Question about Sony Mavica MVC-CD500 Digital Camera
My camera is stuck on USB mode no matter what I do,if i turn it off and back on its still stuck in USB Mode no matter what setting it is on
    Brigadier General:
  • 11,967 Answers
Try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Posted on Nov 14, 2009
What mode should camera be in to upload pictures does it matter if you connect usb cable to ccamera or computer first
It should be in playback mode. It doesn't matter if you plug in camera first or computer first but it does matter that you have to first install the proper drivers for your camera on your computer. The proper drivers is on the CD that came with your camera. Install that first before connecting your camera to your computer. Personally, I don't like to connect camera to computer unless I'm doing an update to the firmware. I would suggest buying a USB memory card reader if your computer/laptop doesn't have one already. Then I upload my pictures by removing the memory card from the camera and plug into the USB card reader. Best of luck.
Feb 28, 2011 | Canon PowerShot SD1000 Digital Camera
My screen is blank (white) and has USB on the upper left corner... i lost my usb cord and it wont let me take pic's or use any of my buttons. What should I do?
Try taking the batteries out for about an hour, put them back in and try it. It seems to be stuck in USB mode which can only happen with a supply voltage of 5 volts coming IN the USB socket. Hopefully that will allow it to turn on in camera mode again.
Dec 05, 2010 | Fuji Finepix J50 Digital Camera
My Moultrie I40 seems to be stuck in set up mode. won't advance to Auto. test button brings back error 4800. Tried calling their customer service, no matter what extension i select i just get hung up on.
what does battery % say? twice this prob was solved by using good brand new bats; might try removing bats with cam on; turn cam off; replace bats and power up. Wait until setup screen is on before pressing mode.
Aug 09, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
DMC-TZ5 is stuck in USB mode
Try a total reset on your camera/?
Apr 03, 2009 | Panasonic DMC-TZ5 Digital Camera
Ccdtrv608 sony handycam stuck in nightshot mode
Below image of CCD-TRV608 shows NightShot Button location, turn it Off for normal mode recording.
Mar 24, 2009 | Sony Handycam CCD-TRV68 Camcorder
A630 clicks and wont take picture. Stays in preview mode.
Do you mean you are expecting it to show the photo that you just took for a few seconds before it goes back to preview mode? There's a menu setting which I think is called "Picture Review" and you can set it for something like 0, 2 seconds, 5 seconds, something like that.
I hope that was it.
-Vince
Oct 01, 2008 | Canon PowerShot A630 Digital Camera
Can't get out of USB mode
You most likely need to change a setting called USB Connect under main settings 1.
Page 67 of http://pdf.crse.com/manuals/3208400121.pdf
Default is auto
I suspect it is set to mass storage and is causing your hassle
Mar 04, 2017 | Sony Cyber-shot DSC-W200 Digital Camera
Finepix stucked in USB MODE
try taking out the battery and the memory card on your camera, then reinstall everything and turn it back on. lets see if that will help..
Apr 09, 2008 | Fuji FinePix A340 Digital Camera
HP Digital Camera - M425 - Stuck in review mode, won't switch to capture mode
I just fixed my daughters camera with this problem. First go to the capture mode and see if the reason you are in review mode is because the camera thinks it is docked. If so, look at the dock port on the bottom of the camera. ( May need to magnify it to see in there ) Look for any green corrosion between the contacts. Her's has this corossion between two pairs of the contacts. I took a jewelers screw driver and scraped out the corrosion and then blew canned air in there to remove it. Turned it on and now it works fine. I have a feeling that the battery compartment is venting through this port and the small amount of acid vapor produced as the batteries discharge is causing the contacts to get this corrosion.
Jan 13, 2008 | HP Photosmart M425 Digital Camera
Camera Wont turn On: Is it stuck in USB mode? How do i fix it?
I was able to get past this problem by removing and reinserting the battery. This caused, in effect, a hard reset of the camera, which let me power it up fresh and take pictures again. Of course, it's not exactly reassuring that the problem arose in the first place,
Jimmo
Nov 04, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Sony Mavica MVC-CD500 Digital Camera Logo
235 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
