Question about LG Neon GT365 Cell Phone
How can I us my voice clips for my ringtones - LG Neon GT365 Cell Phone
How can I change ringtones on hisense u962 android
You can change your ringtone by going to:
  1. System Settings ? Audio Profiles
  2. "Pre-defined profiles": under "General," press the icon to the right: Settings.
  3. Under "Incoming Calls," choose "Voice call ringtone." Here you can set your default voice call ringtone.
Feb 04, 2018 | Android Cell Phones
Change ringtone
Change your ringtone
1. In Idle mode, press Menu, Settings ,
Phone settings , Phone profiles.
2. Scroll to a profile.
3. Press ,Options , Edit ,Voice call, ringtone.
4. Select a ringtone category , a ringtone.
5. Press ,Options , Save profile.
Nov 03, 2013 | Samsung J700 Cellular Phone
Every time says phone memory full. delete some datas. how to delete some data in the phone memoy
Delete sms, all type of media file as a ringtone,video clip, voice recording move on external memory.
Nov 23, 2010 | Nokia N72 Cellular Phone
Ringtone for LG Scoop
if you want the voices of your relatives and friends recorded and personalized a your ringtone for them,follow the steps:
1.you go to the menu and you click on multimedia,you find the voice recorder there
2.you tell your family and friends or whoever person you want to keep talking and you record their voices,it saves automatically in the sounds located in "my stuffs"
3.you now go to your contacts,click on contacts you will find your groups i.e family and friends,you click on options,you will find the group ringtone,you click ok,immediately the sounds stored on your phone opens including the recorded voices and you click ok on the desired voice for the group or persons
Feb 27, 2010 | LG VX8300 Cellular Phone
How do i make a voice record and set it as my ringtone?
its nothing wrong with the voice recording, or your phone, voice recordings are simply not allowed to be set as a ringtone,
i have the same phone and it took me many calls and headaches to At&t before they told me that anything set as a ringtone had to be in mp3 format.
Jul 20, 2009 | LG Vu CU920 Cellular Phone
Voice recorder... need to find it on my phone
You jus gotta record the voice using the voice recorder and the file will be saved in the "SOUNDS" folder.You can select the recorded file and set it as ringtone. Simple...
And if this solution has helped...PLEASE leave me a FIXYA RATING.
Thank you.
Mar 13, 2009 | Sony Ericsson Walkman W810i Cellular Phone
VOICENOTE TO PERSONALIZED RINGTONE ON BB CURVE 8330?? PLZ HELP!
Voice Notes to Ringtone.
If the voice note is stored on the device memory:
Go into the Media icon. Hit the BlackBerry® (menu) button and select ‘Explore’. Select ‘device memory/home/user/voice notes’. Highlight the voice note and hit the menu button. Select ‘Copy’. Hit ‘Up’ twice. Highlight the ringtones folder. Hit the menu button and click on ‘Copy Into’.
If the voice note is stored on the media card:
Go into the Media icon. Hit the BlackBerry® (menu) button and select ‘Explore’. Select ‘Media Card/BlackBerry®/voice notes’. Highlight the voice note and hit the menu button. Select ‘Copy’. Hit ‘Up’ twice. Highlight the ringtones folder. Hit the menu button and click on ‘Copy Into’.
Now the voice note will be available as a ringtone and can be assigned to a specific individual.
Mar 01, 2009 | RIM BlackBerry Curve 8310 Smartphone
Message tones and vibrate facillity
To change the vibrate function:Go to main menu, phone settings, phone profiles, highlight the 'normal' one & press the 'options' soft key to the left of the touch screen keypad. Pick 'edit', then the 'call alert type' will be highlighted. Press the left soft key saying 'options' & select 'change'. You can then opt for it to vibrate by highlighting the vibration one & pressing the tick on the touch screen bit. Then don't forget to save the changes!
To Change the ringtone:
  1. From the standby screen, press Menu (Figure 1).
  2. In the main Menu, press Settings (Figure 2).
  3. In the Settings menu, select Phone profiles and press (Figure 3).
  4. You will be presented with a list of phone profiles for different situations and environments. The one you're currently using will be ticked. Highlight the one you want to use (in our example, Normal) and press the Edit button at the bottom of the display (Figure 4).
  5. You are taken into the profile settings (Figure 5). At the top of the list you'll notice three tab icons - these represent (from left to right), ringtone, message alert, and keypad sounds. You can switch between settings for these by tapping one of the tabs.
  6. You should be taken first into the ringtone settings list. Should you want to change the Call alert type (from melody to vibration then melody, for instance) tap this option and scroll through the list of options to choose the one you want.
  7. To change the Voice call ringtone, tap this option on the screen. You will be taken into a list of phone file folders from which to choose your ringtone (Figure 6). You can tab across to view files stored on a memory card, if you have one installed.
  8. Press the Sounds option. You now have the choice of choosing from yourMusic files, Ringtones that are loaded onto the phone, or My voice clips(clips you have recorded) (Figure 7). You can select from whichever of these folders you want - the setting procedure is the same for each. In our example, we'll choose from our Music folder to select one of our tunes as the new ringtone.
  9. Press the Music option. A list of tracks appears (Figure 8). Tap the one you want in order to highlight it (Figure 9). Press Options, then tap on theSelect menu option to install it as your ringtone (Figure 10).
  10. You are now taken back to the Normal profile settings, where the Voice call ringtone has changed (Figure 11). To save this change, press Options and then Save (Figure 12). Alternatively, press Back and you will be asked whether you want to Save?. Press Yes.
In the ringtone settings menu, you can also change the video call ringtone (which is lower down the menu) by following the same procedure.
Aug 27, 2008 | Samsung U900 Soul Cellular Phone
Motorola RIZR Z3 - Recordings as Alerts
Some phones will not let you set voice notes as a ringtone. If you get Motorola Phone tools, (available through motorolas website for download about $30.00) it has a ringtone creater that you could use to create a ringtone from a recording.
It also is syncronization software that will allow you to transfer files and back up your contacts.
Feb 04, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
LG Neon GT365  Cell Phone Logo
27 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
