12 volt Power souce
Power source
I would like help to locate an ignition wire to power a small dash mounted back up camera for a 2007 Chev. Suburban?
  • mystikguy Jan 09, 2008
    The camera has a wire that is connected to the back up lights .which is activated when the truck backs up. The camera is mounted on the dash with a 3 ft. ground and a power wire . What wire under the dash or side fuse panel will work only with the ignition?
  • 589 Answers
I don't recall there being a switched power source in the back, but I'm not 100% sure. Does it have the cigarette lighter jack in the back (for an air pump, etc)? That may or may not switch with the ignition.
If you want it to come on only with the backup lights, just tap into the power wire for the backup lights themselves.
Posted on Jan 08, 2008
  • brian c
    brian c Jan 09, 2008
    There "should" be a few empty slots on the fuse panel marked "IGN" or "ACC".
Mmy daughter gave me this camera when she bought new vehicle with back up camera.I donthaveinstallationbookorinstructionscanigetthisinfooncomputertoprintout
yes you can find generic info on this. most all the systems, no matter name brand, have the same basic installation.
you will need a 12 volt power source for the monitor. the camera power will come from the reverse lights power source(tap into the power at the reverse light), then you will need to run an rca style cable from the camera mounted position to the monitor itself.
so every time you put vehicle in reverse the camera comes on.
or you can wire the camera and the monitor through a switch and it will come on anytime the switch is turned on. but if you do this, the switch need to be wired to a ignition controlled power source.
Jun 01, 2015 | PEAK Back-Up Camera with 2.4 LCD Monitor -...
2002 chev impala, will not start. fuel pump and gauge not working on dash. When i go to start all lights go out on dash and than they will come back on in 3 or 4 seconds?
Have the battery tested if no good replace. Check for power at the starter cable and then while someone holds the key in the crank position check for power at the trigger wire of the starter. If you have power but no crank or click then you may have a bid starter or the engine is seized. If no power on the tarter little wire which comes from the ignition switch make sure you fuses and relay is good and that your ignition switch is working. If the battery tests good have your alternator checked as well.
May 14, 2014 | 2002 Chevrolet Impala
Suziki Boulevard C90 wont start, when hitting the ignition nothing happens, no power, no light, nothing are on, it's never put the ignition on.
ASSUMMING THE BIKE IS 12 VOLTS WITH A NEGATIVE GROUND;
1. with a voltmeter check across the battery terminals and see that it has about 12-12.6 volts. If it does not then charge or replace the battery first.
2. Check the fuses; most bikes have a main fuse coming off of the battery or in the fuse box.
3. If the battery and fuses appears ok, check for loose or corroded terminals. Also look for connectors and wires that are corroded and/or have a melted look.
4. If everything before this checks out ok, check for 12 power at the back of the ignition switch.
5. At this point it is best that you have a wiring diagram to determine which wires carry power away from the ignition switch. Turn the ignition switch on and continue to track the power wires to where ever they go. When the ignition switch is turned on it should have some wires measuring 12 volts coming off of the switch or the switch is bad. Continue to track wires until they reach there source or a point that no longer has 12 volts and that will be the problem area.
Apr 13, 2014 | 2005 Suzuki Boulevard C90
Add 12 volt outlet switched by ignition
Look in your owners manual for the accessory fuse. That line turns off. Also, consider a 12 volt relay between the seat and your power source. A small toggle switch will work well for a relay.
Dec 13, 2013 | 2005 Pontiac Montana SV6
My hyundia tiberon horn does not work
hotwire the connection to 12 Volts to see if the horn is short or its a lack of power to the horn. commonly the connection in the steering wheel comes loose. you can mount a horn switch to the dash stealing 12 Volts from any source and ground it, be sure to use proper gauges wiring 10 or 12....
Sep 04, 2012 | Hyundai Accent Cars & Trucks
2007 chev cobalt changed battery now radio doesn't power on at all
For radio related problem, check the radio help links .Click the link below to go through its procedure:----- How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
------------- Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
How to wire new car Radio?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
----------- After Market Stereo wiring?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash?
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
This will help.
Thanks.
Feb 28, 2012 | Cars & Trucks
The white, black & red wires located behind the face of the CD (the eject cartridge) broke away from the terminals on the small circuit board. What is the wire(s) orientation so I can reattach them? ...
Hello
I will give you a full rundown on how to install the cd changer;
Disconnect the car battery.
Run the cable from the Jensen changer to the back of your dashboard. Depending where you mount the changer, you might want to hide the cable under the carpet or run it along the door panel. Take some time before you mount the changer to figure out what is the best way to run the cable for your situation.
Remove your deck and the dashboard around it to access the back of the deck.
Locate the antenna lead plugged in to the back of your deck. Unplug it.
Find a good space to mount the FM modulator behind the dash and close enough to the deck to connect the antenna lead. You can secure the modulator to the inside of your dash by using two sided Velcro tape and place it where you need. Plug the antenna lead into the modulator's "Antenna In."
Connect the FM modulator to your deck by plugging the "Antenna Out" lead off the modulator to the antenna in on your deck.
