Question about Kenmore 57029 Side by Side Refrigerator
Icemaker isn't making ice - Kenmore 57029 Side by Side Refrigerator
  • 22 Answers
You need to make ice , water (make sure it's on) power, the switch (leaver to activeate it) control board some has to tell it when the ice is done
Posted on Nov 14, 2009
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Tip
    How to repair an ice-maker of a refrigerator
    An icemaker receives water through a small, 1/4-inch water supply line that runs from the refrigerator to a water pipe, where it is connected by a tap valve. The water supply line enters a valve in the refrigerator that is controlled by an electric solenoid that sends water through a fill tube into a mechanized icemaker assembly. There, the water freezes and is dumped into an ice bin. When the bin is full, the ice lifts a bail wire that turns off the icemaker. If the water’s route is blocked or the solenoid doesn’t work—or if the bail wire is lifted—the icemaker won’t make ice. (Also note that your home’s water pressure must be strong enough to serve an icemaker.)
    Here are a few steps you can take to get your icemaker working (be sure the bail wire above the ice tray is in the down position):
    1) If the icemaker doesn’t make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is finished, the water valve is asking for water that isn’t arriving. This means the valve and the solenoid are probably okay, but the water supply is not. Be sure the water supply line isn’t kinked behind or beneath the refrigerator (1/4-inch copper tubing is much better than plastic fill line).
    2) Check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
    3) Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
    4) Check the tap valve; a bad tap valve may cause the problem where the icemaker’s supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the “self-piercing” type). You can do this yourself, or call a repairperson or plumber to install an inline water filter when replacing the valve.
    5) The water line attaches to a solenoid at the back of the refrigerator and then travels to the icemaker. The solenoid may be defective or may not be receiving power. You can try removing the sediment screen inside the solenoid and flushing it with water to clean it, and at the same time you can inspect any seals or diaphragms to ensure that they are sound. Unplug the refrigerator first. Unless you’re skilled at home repairs, this job is better left in the hands of an appliance repairperson.
    on Sep 02, 2010 | Refrigerators
    Floor was soaked with water then our icemaker quit working. what could be wrong
    I had that happen and it turned out the cat had bitten through the water line that feeds water to the icemaker. Water had gushed out of the line onto the floor and since the icemaker couldn't get any new water to make ice with, it quit working. A clog, the line simply coming disconnected or a different kind of pet going after the line could also cause this problem. Luckily, a new line isn't expensive, and if you rub some habanero sauce on it, the cats and the rabbits both leave it alone.
    Aug 31, 2012 | Kenmore Side by Side Refrigerator
    My Ic13b icemaker but when ice tray is full it still adds water to icemaker causing it to overflow and freeze on bottom of freezer
    either your ice maker is calling for too much water or the water valve isn't shutting off when the ice maker tells it too. The best thing to do is to change both the ice maker and the valve because if one is defective more than likely thee other will fail shortly
    Jun 05, 2012 | Amana Refrigerators
    Subzero 501F icemaker slow in making ice
    More thatn likely, being thats an older model, you are low on freom and the temperature isn't cold enough for the icemaker to keep constant production up. You maybe thinking the freezer is fine because stuff is frozen in there but that is why most people don't catch the problem until they lose all their food. The temperature for the icemaker to even come on is 10 degrees F. The sub zero freezer temperature should be around 0. Check your settings and make sure they are turned down but I would get a thermometer and put in the freezer and check to see what it says. If its above 5 degrees F check your condensor coils to make sure they are clean and also see it the condensor fan is running. If dirty, clean the coils and see if the temperature drops, if not call a service company.
    May 03, 2012 | Frigidaire Refrigerators
    Icemaker making noise
    check that there isn't any ice stuck inside the icemaker teeth.
    Apr 24, 2012 | Whirlpool Ice maker 4317943
    Ice cube tray won't stop making ice.
    This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
    Thank you
    Rick
    Mar 12, 2012 | Refrigerators
    KitchenAid 25in KSRJ25CNST00 icemaker trouble. The LED light on side of freezer is blinking twice with a delay and repeats same sequence. No ice is making. Any suggestions on what to look for?
    Try the reset button on the control panel. If that doesn't work, then try unpluging the refrigerator.
    Also, make sure that ice tray shut off arm isn't in the up position. It should be in the unlock position one notch below the off position. This arm is used by the refrigerator from over filling the ice cube holding tray. Once the ice fills the tray. The ice in the bend will push up on the arm which
    initiate the ice maker to stop making ice. As soon as you start using the ice in the bend and the arm falls below the off position. The ice maker will start making ice. GB....stewbison
    Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
    My ice cube maker isn't making cubes,but I still get water
    hello,
    In a case like that usually the problem is going to be a cooling issue, is the fresh food and freezer section both cold? it obviously takes water and freezing tempatures to make ice.
    2 things to check are
    1) the condenser coil under the grill below door or on back depending on model is clogged with dust and needs to be cleaned
    2) the fan in the freezer isn't running circulating air into ff section and directly onto icemaker
    Good luck, i hope this helps
    Gene
    Jul 31, 2011 | Kenmore Side by Side Refrigerator
    Whirlpool fridge ice maker not working. ice begins to form but isn;t dispensing. melted ice in case was stuck, little prongs are down
    You need to replace the icemaker . Probably the mold heater is bad but it cant be changed .
    Aug 26, 2009 | Refrigerators
    Kenmore 57029 Side by Side Refrigerator Logo
    118 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    ka4iup
    ka4iup
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
