Question about LG Neon GT365 Cell Phone
How can I use my voice clips for my ring tones
    Problem Solver:
  • 4 Answers
You can't but you can listen to them on your mp3.
Posted on Nov 14, 2009
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
Hello, my phone has been very wierd. when someone calls me, it will have a voice be saying, call from so and so. and i want it to be just a ringtone. please help!
Which phone are you using ? Check your applications if your have installed any software like Voice/Talking Caller Id or something similar . This software will be the reason the Caller id is a voice and not a ring-tone. Even check the settings in ring-tone if you and option to switch off Voice Caller id. Either uninstall the software or disable the software from the options within.
Jan 19, 2011 | Cell Phones
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
Ring tone cuts out too fast. How do I prolong dialing tone so thst I can grt to phone before it cuts out?
When the ring tone cuts out, your caller goes to your voice mail, right?
The length of time before an unanswered caller goes to voice mail is called your "ring cycle" and is set by your phone carrier (e.g. Vodaphone, Verizon, Orange, etc.)
There shouldn't be any charge to change your ring cycle, and some cell carriers will let you adjust it from your account settings on their website, but the simplest answer is just to call your carrier's customer service and ask them to change the ring cycle for your number.
For cell carriers in the US, you can call 611 from your phone to reach your carrier's customer service, but I don't know about other countries' mobile carriers.
Feb 11, 2010 | Cell Phones
SINCE NEW , UNABLE TO CHANGE RING TONE. IT ONLY
Under settings menu touch, more, applications, voice command, call alert. Change to ring only. Hope this helps.
Aug 05, 2009 | LG Xenon GR500 Cell Phone
How can i set message ring tone.
Go to menu>my stuff> tools >utilities. Scroll down > my voice.
Then press record .
To set it as your ringtone:
Go to menu, settings, then profiles. Then it takes you to flight mode, silent, vibrate, ring, and etc. On the side it says options. Select it. Scroll down to customize. Then just change the ringtone or scroll down to message tone.
Jul 25, 2009 | Pantech Matrix Cell Phone
LG Chocolate Ringer problem
Go to tools, phone settings, voice commands, call alert then do not select name repeat, the other 2 selections have a ring.
Mar 28, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Turnoff keypad tones??
dear smoothy, there is an option in your voice settings which says 'keypad volume'. You have to set it to minimum or zero. After that you will not hear your keypad beeps, and it will not effect your caller tone because it is altogether different option and has nothing mutual.
If that has helped you please press 'fixya'
Nov 29, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Setting up ring tone
When the phone is sitting in its normal mode hitting the "flash" button toggles through the available ring-tones, including my favorite: off
Jun 11, 2007 | Innovage Touch-panel Phone 1502084
No voice during calls both incoming and outgoing
Have the audio jack repaired it's not making contact on the connecting plates properly. You ould have a go at this if you are very good with fine electronics
Nov 26, 2006 | i-mate PDA2k Pocket PC
LG Neon GT365  Cell Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
