Question about Pride New Mobility Legend 4 Wheel Scooter
My invacare auriga 3 wheel scooter will not work got 2 new batteries but will not power light flashing on charger as if charging but when put key in not even lights comne on
  • Pride Master
  • 1,271 Answers
Can you clarifly what happens you plug in the charger in ?
Are you sure the fuses on the battery leads are okay ? the is one for each battery like a glass container ? check they have not blown, check the connections to the battery , are they tight ?
Regards
gewizrepairs.co.uk
Posted on Dec 02, 2009
Invacare Meteor Hillclimber. I have replaced the old batteries with 2 x FullRiver 12v 65Ah batteries. The charger is the original one supplied with the scooter by Invacare, 24v 8amp. I returned the batteries to the supplier for testing as they appeared not to be fully charging.The batteries tested out to be in perfect working order. It was suggested by the battery supplier that for reasons not known to them that the batteries were not being fully charged. My charger is showing that it is fully charging the batteries through the three stages. It has always been my practice to put the scooter on charge after every use. I am thiking of getting the scooter checked out by an auto electrician. Hope you can shed some light on this problem. Cheers Brian
Posted on Jun 05, 2011
Mobility scooter lights wont turn off
It really can only be one thing. Somewhere on your scooter is a switch for the lights. Try turning it off. If that doesn't work the switch is faulty
Nov 01, 2016 | Invacare Health & Beauty
I have a invacare agura mobility scooter with new batteries but the power lights fluctuate in use the lights go down fairly quick if i turn the scooter off for 2/3 seconds the lights go up for a short time
if it is not making a difference in speed sounds ok deep cycle batterys run at same amps until completely dead this is when they should be charged for 8 hours most chargers are auto shut off
Mar 18, 2013 | Invacare Health & Beauty
Where is the circuit breaker for an Invacare Lynx 4 scooter?
Heres a link to the manual
http://www.invacare.com/doc_files/1143205.pdf
Go to page 54 is the service lamp flashing?
Circuit breaker is on page 55
Bunch of things to check on page 53
Get back to me if you still have problems
May 30, 2012 | Lynx Invacare 4 Wheel Mobility Power...
HI Scooter is on charge full time and used daily after 30min i loose the first green light that is OK but if i dont use it for one or two days i loose the first green light only after 10min can you...
well it could be that you overcharged the batteries. You should not leave the scooter on the charger full time. you should charge the scooter nightly while you sleep unplug from the charger when you get up in the morning. the charger should not be on the scooter more than 12 hours per day and that rare. Whenever you have a red and green light on the charger the scooter is fully charged and can be unplugged. Always put it up fully charged and then charge after each use. Your batteries need to be replaced and charge the new ones before use then charge overnight each day that you use the scooter. If you don't use it for a few days you should still be fully charged than charge after use Hope this helps
May 12, 2011 | Invacare Supply Group Invacare Scooter...
My wife has an Invacare Auriga, it was not charged over winter, therefore batteries went flat. I bought 2 new batteries and fitted them, but when I switch the key on, the left hand light on the dash panel...
Check that you are not in freewheel. If you can push the scooter easily and the rear wheels roll then you are in freewheel. Move the lever to drive postion and turn the scooter on to see if that fixed the problem Hope this helps
May 05, 2011 | Health & Beauty
I have an invacare ride on . The battery charger failed after the storm. Are they repairable or do I need a new one. If so, how much do they cost
The battery charger for this scooter is available from:
http://www.monsterscooterparts.com/
I believe the original equipment charger from Invacare for this scooter was a 3 Amp off board or on-board charger. The charger is no longer available from Invacare. Monster scooter parts shows this as a 2 Amp charger for the Lynx.
It would be more expensive to repair this charger than to replace it since you indicate it failed after a storm power surge. You will be happier by replacing the off-board or on-board charger for a price between $50 and $150. The only cost effective charger repair is the cord or plugs.
If the charger was plugged in during the storm, I would check the power path on the scooter for burnt fuses and wiring. Hope this helps.
Dec 30, 2010 | Invacare Supply Group Invacare Scooter...
Have Invacare Auriga 4 scooter about 2yrs old Put into stores about 6 months ago was working fine battery's have always been on charge. Cannot get scooter to move. When I put de-clutching lever in to...
Hi. I have had a few scooters that have had this problem after sitting for a while. The brake lining is stuck to the body of the brake assembly. When the brake is energised by the controller, it can't release.
De-clutch the machine like you did, and try rocking the machine back and forth. If this doesn't work you might have to have a new brake assembly fitted.
The wheels turn in opposite directions, because the drive is through the differential unit in the rear axle. Even a car will do this if the driving axle is raised in the air.
I have also had a few cases of stuck motor brushes in these machines, but from your description, I would say it is the brake assembly.
Good luck. Neil.
Jun 13, 2010 | Health & Beauty
Invacare auriga looses power
Hi. Most probably its the throttle pot ( Wig Wag ) thats causing the problem. I am an Invacare service agent and I have changed these many times for this very reason.Also check motor brushes are not worn down or jaming. Good luck. Neil.
Mar 21, 2010 | Health & Beauty
Blinking charge light on Invacare Zoom 300 scooter
Can you try another charger ?
Is it a onboard charger ? if so they do go wrong, Are they supply MK batteries ?
Check the leads from the charger connection socket to the motor controller board.
Regards
GeWiz.
Oct 03, 2009 | Invacare Pronto M51 Power Wheelchair
Pride New Mobility Legend 4 Wheel Scooter Logo
678 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
