Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
How do I change the lamp? - Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
  • 668 Answers
You need to remove the Front Panel. This is done by loosening the retaining knobs found on the lower rear edges. Once this is done the Front Panel will pull off. The Lamp Door is just left of center on the bottom front.
I hope this helps,
Skyassoc
Posted on Nov 15, 2009
How do I reset the lamp timer for the infocus LP925 projector? Are there other problems that could cause my issue?
hi
this lamp has a small lamp pcb with a chip on it.
have u change the complete module or have just changed the bulb.
if you have just changed the bulb then u have to replace the small fuse on the chip.
this should help to reset the lamp timer!
Apr 07, 2015 | InFocus SP-LAMP-LP9 Projector Lamp for...
I have a mitsubishi 73735 television that is not showing a pcture there is a red lamp light on; on the front of the television does the lamp need changing
Hello, welcome to Fixya!
My question would be; how long have you been using the TV and have you every changed the lamp?
If you have never changed the lamp or if it has been a long time since you changed the lamp, then it means the lamp needs to be changed.
The red lamp staying on, also could mean a power problem. But,in any case, go ahead and change the lamp. Hopefully, it should fix the problem.
Regards.
Nov 03, 2011 | Mitsubishi WD-73735 Television
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Flashes change lamp after a couple of hours run
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 02, 2009 | Sharp ANXR1LP Projector Lamp for XR1X,XR1
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
How do I change the lamp in this tv? Do I need to buy just the lamp or lamp with housing?
If you have not changed a lamp before at all, I would suggest that you purchase the lamp plus housing. This will contain complete instructions on how to change the lamp and reset the counter. Keep the instruction sheet and the old housing and you should be able to replace just the lamp the next time.
Dan
Apr 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Need to change lamp
I need to change lamp for sony KF-50we610 TV. Just got the new lamp and ready to change.
Thanks.
Aug 09, 2008 | Sony Grand WEGA KF-50WE620 Television
Projector
Go into the projector menu, OPTION and then select LAMP TIME.
May 30, 2008 | 3M Projector lamp Projector Lamp
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
