Question about Whirlpool Duet GHW9150P Front Load Washer
Maytag washer, f26 code, was able to resest from an f20 code 2 days ago with a button combination and can still access the code menu just do not know what code to put in to clear this code
  • jstone_33 Nov 14, 2009
    thank you but i posted under the wrong washer. MAH22PRAWW is the model i have and there is a button combination used to get to a code menu and i can get to the code entry but you have to use a code made up of the bottom 3 buttons
  • 10,515 Answers
F-26, is a door lock switch error code. Some things to try; Unplug the washer for 1 minute and see if the error clears. If not, try entering the diag mode by pressing any key except pause/ cancel. Press for 4 seconds and release for 4 seconds 4 times. If entered correctly, all lights should light and the first error should appear. Press the same key to advance through all the errors. When the errors finish. It will start an automatic test mode that tests all components. The first thing it will test is the door lock. If this fails you more than likley have a door switch problem.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2009
What fauit code f26 mean
This error code indicates that the door needs to be opened and closed.
For a more thorough explanation, check out member Yadayada's explanation here -
My maytag commercial washer display code F26
Sep 20, 2017 | Washing Machines
Codes f26 and then f27 for maytag model MFH 0710
F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start. unsure of f27
Dec 23, 2016 | Maytag Washing Machines
What does f26 mean for siemens washing machine
F26 come up This error code indicates that the door needs to be opened and closed.The F26 code may appear the first time you try to use the washer. Open and ...
Jan 03, 2016 | Siemens Washing Machines
F26 code
Unplug it and wait a while, the door may finally release the lock. Then google the problem to see what F26 is.
Nov 25, 2013 | Hotpoint Ultima WD72 Front Load...
My maytag commercial washer display a code F26
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Error code F26
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
Washer says f26 and won`t spin the clothes out. is there anything i can do?
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
I have a Kenmore Elite HE5t and the code F26 keeps coming up Please let me know what that is My acct is under the phone719-465-3853
The door switch sensor button may be sticking in the closed (pushed in) position. Try to get it to spring back out. Otherwise the washer computer "thinks" that the door has not been opened for three cycles (F26).
Aug 02, 2010 | Kenmore Washing Machines
F26 Error - Door Switch?
when you hear clicked can you open the door?its should be locked...
Oct 12, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
158 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