Connect the two power cables from the modulator to your car's power. One lead goes to a constant source of power and one connects to a switched 12-volt power source.
Ground the modulator by running the black wire to an exposed screw. Wrap the wire around the screw and tighten it down so the wire doesn't come loose.
Reinstall your deck and dashboard.
Find a spot on your dash to mount the display unit. You can get creative and cut a hole in your dash and mount it that way or you can use Velcro tape and place it on your dash that way. Make sure it is close enough to the driver's seat so it can be accessed without having to reach too far. If there are loose wires hanging from under the dash you will want to tuck them under the dash and wrap them with wire ties.
Sep 12, 2011 | Jensen CH1001 10-Disc CD Changer
The radio will not hold memory
If your radio will not hold memory then you are lacking a constant 12 volt power source. Check the yellow and red wires at the radio. The yellow wire should be connected to a constant 12 volt power source (battery) and the red wire should be connected to a switch 12 volt power source (accessory or ignition).
Nov 23, 2010 | Pioneer DEH-2800MP CD Player
How to find positive power 12 volts and ingnition switch 12 volts
Should have said that in the first place. Use a test light and locate the wire that is hot on the ignition switch with the key off. (to avoid constant draw, turn the key to the "on position after locating the one that is hot all the time, then find the thickest hot wire on the other side of the switch that is hot in the "on" position. The switch itself is located on top of the steering column under the dash and generally is easier to reach if you remove the plastic covers and the bolts that hold the column on the dash. You can use any of those bolts to attach your ground wire.
Oct 13, 2009 | 2003 Chevrolet Silverado 1500
I need to find out the weiring diagrame to install it
Equalizers Like a crossover, the equalizer gets installed between your receiver and your amplifier. The outputs will be preamp connections to your amplifier. You'll find EQs that are designed to be installed in the dash, above or below your receiver. Others are designed to be mounted in a remote location, like the trunk. Either way, the wiring connections required will be the same. To install:
1. Mounting the equalizer:
A remote-mount EQ can be securely mounted with just a few screws. Anywhere between the receiver and the amp is fine. Most people mount the EQ in the trunk near their amp, especially if you have more than one amp. This also makes it easier to add additional amps later. You should mount it where it will be easy to get to so that you can make adjustments without too much trouble. Don't mount your EQ directly on steel — you will invite noise problems. Instead, install it on a non-conductive board and attach the board to the car body (or use rubber grommets under the screws to isolate the crossover).
An in-dash EQ can be mounted above or below your in-dash receiver, assuming that you have space available in the dash. This will require custom installation work. Another option is installation below your dash, in a universal under-dash mounting kit. To install the under-dash mounting kit, attach it to the mounting surface using the supplied self-tapping screws. In most cases, the use of an under-dash kit will require modifications to the kit or to the mounting surface.
3a-xover.jpg Locate the remote turn-on lead behind your radio (usually a blue wire). 3b-xover.jpg Connect the turn-on lead from your amplifier wiring kit to the blue wire. You can wrap the bare wire ends together and cover with electrical tape, or use solder. 2. Making the power connections:Your EQ will require 12-volt power, ground, and turn-on signal connections.
  • To obtain 12-volt power: Cut a length of small-gauge cable (16 gauge is typically sufficient) long enough to reach from the EQ location to your vehicle's fuse panel. Strip one end of the wire, and attach it to the EQ's power input. This may require a crimp-on connector, or bare wire might be sufficient, depending on the equipment you're installing. Route the wire from the EQ location to your car's fuse panel. Using a fuse tap, connect the wire to a source of switched 12V power.
  • To ground the EQ: Remove a bolt near the EQ mounting location. Crimp a ring terminal to one end of a length of small-gauge wire, and then bolt the terminal tightly to the vehicle's metal chassis. Scrape away any paint and clean the bolt location thoroughly. If you can't find a convenient ground screw or bolt, drill a hole for one — be careful not to drill into the gas tank or a gas or brake line.
  • Making the turn-on connection: In most cases, you can tap into your in-dash receiver's amp turn-on lead to get a turn-on signal for your EQ. Remove the receiver from the dash to access the turn-on wire (usually a blue wire). For step-by-step instructions on removing your vehicle's radio, see your vehicle-specific Crutchfield MasterSheet™, or read our In-Dash Receiver Installation Guide. Strip the insulation off a small section of this wire coming from the radio. Strip the insulation off another small-gauge cable that's long enough to reach from the in-dash receiver to the EQ, then connect the two with crimp caps or solder. Wrap the solder or crimp connection with electrical tape to guard against a short. Using wire ties to secure the wire, route the turn-on lead behind your dash all the way to the EQ mounting location.
3. Making the signal connections:
In most cases, you'll be routing RCA cables from your in-dash receiver's preamp outputs to the inputs of your EQ. While your receiver is out of the dash to access the turn on lead, connect a set of RCA patch cables (long enough to reach your crossover in its mounting location) to these outputs, taping them together so they won't come apart. Route the patch cables (again using wire ties) behind the dash, and to the crossover mounting location.
May 14, 2009 | Alpine Car Audio & Video
Computers & Internet Logo
77 people viewed this question
Alun Cox
David Payne
David Payne
