Does not turn on
When i plug my WD 500gb external hard drive into the outlet the blue light on the front turns on for less than a second and goes back off. and while that is happening, i can also hear it start to power up, and then it just shuts back off.
    Champion:
  • 206 Answers
Try to connect it to an other USB port. Sometimes the power of the port is just not right for some devices that consume a lot of power, like in your case. an other thing might be possible: that your USB cable is too long and that that is the reason of loosing signal
Posted on Nov 15, 2009
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
  • Project NOMAD
    Project NOMAD Nov 15, 2009
    SPECIAL NOTES
    USB flash drives can fail for no apparent reason.
    Sandisk Cruzers are especially bad for this.
    USB hard drives should be treated with extreme care.
    This is a real hard drive ! and knocks and bumps can quite literally kill them.
    Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
    Known as "The Click Of Death"
When I plug I my WD hard drive, the blue lights flash for a few seconds, and then it goes off. Any ideas what could be the problem?
If it is new contact WD for a solution under warranty. If not, go to My Computer in Windows and look to see that the drive shows up in the list.
Oct 24, 2013 | Western Digital My Book Essential 1TB...
1 TB My Book Live Western Digital, light starts up blue then after trying to discover goes red, tried new eternet cable and still going red. Reset my router and have tried plugging hard drive right into...
I have SeaGate FreeAgent GoFlex 500GB external hard disk and it shows only 230GB. I formatted it many a time but still shows 230 Gb only..Please help me to fix the problem....
Sep 11, 2013 | Western Digital WD My Book Live 1 TB...
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
I have a cavalry CAUE37500 500GB 2.0 that I have literally used less than 50 times since I bought it a few years ago. I haven't used it for the last 6 months, but thought it was a good time to delete...
> ticking of a watch ...
A typical sound from a disk-drive that has malfunctioned.
If it still has a valid WARRANTY, exercise the warranty to get it repaired/replaced.
If the warranty has expired, then open the case, remove the disk-drive, buy a new "compatible" disk-drive, connect it, and thus "revive" your external storage device.
Oct 23, 2010 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
My iomega 500gb external hard drive has a broken.
My Iomega (33654) 500GB USB isn't working. When I turn it on the blue light comes on for a few seconds. I can hear / feel it working but then the light goes off (it is still whirring inside). The computer isn't recognising it. I think it's still under guarantee but I can't find the paperwork. Do you have any ideas?
Apr 03, 2010 | Iomega (33654) Limited Edition 500 GB USB...
500gb element external drive doesnt power up i plug it into the outlet light turns on then goes off and nothing
sounds like the power addapter internally of the externall hdd has failed its happend to a few of my customers and usaly i convert them into internall hard drives for them simply remove the outer casing and install as a second internall hard drive if you really want to get it fixed a local pc shop might be able to help however its only 59.99 for a new 1 tb (1000gb) from maplands just a thought hope this is of some use to you
Mar 17, 2010 | Western Digital Elements powered by WD 320...
Western Digital MYBOOK 500GB external harddrive won't come on. When it plugs in, the blue light comes on for about a second. Computer does not recognize drive.
It is "dead". If it is still under warranty (check 'www.wdc.com' for details), then Western Digital will replace it. If not, check their web-site, for their "Customer Loyalty Program", i.e., since you bought one W.D. disk-drive, you can get a discount on buying another W.D. disk-drive, if you order online from W.D.'s web-site.
Dec 11, 2009 | Western Digital My Book Essential Edition...
SimpleTech external HD won't turn on
Get a new AC adapter for it. I had the same problem, & I had an AC adapter that was the same type for the modem & I tried that one & it was working again.
Feb 28, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
Computers & Internet Logo
265 people viewed this question
David Payne
David Payne
