Question about Microsoft Xbox 360 Console
New xbox. turned on and message read lets get
New xbox. turned on and message read lets get started. select language so i pressed green button and nothing happened.everything is connected as it should be
  • 456 Answers
Try using another controllor or plugging the controller in using a plug and play charger cord, the problem may be either the controller or the wireless receiver on the xbox. Good luck.
Posted on Nov 15, 2009
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Sep 06, 2016 | Laser Office Equipment & Supplies
Error Code 51.2 C on an HP 4600
This is a laser error. I found this directly from HP's website. Here's your fix:
  • Press the green c00224695.jpg (Select) button to continue.
  • Turn the printer off, and turn it on again.
  • Perform a cold reset.
    1. Turn on the printer.
    3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
    4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  • If this message persists, contact an HP-authorized service or support provider. Please let me know if this helps you!
  • Oct 01, 2011 | HP LaserJet 4600 Printer
    How do I get my xbox information to go back to english and reset my settings?
    To set or change the default language on your Xbox 360 console
    1. Turn on your Xbox 360 console without a disc in the disc tray.
    2. On the controller, press the Guide button to go to the Xbox Dashboard.
    3. Select Language, and then select the language you want to use.
      Then format the hard drive to reset EVERYTHING. This will erase all data and reset all settings.
      To format a storage device
      1. Start your Xbox 360 console without a disc in the tray.
      2. On your console, go to My Xbox, and then select System Settings.
      3. Select Memory.
      4. Highlight the storage device that you want to format, and then press the Y button on your controller.
      5. Select Format.
      6. You receive the following message: This will delete all content on this device. Do you want to continue?Choose Yes to format the storage device.
      7. If you are asked to enter your console serial number, enter your number, and then select Done. This step helps guard against accidental formatting.
        The console serial number is located on the back of the console and behind the oval door on the front of your console.
    Jul 24, 2011 | EA - Electronic Arts Video Game Consoles &...
    Code ereur 59
    A code error 59:
    Description A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly. Action
    1. Press the green c00099346.jpg (Select) button to continue.
      3. When the memory starts counting, press and hold the green c00099346.jpg (Select) button.
      4. Continue holding the green c00099346.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
      6. Press c00099347.jpg (Down Arrow) button once. The control panel will display COLD RESET.
      7. Press c00099346.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
    Mar 02, 2011 | HP LaserJet 5550DN Printer
    Wireless controller wil not sync with xbox 360
    turn on the console. let it start up all the way. turn on the controller. on the console to the right side of the two memory card slots is a little button. press and hold it til the green lights start flashing around the power button. there is a little button on top of the controller. when the lights around the power button are flashing, press and hold the button on the top of the controller til the lights around the center button start flashing and then it should sync together
    Feb 18, 2009 | Microsoft Xbox 360 Wireless Controller
    My son did something when he was playing the xbox and now its not in english and he cant play it.can you help me put it back in english please
    1. Start your Xbox console with no disc in the disc tray. The Xbox Dashboard appears.
    2. On the Main Menu screen, press the directional pad (D-pad) down two times to select Settings, and then press the A button.
    3. On the Settings screen, press the D-pad down one time to select Language, and then press the A button.
    4. On the Language screen, press the D-pad up or down to select the language you want, and then press the A button.
    5. Press the B button to return to the Main Menu screen.
    Jan 31, 2009 | Microsoft Xbox Console
    Not english
    Note If the current language setting of the Dashboard is in a language other than English, the following steps will still work but you may not be able to read the menu options. If this is the case, you must follow the directional pad instructions exactly to make sure that you select the correct option.
    Jan 17, 2009 | Microsoft Xbox Console
    Resetting the language on an Xbox
    1. Start your Xbox console with no disc in the disc tray. The Xbox Dashboard appears. 2. On the Main Menu screen, press the directional pad (D-pad) down two times to select Settings, and then press the A button. 3. On the Settings screen, press the D-pad down one time to select Language, and then press the A button. 4. On the Language screen, press the D-pad up or down to select the language you want, and then press the A button. 5. Press the B button to return to the Main Menu screen.
