Question about HP OfficeJet k60 All-In-One InkJet Printer
I have installed new cartridges but the status panel keeps telling me to remove and check colour cartridge
  • 4 Answers
Reboot your PC , unplug your power and usb / parallel port and see if this clears the message. Run a "clean cartridge and align paper" also
Did you buy refilled ink cartridges, 'cus if so, this could be the problem,
Sometimes it happens to me also, hwen I buy those refilled cartridges but I just ignore it and it prints, scans and copies, even if that error message is on the front screen.
Posted on Nov 15, 2009
Check print cartridge keeps coming up so i refilled the cartridges and reset the printer but the fault keeps coming on.
Your pen nib is faulty, but you are filling the ink, it wont work right?.. Similarly print cartridge(s) are faulty, no use to refill it. Do this exercise:Remove both cartridges from the printer, switch on the printer see the cartridge missing status on panel, insert mono(Black) cartridge close the door see the panel massage, if it's detected no issue with mono cartridge,if not mono cartridge faulty. insert colour cartridge & see..find out replace it...
Apr 28, 2012 | HP PSC 1315 All-In-One InkJet Printer
I had my cartridges re-filled at Cartridge World for the second time. The first time gave no problems. This time I installed the cartridges and for some reason the colour will not work at all. The status...
remove cartridge(s) and insert surface head into hot water for about 20 seconds and test it by sliding it over a cloth. Repeat untill ink visible.
good luck
pls. vote for better sharing ... thank you
Nov 21, 2010 | HP C4680 All-In-One Inkjet Printer
I installed new color and black ink cartridges and keep getting: color cartridge short. Press power key. Hence, the printer will not work.
It could be a "short-circuit" type of electronic problem inside the colour cartridge.
Turn the printer off.
Remove the colour cartridge.
Purchase a new colour cartridge.
Insert it.
Turn the printer on.
If you still get the error, take the printer to a qualified technician.
Jan 22, 2010 | IBM Lexmark X83 All-In-One InkJet Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Installed black ink but hp psc 750 keeps saying install colour and i only have black ink. Can you operate this printer without colour in.
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP PSC 750 All-In-One InkJet Printer
HP 7410 printer displays error ''remove and check colour cartridge
I think that spring must have gotten loose that holds the cartridge in place, right hand side, put it back where it belongs, might want to compare with the other, black cartridge side.  Good Luck!
May 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
New colour cartridge inserted and machine keeps saying remove ano
Are the cartrideges real HP ones or an off brand? If a substitute , take them back for a refund and get the real thing.
http://h10025.www1.hp.com/ewfrf/wc/product?product=60259&lc=en&cc=us&dlc=en〈=en&cc=us
Jan 06, 2009 | HP PSC 950 All-In-One InkJet Printer
How do you install ink into a hp c4180
Hi bogtank, here are the instruction on how to install the ink cartridges.
  1. Open print cartridge door, make sure the print carriage moves to the right, if it does not move to the right, turn the device off, then turn it back on again.
  2. Remove the tape from both cartridges, making sure you don't touch the copper coloured contacts.
  3. Hold the cartridge with the HP logo on top.
  4. Insert the tri-colour cartridge in the left cartridge slot, and the black cartridge in the right slot.
  5. Make sure you push the cartridges in firmly until they snap into place.
  6. Make sure you have paper loaded in the tray and close the print cartridge door.
  7. Press OK at the promt on the display to start print cartridge allignment.
  8. Check the display for status then press OK.
Nov 13, 2008 | HP Office Equipment & Supplies
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Cartridge problems with the P915 Lexmark printer.
Check that the contacts are clean. Also try another catridge. Even a new on can be bad...
Geno
Mar 04, 2008 | Lexmark P915 InkJet Photo Printer
HP OfficeJet k60 All-In-One InkJet Printer Logo
143 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
