service charge at a shop. Geek something.
https://www.walmart.com/search/?query=desktop%20pc%20on%20sale
Mar 27, 2017 | HP Pavilion a1140n (PX774AA) PC Desktop
My hp dv4-1435dx screen is blank.It was on then it froze and then went blank. I have tried to fix it by removing the battery and replacing it a number of times. It comes on when started and plays the...
This could be due to presence of static charges on the notebook or hardware malfunction of the video card or defective LCD display screen of the notebook. To resolve the issue, perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check if the display works fine or not. Incase, if the issue persists, then the video card or LCD screen must have gone bad, and to isolate the same, please connect an external monitor to the notebook and check for the display on it. You can follow the steps below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your notebook is under HP warranty, then contact HP to get the notebook repaired for free of cost.
Jun 01, 2010 | HP Pavilion dv4000 Notebook
Blank screen,pwr sup appears to ok, fans runs, pwr light on
The issue seems to be due to defective video card on the notebook. Connect and external monitor to the PC and check if it works fine or not. You can follow the steps listed below to connect an external monitor.
If your PC is under warranty, contact HP to get available options to get the notebook repaired under warranty.
May 26, 2010 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
My laptop monitor goes out after windows loads.
Sounds like the backlight is broken If it works with an external monitor the backlight needs to be replaced will cost you about 100$ sorry
Nov 13, 2009 | Computers & Internet
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
May 21, 2009 | Dell Inspiron 9400 Notebook
External display not displaying!
When you are able to view a video clip on the external monitor, We can rule out the issue with the software. Probably you need to check the connections and also the external monitor settings in the display. The reload might have changed the old setup
Feb 03, 2009 | Dell Latitude D820 Notebook
Blank Laptop Screen
unplug everything from your laptop unplug the power from the laptop close it and turn it over remover the battery open and hold the on button(battery is still removed) for a 10 count, replace the battery
turn on you can plug the power cord if needed the prob. should be fixed
Dec 26, 2008 | Gateway MX6956 Notebook
Display Problems
your gpu has failed - thats graphics processing unit. new m/board required
Jul 12, 2008 | HP OmniBook XE3 Notebook
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
