Question about Kitchen Ranges
Preheat light is flashing, book says it is a faulty sensor circuit and to check the circuit. Where is the circuit and how do I check it? I have an ohmmeter/electrical tester.
  • horseshoer Nov 14, 2009
    Yes, very. I am trying the solution now. Good-bye
  • 6,784 Answers
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
NOTE_ The sensor is located , and mounted on the backside of the oven wall. Open your oven door, and look on the top right, or left hand side of the back wall. You will notice a 5 inch probe.This is where the sensor will be housed. there are two screws to remove, in order, to access the sensor. On most models, it will be required to remove the unit from the cabinet. this will allow you inspect the wiring and test as well. The sensor can be removed from the back of the unit, once it is removed from the cabinet. use the wire contacts on the sensor for testing.
Posted on Nov 14, 2009
Light flashing O/D OFF
book vehicle in to be diagnosed and checked
possible faulty O/D sensor or switch
Oct 06, 2016 | 1999 Ford Explorer
Why does my honda 420 FI light flash 9 times
Check your bike with it parked on the side stand. Count how many times the F1 light flashes. There are two types of flash that it gives off... a long one and a short one! A long flash = 10 short flashes.
So you may get 2 x long flashes and 5 x short flashes = 25 flashes in total.
The codes for Honda ST1300 are as follows. I know yours is a different model but I would have thought they would all be the same across the Honda range.
0 - bank angle sensor, ECM, PGM-FI fuse
1 - MAP sensor
2 - MAP sensor vacuum hoses, or sensor itself
7 - ECT sensor poorly connected or open circuit
8 - TP sensor, TP senspr wiring
9 - IAT sensor connection, or open wire
10 - Baro sensor, or connection, or wiring
11 - Vehicle speed sensor, or connection or wiring
12 - #1 injector connection, or faulty injector
13 - #2 injectior connection or faulty injector
14 - #1 connection or open/shorted circuit
15 - #2 connection or open/shorted circuit
18 - Cam pulse sensor, connection or loose sensor
19 - Ignition pulse sensor, connection or loose sensor
20 - faulty E-PROM in ECM.
Aug 18, 2015 | Honda Motorcycles
My Kenmore Model 91195371790 oven Preheat light comes on as soon as you turn oven on and then flashes f2
Over-temp condition due to either oven temperature sensor or ERC (electronic range control).
Testing should be done by a qualified tech to prevent risks to user.
Jan 16, 2015 | Kenmore Ovens
Codes 32 75 12 22 on a check engine light
first code it's P0320 Possible causes
- Faulty Ignition/Distributor engine speed sensor
- Faulty Crankshaft Position sensor
- Ignition/Distributor engine speed sensor harness is open or shorted
- Ignition/Distributor engine speed sensor circuit poor electrical connection
- Low battery charge
- Faulty Engine Control Module (ECM)
Read more: http://engine-codes.com/p0320_ford.html#ixzz3DcwddSlp
2- P0750 Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Faulty shift solenoid 1 valve
- Shift solenoid 1 valve harness or connectors
- Shift solenoid 1 valve circuit is open or shorted
Read more: http://engine-codes.com/p0750_ford.html#ixzz3DcwoXS73
3- P0120 Possible causes
- Faulty Throttle Position Sensor
- Throttle Position Sensor circuit is open or shorted
- Throttle Position Sensor poor electrical connection
Read more: http://engine-codes.com/p0120.html#ixzz3Dcx3VCPs
4- P0220 Possible causes
- Throttle Position Sensor (TPS) harness is open or shorted
- Throttle Position Sensor (TPS) circuit poor electrical connection
- Faulty Throttle Position Sensor (TPS)
- Fault Electric Throttle Control Actuator (or Throttle Body Motor)
- Accelerator Pedal Position Sensor (APP)
Read more: http://engine-codes.com/p0220.html#ixzz3DcxGUMl4
Sep 11, 2014 | 1991 Ford F150
Can you tell me the location of code reader 1991 capri ?
1991 is pre-OBD2. code readers will not work.
sorry.
however, all is not lost. Many cars have an alternate way of reading codes from the computer.
Toyota has a block under the hood and you short couple wires together and count engine light flashes
Chrysler you can turn the ignition key on and off a few times and count engine light flashes
in your case for GMs from 1982 to 1995
1: find the 12 pin connector under the dash and short the upper two rightmost terminals.
with the ignition "ON" and engine not running. The system will enter the diagnostic mode. In this mode, the computer will display a Code 12, three consecutive times, by flashing the "CHECK ENGINE", "SERVICE ENGINE SOON" or "MALFUNCTION INDICATOR LAMP" or light. A Code 12 consists of one flash, a short pause, then two flashes in rapid succession.
