Question about Toshiba RD-XS32 DVD Recorder
Remote control I have a toshiba Rd xs32 dvd recorder when I came to change in book on remote control i changed to RD2 it was already on RD1 now I cannot use the remote control and when I go to the recorder it works fine but no editing and if I press the instructions to find the RD1 again all I get is RD off or RD2
  • stephew Apr 06, 2009
    similar problem. My device stopped switching to correct channel to record on timer. I stupidly went to setup and changed IR to 3...(was on 1). Now remote doesnt work. That's useful. I tried the set-up + [1] (and +2 for good measure) but it didn't help. anyone else can help?
  • stephew May 11, 2010
    i tried again and it worked!
  • 3 Answers
Lift up the flap on the remote. Press setup and 2 at the same time. This will activate your remote to RD2 the same as your recorder.
Posted on Jan 09, 2008
How to play a dvd on toshiba hdd xs32
You must use the input setting and select dvd. Thanks.
Aug 22, 2014 | Toshiba RD-XS32 DVD Recorder
Every time I try to use the remote on my Toshiba RD-XS32SU Video Recorder I get the following code displayed on the unit: DR-OFF I do not know what it means and how to resolve the problem.
It is confusing to many people this function, but not impossible to investigate (perhaps experiment with some of the functions). You can get a copy of the INSTALLATION GUIDE (if you don't have a copy for any reason) from the following:
http://tacpservice.toshiba.com/consumerproductsupport/Manuals/dvr/RD-XS32SU_Inst_E.pdf
and if you don't have a copy of the original OWNER'S MANUAL, you can also download that from the following:
http://tacpservice.toshiba.com/consumerproductsupport/Manuals/dvr/rd-xs32_om_e.pdf
(copy and paste into your browser if required - these are both FREE documents)
(Page 48 of the installation guide (not the owner's manual) tells you about IR CODE setup option using remote - read that first if you like, then try your recorder).
Hopefully this helps you a tiny bit.
Mar 23, 2011 | Toshiba RD-XS32 DVD Recorder
I have a Toshiba RD-XS27KE DVD/VR. It does not perform any recording on the HDD - error code E49. I have deleted titles and it still does not record. What can I do ?
I fixed it by 1. delete all on HD drive (a function described at the end of your manual) 2. turn off your recorder 3. turn on your recorder 4. now should E49 not be vivible and recording function again
Jan 31, 2011 | Toshiba RD-XS32 DVD Recorder
Fault code ER 7071 on Toshiba HDD drive model
TENGO UN TOSHIBA DVD RECORDER Y EN LA PANTALLA TIENE UN ERROR ER7071, COMO PUEDO ARREGLARLO?
Oct 04, 2009 | Toshiba RD-XS32 DVD Recorder
Don't know how to set channels w/new cable box.
Use channel 3 or 4 or hook up the RCA jacks. If you use 3 or 4 leave it on that channel and use the cable box to change channel. Use RCA jacks (best) turn the channel on the recorder to line in ether LINE1 or LINE2 with one you plug it up to and leave it on that channel.
Jul 23, 2009 | Toshiba RD-XS32 DVD Recorder
A/V Signal Outout through Onkyo TX-SR705
Are you trying to record cable programming with your DVD recorder? If so, you might want to try using component cable as HDMI does have a copy protection circuit that might be preventing your recorder from receiving the image. Just try to connect the cable box component (RED/GREEN/BLUE) cable to your DVD recorder. If that doesn't work, then try to change everything over to component cables. HDMI is a great cable to use but it the only required to display 1080p images and the only current source that uses 1080p is a bluray player. Everything else, such as your cable box and DVD recorder is 1080i and component cables are perfect for it.
Mar 14, 2009 | Toshiba RD-XS32 DVD Recorder
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ? I have the...
Got the same problem today. I found the solution online on the installation guide. You need to push the two channel changing buttons on the recorder at the same time for 3 seconds.
Jan 11, 2009 | Toshiba RD-XS32 DVD Recorder
Toshiba rd-xs32
i've attached the hd to my pc but when i put it back again on my dvd toshiba i got 7034 error and it stop i cannot access no more in my dvd recorder and i didnt see my recording movies on my pc too.please help me very urgent thnx.
Oct 19, 2008 | Toshiba RD-XS32 DVD Recorder
I am unable to find dvd disks that will record to my two toshiba dvds RD-XS32 OR RD-XV45 CAN YOU HELP
RD-XS32
DVD-R
DVD-Rw
http://www.videohelp.com/dvdplayers?DVDname=RD-XS32&Search=Search&dvdportable=&dvdchanger=&dvdtv=&chipset=&orderby=Name&hits=50
RD-XV45
DVD-R
DVD-RW
The link tells you about the first player. It says that this player is really picky with discs but people have had success with 4x vertabrim DVD-R discs. The link also has some information on a firmware upgrade to improve the DVD-R/RW selection of discs which the player accepts. Coudn't find much on the second player though other than a french manual which told me what it accepts which i've put above. Hope this helps.
Aug 19, 2008 | Toshiba Televison & Video
Not copying program
I updated my firmware from 1413 to 1416 found on avforums. This is for european units. I suggest you also complain to Toshiba Japan as there are known issues with the xs32. We all need a firmware update. See AVforums.
My unit will not recognise RAM discs anymore - even those that I had previously used.
Have you thought of replacing the DVD drive. See AVforums.
Sep 06, 2007 | Toshiba RD-XS32 DVD Recorder
Toshiba RD-XS32 DVD Recorder Logo
222 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
