Two computer Lan. Both see internet through router, Main sees little computer's files but little can't see Main computer at all. Main is hard wired to router, little is wireless to router. Windows XP.
  • rbarbarin Nov 14, 2009
    Neither computer has "use simple file sharing" option, nor anything like it. (XP, SP3). Sharing on main computer setup OK. System has worked in past, something blocking it. Turned off Firewall, no change. Any other programs interfere? I gather that since signal gets to router from little computer, problem is at main Computer?
    Thanks for help.
  • 2,567 Answers
You will have to first enable Simple File Sharing on the main computer so that the little computer could see & access files on the main computer. To do this:
1. Open "My Computer".
2. From the "tools" menu, select "Folder Options".
3. Click the "View" tab.
4. Scroll down to the end of the list of options. Make sure that the "Use Simple File Sharing [Recommended]" option has a check mark opposite to it.
5. Click "Ok".
After that, go to the drive or folder you would like to share on the main computer, right click it & click "Properties". Go to the "Sharing" tab, select "Share this folder" & write down the share name. After that, click "Ok".
You will have to repeat this for each folder you would like to share on the main computer.
Posted on Nov 14, 2009
Can I connect my Pocket Wi-Fi to a Router with USB Port so that I can share my internet connection to my other computers.
Normally any new router with a USB port is only for USB memory sticks to share file across the network. Not for feeding internet into the unit (router).
It should be possible if you had a wifi "repeater" with Ethernet outlets, if what you are trying to do is hard wire the other computers.
The pocket wifi would wifi to the repeater, then the repeater would feed the Ethernet to the computers.
Jan 21, 2015 | Computers & Internet
Connecting a Linksys WRT54GL. no internet connection detected
The ISP modem connects to the main LAN port on the router. The PC connects to any other port. Done. You should have internet via wire at this point.
Feb 12, 2013 | Linksys Wireless-G WRT54GL Router
How can i cascade a Comtrend CT-5621 with a Netgear Wnr2000v3
works best if you hard wire from LAN port of main router to LAN port on second router. 2nd router never has anything plugged into internet port. 2nd router has dhcp turned off. 2nd router has a ip inside the 1st routers ip range but not the same as anything else
Jul 06, 2012 | NetGear WNR2000 Wireless Router
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
I've got a Linksys WRT160N V2 router that stopped connecting to my modem last night. If I plug my computer directly into the modem, I can get Internet access, but if I plug the router into the computer and...
I had the same problem and found that the port was damaged and change to another port and work fine but after a few days working file it drops back again and no internet again. Tried all the other ports and no result. I found out that something is going wrong with a part in the router and when it heats up the problem repeat.
So my solution is Buy another router and my choice went to:
TP-Link TL-WR1043ND
Dec 16, 2010 | Linksys WRT160N Wireless Router
I have a iomega eGo 500GB which I used on a dell laptop running Windows XP. I backed up all my files on the drive and now have a new laptop running Vista (old laptop has gone) put whan I pluged in the...
Enable "File and Print Sharing" on the "old" computer.
Connect the IOMEGA to the "old" computer.
Enable file-sharing on the "root" folder of the IOMEGA.
Connect the "old" computer to one of the LAN ports on a router (wired or wireless).
Connect the "new" computer to another LAN port on the same router.
Make sure that both computers are in the same "workgroup".
From the "new" computer, browse to "show computers in my workgroup".
You should see an icon for the "old" computer.
Double-click that icon to "open" that icon, and you should see all the files on the IOMEGA.
Copy those files to the 'C:' drive on the new computer.
Nov 11, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
How to hook up tv with internet hard wired to existing router with wireless connection to computer ip address on computer will not connect tv to internet help
Assuming that you have an "IP" TV, run an Ethernet cable from the TV to one of the LAN ports on the router.
Run another Ethernet cable from your computer to one of the other LAN ports on the router.
Both the TV and the computer should now have Internet access.
Do you have a third computer that has a "wireless" connection to the router?
Sep 26, 2010 | Belkin (F5D7230-4) Router (587009)
This is my situation; I have a hard wire connection from my wall phone/DSL outlet to a Westell model C90 DSL router/modem. Since this allows for only one single hard wire connection to one desk top (I have...
So you are connecting the DSL Modem output to the D-Link's LAN port 1, right? In this case, you should connect the DSL Modem output to the D-Link's WAN Port, which is between the power input and the LAN outputs.
If it doesn't work that way, check this out:
http://www.voipmechanic.com/westelltobridge.htm
Aug 24, 2009 | Computers & Internet
Internet access problem with a Linksys 54g router
Try setting the default gateway on the laptop to the ip address of your ICS gateway machine. Some routers separate the wireless and LAN connections on different subnets.
Try comparing your laptops ip information with that of one of the working wired computers. You can do this by going to Start up to run and type cmd then click "ok"
At the black prompt screen type "ipconfig" without the "".
You want to compare the IP Address, Submet Mask, and Default Gateway.
If one has an ip of 192.168.1.* and the other has 192.168.0.* then the wireless and wired are on seperate networks.
If the subnet masks are something like 255.255.255.0 and 255.255.255.1 they are on seperate subnets. Both should be fixable by putting in the same default gateway.
For example if your ICS gateway is 192.168.1.1 then set that as the default gatway on the wireless laptop. This can be done by going to start >> Control Panel >> Network Connections then right click your wireless connection and goto properties then double click on the "Internet Protocol (tcp/ip)" option. This will list all of your ip information (if its static) if its dynamic (ip gotten from router) you can still click "Use the following DNS server address" and set preffered dns to the gateway ICS ip. Or click "Advanced" and click Add under Default Gateways and add the gateway ICS ip there.
Jun 20, 2008 | Computers & Internet
Use a wired router for dial-up (NETZERO) connection..
You want to use a LAN with a router that uses a dial-up as a backbone internet connection for your LAN.
This is absolutely possible.
If you just want to share the connection that one computer has, and dont want to buy a router that has a built-in modem, try this
If you are running windows, There is a feature called Internet Connection Sharing (ICS.) It will share the dialup across the network.
Just 1 hookup the router and all the pcs to it. 2 Dialup the machine with the modem. 3 Enable ICS on that machine. 4 Youre LAN is online.
In XP, goto the network connections, and while you have 2 active connections in there (the dialup and the LAN port connected to the router), right click the dialup, goto properties. goto advanced tab, and click on enable ICS.
The other computers should be served IP's automatically and NAT'd out to the internet by the computer running ICS.
(The other computers should be automatically setup to the internet like they should be and connected to the dialup riunning on the ICS (host) computer)
May 16, 2008 | Linksys (R) RT41P2-AT 4-Port Wired Router...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
