Question about Eureka 5856BVZ Boss Bagless Upright Cyclonic Vacuum
My vacuum will only sweep a few minutes and then shuts itself off and it has to set for like a hour before it will turn back on
  • 1,056 Answers
Either the motor thermal breaker is bad or the motor is overheating causing it to do that.
Posted on Nov 14, 2009
Vacuum spits dirt out of the back end as I'm vacuuming.
Heather,Does the vacuum have a switch or a lever somewhere that makes it change from floor to hose? If so, it sounds like you've been using it on the hose selection but not actually sweeping using the hose. In other words, on an upright vacuum when sweeping just with the vacuum normally have the lever on floor setting and if you use the hose/attachments you have to have the lever on hose setting for things to work correctly. Hope this helps!
Deanna
Mar 28, 2013 | Vacuums
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
My Broan-NuTone central vac shuts off after I am vacuuming for a couple of minutes. I turn it off for about 10 minutes and start vacuuming again and it keeps shutting off. What is wrong with it? I...
Some of these units have had trouble with the motors and this is what causes them to shut off. NuTone has been pretty good about replacing them under warranty. 1-888-336-6151.
Aug 17, 2011 | Broan-NuTone VX475 Bagged Central System...
I have a dirt devil upright vision and when I am sweeping it will shut off like it had overheated or something. I will unplug it and let it sit for a few minutes and it will start back up and then after a...
Hi Cassidy. You are probably right about the motor overheating. The usual cause for overheating is a clog some where on the bottom of the machine. Check for anything that could be blocking the dirt fro going into the bag. Hope this helps Chris
Feb 20, 2011 | Dirt Devil Vacuums
Rainbow e2 2 speed vacuum shuts off after 5 minutes of vacuuming.
2 speed E2 models have a circuit board inside that controls the machine. It sounds like this controller board may be bad. The unfortunate part of this is that the board is not only very expensive, but it is only available from an authorized Rainbow service center.
Use caution if you decide to work on this yourself or if you take it to a service center that is not famliar with these models. The circuit board mentioned above is susceptible to damage from static eclectricity discharge. The static you generate from just walking across a carpet could make this board useless. So, if the original problem is not the board you could make the problem worse.
Jan 31, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Dies after a few minutes of vacuuming
The thermal cut-off in your machine is activating - this indicates that you have a blockage or a clog in the machine. The machine will turn itself off so that the motor doesn't overheat - the machine will cool off and you'll be able to turn it on after 30 mins to an hour.
Call the Dyson Helpline for a thorough blockage check - they know what they are doing.
Jun 15, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums shuts off during use
 My guess is: Either a loose contact on the plug  or Intermittent electricial open  in the electric cord itself. To confirm. Try wiggling the cord and ends while running. If you find the place yo ucan either replace the cord or repair it.
Dec 22, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Sounds funny/shutting off after few minutes
Yup! Clogged hose on the back of the cannister! Unit is designed to shut off for 30 minutes when this happens to protect your motor. Remove top of hose where debris enters the cannister through a filter above it, then remove the other end of the hose from the bottom of the back of the cannister, take it outside and use something long that'll fit inside the hose to force out all the clogged debris and hair through the top of the hose.
Oct 17, 2008 | Bissell LiftOff Revolution Pet Vac 37602...
I HAVE A BRAND NEW HOOVER MACH-3 CYCLONIC THAT CUTS OFF EVERY FEW MINUTES. IT IS DRIVING ME CRAZY! IT'S LIKE AFTER 5 MINUTES OF VACUUMING IT HAS TO SIT FOR A LEAST AN HOUR THEN YOU CAN VACUUM FOR ANOTHER...
If it were mine and it was brand new I would bring it back and exchange it. It sounds like the motor is over heating and shutting off automatically. Does not sound good. My advice return it.
Mar 16, 2008 | Vacuums
Eureka 5856BVZ Boss Bagless Upright Cyclonic Vacuum Logo
154 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
