Question about Texas Instruments TI-84 Plus Calculator
Can't read the screen
For no reason at all, I can no longer read the screen. I can tell it's on but the typing is really, really light.
  • Mel77 Jan 09, 2008
    Thanks!!!!!!
  • emilyle Oct 04, 2008
    When ever i turn on my calculator the contrast immediately begins to lighten from really dark, until its so light that I cant even see it.
    help please?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
That's just the contrast and brightness of your screen. all you need need to do is to hit 2nd and then hit the up arrow. you will need to do this several times for it to get darker. Everytime you do it you need to hit the 2nd key and then the up arrow.
Posted on Jan 09, 2008
How do I respond to a "the type of print head is incorrect install correct print head" message?
Usually that type of message means either the print head was not a Canon authorized print head or the chip that the unit reads is damaged.
All you can really do is ask for a refund from where it was purchased, or get another one from a Canon authorized retailer.
"Never purchase a reconditioned print head, for exactly this reason" Be aware of "Pirates" who call you, ask you what type of printer or copier you have and as soon as you tell them, they all of a sudden have what you need at a huge discount. Its a rip off.
Jun 18, 2015 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Why is the tv picture red?
Video output section circuit fault. This fault can be caused by many reasons, and called technically 'one color predominant screen'. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Mainly, loose solder terminals at the video output card can cause this. You have to look for it first. This car can be located at the neck of the CRT, will directly plugged to its back. Reasons for this can be read in detail by the above linked site. Surf it with type in "one color predominant screen"
Jun 15, 2014 | Emerson EWF2004 20" TV
Need to deactivate service engine soon light on my 2009 eclipse
  • When that light comes on it is telling you there is something that needs to be addressed. If you go to your local major parts store they have a code reader that can tell you the codes and allow you to further diagnose the reason for the light in the first place. However if you really just want to turn it off then just have them read and then clear the codes. The light will go off but if the problem is persistent then the light will return.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 08, 2011 | 2009 Mitsubishi Eclipse
Check Engine light is on solid. The car is running fine. How do I check what is the reason.
A local shop will charge but auto zone o really advance etc will scan for free it has a code stored when the light stay's on.
Nov 01, 2010 | 2004 Honda Civic
The check engine light comes on all the time now and the Audi service dept constantly tells me it could be a 1000 reason why it continues to come on and each time I take it to the service dept, it cost me...
There really are 1000 reasons the check engine light is coming on. If you keep resetting it and it comes back on, and it is not affecting the engines performance it is more than likely a faulty sensor. But thats just 1 of the many reasons. They want to keep you coming back so unless you tell them to fix it. They are going to be very vague. Get the obdII software and reader is the best thing I can tell you. Then you can read the code that is tripping the CEL. Hope it helps!
Jun 25, 2009 | 2004 Audi A8
Acer 4520 light going dim
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
Disc player does not work
Try using a cleaning disc, run it for about 20 to 30 seconds. If that does not help you do not really have any other options, RCA does not sell parts for the audio equipment anymore. They stopped about a year ago or more. I work at a authorized RCA service center and we can not repair any of the RCA audio equipment because of this.
The problem with your CD player is most likely the laser pick up, when it goes bad it can not read the disc's so it thinks there is no disc in it. The laser pick up is the most common reason for your type of problem.
If it is under the RCA warranty still you can send it to them and get a free replacement, if not under warranty you may as well trash it and buy a new one from a different manufacturer. The RCA audio equipment is not very good quality. That is the reason they no longer offer parts for them, it is cheaper for them to give you a new one than to pay a service center to fix it.
Jul 12, 2008 | RCA RS2650 Shelf System
I am trying to install a photosmart all in one C5180 on my pc running Vista. It keeps saying that the program cannot be installed as use by and asking me to log on as the Administrator. I AM the...
This is normal with Vista, Vista log in users as standard (not Administrator privileges) , then ask if to run programs as administrator for security reasons. Once you tell the system to run program as administrator it should install with no problems.
If you really cannot install the program, you can restart computer and login as administrator:
At the "pick a user to login" screen, hit CTRL-ALT-DEL to get the classic login screen. Then you can type in Administrator for the user name, default password is blank.
Read here for more.
Jun 08, 2008 | HP Office Equipment & Supplies
My ps2 wont read any discs but it plays music discs and cd's
Hi Cozza,
Open the console up, and remove the cover over the Cd drive. Clean the lens of the Laser with a Q-tip lightly dampened with Rubbing alcohol. Use the dry tip of the Q-tip to dry the lens, look to see if you left any lint, and make sure the lens of clean.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
Texas Instruments TI-84 Plus Calculator Logo
231 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
