Question about UTStarcom Blitz Cell Phone
My blitz screen will only work while its beeing charged
I dropped it and now it won't turn on
it could also be loose wiring after you have dropped it, either way someone definitely needs to open it up and take a look
Apr 27, 2014 | Verizon Wireless PCD Blitz TXT8010 -...
My Verizon Blitz won't connect to my computer
Endless hours were spent trying to connect my Motorola Razr to my computer. This finally worked:
Go to Google Playstore on the phone. Download Motorola PIM (all upper case).
If you have an extended battery case/charger on the phone, remove the phone and insert the USB cable into the port on the top of the phone.
Or
Download "Airdroid" and connect wirelessly.
Nov 02, 2013 | Verizon Wireless PCD Blitz TXT8010 -...
I plugged in my phone but it will not charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 04, 2012 | Verizon Wireless PCD Blitz TXT8010 -...
My blitz phone battery isnt working AT ALL!!:(
i had the same prob my mom didn't believe me you have to push the charger in really hard still doesnt work all the time though
Feb 01, 2010 | UTStarcom Blitz Cell Phone
Blitz Phone only works when charged
the phones just a piece of **** mines doing the same thing and its not the battery the phone needs to be recalled
Jan 28, 2010 | UTStarcom Blitz Cell Phone
UT Blitz Has to be charging to work
could be either 1, needs a battery or a 2 new charger, even though it looks like it is charging.
Aug 26, 2009 | UTStarcom Blitz Cell Phone
No source of Power with BLitz
you need to service the pannel to make it work fine or change the charging port it may be faulty or put in small led to sold it back it might be broken.
Jul 17, 2009 | UTStarcom Blitz Cell Phone
UTStarcom Blitz Cell Phone Logo
120 people viewed this question
Top UTStarcom Cell Phones Experts
iphone service
buzzcola
Level 1 Expert
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
