Low Water Level in Roper washing machine
When the tub fills at the start of the wash cycle and at the rinse cycle - it ionly fills half way. This happens regardless of the amount of clothes i put in...an empty tub is opnly half way filled. For every load i have to turn and hold the water level knob till the tub is filled. Is there an adjustment somewhere for water level? Thanks in advance!
  • 464 Answers
You need to check the pressure switch which is also called the water level switch. There is a small tube attached to it and it may have a blockage or a hole in it. You can find this behind the control panel to the left of the timer.
Posted on Nov 14, 2009
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Roper washer rtw 4440 xqo very low water level for wash & rinse
You will need to replace the water level switch. Here is a link to the kit.
Here is a video to show you how to replace it.
Oct 21, 2012 | Roper Washing Machines
I have a Roper washing machine (Model: RTW4440XQ0, Serial #: C11740048) that is less than a year old. When you start the machine on any cycle (on high water level) it will fill up with water and run...
The machine was built to adhere to the low water guidelines of your overly intrusive government. Bought a new machine with the same problem. 1/2 tub of wash water and 3"-5" of rinse water. 3 different local service shops and the Whirlpool people said neither was adjustable. I found this unacceptable and decided I was going to make it work the way I wanted not the way the government schlocks said I must. Took out the 2 screws on either end of the control panel ( where all the controls are) lifted it up and found 2 ADJUSTABLE water level control switches. One 3-way for the wash water and one for rinse water. Cranked them both in and now I have a full tub of wash water and the same for rinse, Vote in 2012 to keep the government out of our homes and our lives,
Sep 14, 2011 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
The water is going out the drain and cannot fill up the tub.
Check out the height of your drain. If the drain is too low, the water will drain right out of the tub. Check out the attached photo. Hope this helped and best wishes.
Aug 02, 2009 | Roper RAS8445KQ Top Load Washer
Water runs contiuously... tub never fills...cycle doesn't start.
Hi, You need to reset the drain hose. It needs to be over the water level in the machine. If you have it in a sump pump, it needs to be out of the water in the sump. If I can help you further, please let me know
Thanks
Vic
May 16, 2009 | Roper RTW4100SQ Top Load Washer
Washing Machines Logo
472 people viewed this question
Top Washing Machines Experts
