Question about Clarke Air Tools & Compressors
Replcement for starting Capacitor - Clarke Air Tools & Compressors
  • 585 Answers
The ratings should be stamped on the capacitor. Shop for one of similar ratings at Grainger or a similar vendor.
Posted on Nov 14, 2009
I have a30/06 1903 rifle serial no.1470616. how do i get a replcement barrel?
start by calling local gunsmiths. If you have to ask that question there is little doubt that you should not attempt doing it yourself.
Nov 18, 2014 | Optics
Tip
Wiring up a compressor + start kit
If there is an identifying mark on one side of the capacitor such as a Dash, Red paint or arrow pointing one direction that will be the run side of the capacitor, if no marks you can use either side for start or run.
If you have three terminals on the capacitor you have a dual capacitor, (C = RUN compressor and fan) (HERM = compressor start) and (FAN is fan start wire).
The Start wire goes to one side of the run capacitor it will be the only wire on that side of the capacitor.
The Run wire goes to the terminal side (T2) of the contactor, it will have another
wire from that terminal to the run capacitor which is the opposite side of the start wire.
The Common wire will go to the other side of the contactor (T1).
Start Kit
Start from the capacitor to terminal #1 on start relay There should be another wire from
here to start on the compressor.
Common from contactor (T1) to terminal #5 on start relay. There should be a wire from this terminal to the Common terminal on the compressor.(there will not be a capacitor in this circuit)
Run from the other side of the contactor (T2) to the start capacitor and from the other
Side of the start capacitor to terminal #2 on the start relay. There should also be a wire from this
Terminal to Run on the compressor.
on Jan 24, 2010 | Heating & Cooling
Is magnetron replacement procedure difficult ?
It should not be too difficult, but the fault could also be a failure of the HV transformer or the big capacitor in that circuit.
http://www.repairfaq.org/sam/micfaq.htm
As you may be aware, the main precaution is to make sure the HV capacitor is fully discharged before you work on that circuit.
https://www.youtube.com/watch?v=OFFzS1a6k5g
Some have a self discharge resistor, but that also can fail. Here is a typical circuit
http://www.microtechfactoryservice.com/images/doubleranim_a.gif
and the diagram for your unit may be pasted to the inside of the casing. If you are sure it is the magnetron, you only have to discern the mechanical fixings of it after that.
Mar 22, 2014 | Bosch Microwave Ovens
Replcement stand
There is 5 on ebay, I just typed in (Coby TV stand).
Jan 22, 2013 | Coby LEDTV2326 23 TV
Buick fuel check valve replcement
Do you have an OBD Code present & what is it?
There is nothing called a fuel check valve
Dec 05, 2012 | 2002 Buick LeSabre
When trying to start it just makes a clicking sound
battery boost if still clicks starter needs replcement
Feb 16, 2011 | 2003 Volvo S60
Dvd replcement acer 5050
Most laptop drives will work if they have the IDE interface. The only difference in them is the little tab on the back where the hold down screw keeps them in place. These tabs are interchangable so that any drive will work in another. Just make sure that there are drivers for it, windows has most device drivers though especially if you are harvesting the drive from another laptop that has been run on windows. The only other thing to do is change the bezel, they simply snap off and on.
Jan 31, 2010 | Acer Aspire 5050-3242 Notebook
My goodman electric/gas pack started smelling like burnt motor then stopped blowing then shut down. Blower motor? (yes /no) What is replcement procedure..
(yes/no) verify the motor is bad by volt, amp draw, and ohmmeter. if bad, the repalcement is fairly straight forward the entire squirrel cage assembly is removed, cleaned, new motor and capacitor installed and then wired back in. Goodman has a five year warranty program on many of it's units, verify before spending money on a motor
Jul 06, 2009 | Heating & Cooling
Compressor
pls check compressor capacitor and compressor termonal connection start the unit check the voltage at the compressor terminal if is ok means copmressor need replcement
Apr 27, 2009 | Dometic Rooftop RV Air Conditioner
Mother board
hi for a total handset replacement if u are in warranty period u can claim this with the purchase bill in any of the sony ericsson authorised showrooms.. and they will replace u with new handset... thank u rate me!!!
Feb 09, 2009 | Sony Ericsson K850i Mobile Phone
Air Tools & Compressors Logo
88 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