2:. After Code 12 is displayed, any stored trouble codes will be displayed by flashing the "CHECK ENGINE", "SERVICE ENGINE SOON" or "MALFUNCTION INDICATOR LAMP" light. All codes are displayed 3 times each then a code 12 will repeat. In the diagnostic mode, the computer will also energize all computer controlled relays and solenoids.
Tech -- GM 2 Digit codes for 82 and up (non OBD-II)
code - code definition
12- diagnostic mode
13- 02 sensor or circuit
14- coolant sensor or circuit/ high temp indicated
15- coolant sensor or circuit/ low temp indicated
16- system voltage out of range
19- crankshaft position sensor or circuit
21- throttle position sensor or circuit- voltage high
22- throttle position sensor or circuit- voltage low
23- mixture control (m/c) solenoid or circuit (carbureted models)
23- manifold air temperature (mat) sensor or circuit (1990 and earlier models)
23- intake air temperature (iat) sensor circuit (fuel-injected models)
24- vehicle speed sensor (vss) or circuit
25- manifold air temperature (mat) sensor or circuit - high temperature indicated (1990 and earlier models)
25- intake air temperature (iat) sensor or circuit - high temperature indicated (1991 and later models)
26- quad driver module circuit
27- quad driver module circuit
28- quad driver module circuit
29- quad driver module circuit
31- park/neutral position (pnp) switch circuit
32- baro sensor or circuit (carbureted models)
32- egr circuit (fuel-injected models)
33- manifold absolute pressure (map sensor signal voltage high
33- mass air flow (maf) sensor or circuit - excessive airflow indicated
34- manifold absolute pressure (map) sensor signal voltage low 34- mass air flow (maf) sensor signal - low airflow indicated
35- idle speed control (isc) switch or circuit (shorted) (carbureted models)
35- idle air control (iac) valve/ circuit
38- brake switch circuit
39- torque converter clutch (tcc) circuit
41- no distributor signals to ecm, or faulty ignition module ( carbed models)
41- cylinders select error- mem-cal or ecm problem ( fuel-injected models
41- cam sensor circuit (3.8 engine)
42- bypass or electronic spark timing (est) circuit
43- low voltage at ecm terminal l (carbureted models)
43- knock sensor circuit
44- oxygen sensor or circuit - lean exhaust detected
45- oxygen sensor or circuit - rich exhaust detected
46- power steering pressure switch circuit
48- misfire diagnosis
51- prom, mem-cal or ecm problem
52- calpak or ecm problem
53- egr fault (carbureted models only)
53- system over-voltage (ecm over 17.7 volts)
54- mixture control (m/c) solenoid or circuit (carbureted models)
54- fuel pump circuit (1986 and later models)
55- oxygen sensor circuit or ecm
55- fuel lean monitor (2.2l engine)
61- oxygen sensor signal faulty (possible contaminated sensor)
62- transaxle gear switch signal circuits
63- manifold absolute pressure (map) sensor voltage high (low vacuum detected)
64- manifold absolute pressure (map) sensor voltage low (high vacuum detected)
66- pressure sensor or circuit air conditioning
May 20, 2014 | 2002 Subaru Forester
The stove preheat light is on and the oven does.nt cook fast
Hello Theresa Thomas - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the range back on. Select a normal bake cycle and if issue continues then the unit may possibly have either a faulty element, bad communication error with the EOC, oven sensor, or mechanical thermostat. I strongly suggest contacting a professional to move forward accurately. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. .
Nov 20, 2012 | Frigidaire FEF366 Electric Kitchen Range
Dolce gusto kp2100 won't stay on
in the machine there is small circuit board that control the machine so they programmed that circuit to preheat the heating element for about 30s if this failed the red light flashes two tims then stops so you have to change the circuit board
Oct 07, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Oven won't shut off and preheat light flashes
"The thermal sensor shouldn't have gone out that fast". It could if it was defective.
Sep 17, 2017 | Frigidaire FEF366EC 30" Freestanding...
Error message of F-3
Check oven temperature sensor or wire harness to oven temperature sensor. Probably faulty.
Dec 09, 2008 | Ovens
Preheat light goes on then start flashes then F1 flashes
F1 is an indication of a faulty control board, you can try unplugging for a bit, relpacing control if htat doesnt rectify, the parts not repairable, only replacable
Dec 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
20 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