    Rate if this helps :)
    Nov 05, 2008 | Microsoft Xbox Console
    Hp color laser jet printer 3000n
    Try this. BTW, the Button with the "Check Mark" is the Enter button on this.
    1). Switched the printer off.
    2). Press and hold Enter button while turning the printer ON until CONFIG LANGUAGE appears in the Display.
    3). After the power-on self test, lang=English (French, in your case) will appear. Press + button until the desired language (English) appears in the display.
    4). Press Enter button to save your choice. An asterisk (*) will appear next to English to indicate it is now the default.
    5). Press Online button. The On line indicator will be lit, and display messages will now be in English (you selected).
    if that doesnt work try this
    press...
    green enter button once
    right grey arrow button once
    green enter button twice
    then grey arrow button on right or left of green enter button until you see the language you want.
    Select by pressing green enter button
    Finished.
    Jan 10, 2008 | HP Color LaserJet 2600n Printer
    X box 360
    Make sure the headset connector and the headset jack on your controller are free from dirt and debris, which may interfere with sound transmission. More importantly, ask your fellow gamers and conversants to check their connectors, as the poor sound you hear may well originate from someone else's headset. 1. Examine and then clean the Xbox hardware. To do this, follow these steps:a. Examine the headset, the cord, and the connector for visible defects. b. Make sure that there is no dirt or debris on the Xbox 360 Headset connector. ? To clean the connector, use a cotton swab dipped in rubbing alcohol. c. Verify that the Xbox 360 Controller operates correctly. ? Verify that you can use the controller to turn the console on and off. d. Firmly insert the Xbox 360 Headset connector in the expansion port under the directional pad (D-pad) and the right stick on the controller. e. If this does not resolve the issue, go to step 2. 2. Test the headset. To do this, record and then listen to a new voice message. To record and then listen to a new voice message, follow these steps:a. Press the Xbox Guide button on the Xbox 360 Controller. b. Select Messages, and then press the A button. c. Select Create New, and then press the A button. d. Select Message, and then press the A button. e. Select a gamertag, and then press the A button. f. Select Add Voice, and then press the A button. g. Put on the Xbox 360 Headset. h. Select Record Message, and then press the A button to start recording a message. i. Speak clearly into the microphone and record your voice for 5 to 15 seconds. j. Press the A button to stop recording. k. Select Play Message, and then press the A button. l. Listen to your recording. ? If you can hear the recorded message, your headset is operating correctly. If the headset still does not function correctly when you use the headset on Xbox Live, you may have to configure Family Settings. Go to step 3. ? If you cannot hear the recorded message, your microphone may be muted, or the earpiece volume may set too low. Verify that the controls are adjusted correctly. 3. Configure Family Settings. Note If you set up a profile for a child on the console, Family Settings lets the owner of the parent profile control who can communicate with the child profile on Xbox Live. In Family Settings, you can enable communication in the child's profile. The default setting for gamers who are under 17 is Friends Only. To configure Family Settings, follow these steps:a. In the Xbox Dashboard, select System, and then press the A button. b. Select Family Settings, and then press the A button. c. Select Xbox Live Controls, and then press the A button. d. Select the child?s profile, and then enter the password of the parent?s profile that is associated with the child's profile. e. Select Privacy and Friends, and then press the A button. f. Select Communications, and then press the A button. g. Select one of the following options: ? Everyone This setting lets you communicate with anyone on Xbox Live. ? Friends Only This setting lets you communicate with people who are on your friends list only. ? Blocked This setting blocks all communication with the headset. Note With this setting, you can still receive new friend requests. h. After you select the option that you want, press the B button until you return to the System section.
    Sep 20, 2007 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
